Dabar yra 2026 07 02, 19:22. Visos datos yra GMT + 2 valandos.
 Forumas » Garso stiprintuvai » Tranzistorių kaitimas
Puslapis 13
Pereiti prie 1, 2, 3  Toliau
PranešimasParašytas: 2011 01 02, 16:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa
http://sound.westhost.com/project117.htm
Šioje schemoje Q4, Q5 ir Q6 reikia statyti ant radiatorių ar ne?
PranešimasParašytas: 2011 01 02, 16:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
kionig
* Note: It is imperative that Q5 (the bias servo transistor) is mounted on the heatsink, in excellent thermal contact. This is because, unlike most of my other designs, this amp uses conventional Darlington output configuration. It is necessary to use a Darlington arrangement (or a low power Darlington transistor as shown) for Q5 to ensure that the bias remains at a safe value with temperature. This is left to the constructor, because as noted I will not provide technical assistance for this design. There is probably good cause to model and test this aspect of the design very carefully, because it is so important. The arrangement as shown will reduce quiescent current at elevated temperatures. For example, if total Iq at 24°C is 165mA, this will fall to ~40mA at 70°C. This is probably fine, because there is some delay between the a power 'surge' and the output transistors transferring their heat to the bias servo via the heatsink.
The MJE340/350 pre-drivers reduce the loading on the VAS (voltage amplification stage) and ensures good linearity with acceptably low dissipation of the VAS transistor (Q4) and its current source (Q6). Even so, with around 12mA through the VAS, dissipation is 0.72W, so Q4, Q6, Q9 and Q10 must have heatsinks (or a common heatsink that is suitable for the power dissipated). The bias servo transistor (Q5) should be mounted in thermal contact with the main heatsink.
PranešimasParašytas: 2011 01 02, 17:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa
В этой схеме Q4, Q5 и Q6 надо снабдить теплоотводами или нет? Very Happy
PranešimasParašytas: 2011 01 02, 17:43 Pranešti apie taisyklių pažeidimą Atsakyti su citata
jonyys
Kai pasidarysit ši stiprintuva norėtusi išgirsti nuomone apie jo galia, veikimo niuansus ir derinimo problemas.
Gal būt ir aš bandyčiau šį variantą pasigaminti.
Mano galva minetiem tranzam nereikia radiatoriaus.
Aš turiu pasidares pagal šia schema stiprintuva http://www.pics.lt/gallery.php?entry=images/p68888888.gif
MJE340-350 nei kiek nešyla. Tai ir toje schemoje tie tranzai manau kad neturėtų kaisti. Very Happy
 Re: Tranzistorių kaitimas
PranešimasParašytas: 2011 01 02, 19:36 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa rašo:
4 ir 6 reikia, 5-as turi but prisuktas prie galiniu tranzu radiko, dar geriau - tiesiai prie vieno is galiniu tranzu ir turi turet su juo kuo geresni silumini kontakta
PranešimasParašytas: 2011 01 03, 00:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa
jonyys rašo:
Kokia gali būti nuomonė apie 1,5 kW? Gal galingas Smile Kad pasidarytum jį tau prireiks 2 kVA transformatoriaus (500 ir daugiau lt) ir nemažo radiatoriaus, nesitiki, kad tiek litų turėtum Wink
PranešimasParašytas: 2011 01 03, 00:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa rašo:
nuomone, be abejo gali buti tik viena: totalus briedas
tokios galios stiprintuvas turi buti D-klases
PranešimasParašytas: 2011 01 03, 09:13 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vinor
andriusa rašo:
jonyys rašo:
Net įdomu kaip kiti per atstumą gali svetimus pinigus skaičiuoti, o gal čia naujasis Mesingas Very Happy
PranešimasParašytas: 2011 01 03, 09:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa
gnt rašo:
andriusa rašo:
Žinai, aš todėl ir nebevaikštau į koncertus, neįmanoma apsiklausyt.
PranešimasParašytas: 2011 01 03, 09:46 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vsa
Cia subwoofer-iui ? Andriusa-paskaityk tema is vegalabo /forumo "usiliteli visokoi mochnosti"-daug naudingo rasi.(autor.WP)
PranešimasParašytas: 2011 01 03, 09:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ampmod
andriusa rašo:
Kai fonogramą/įrašą leidžia iš 16 Bit CD, tada taip, labai prastas garsas. Bet kai gyvai groja, galima klausyti.
Bet aš irgi nebevaikštau jau kokius 4-5 metus, po to kai mano tėčio pažįstamą, po vieno renginio, apgirtę jaunuoliai sumušė alaus "bambaliais", vėliau jis reanimacijoje mirė...
PranešimasParašytas: 2011 01 04, 02:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
VEC7OR
http://sound.westhost.com/articles/class-g.htm
Dar seip tokie daiktai yra.
Beje kokia prasme ish to stipriako ?
PranešimasParašytas: 2011 01 04, 05:24 Pranešti apie taisyklių pažeidimą Atsakyti su citata
andriusa
VEC7OR rašo:
Vatai.
PranešimasParašytas: 2011 01 04, 06:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
VEC7OR
andriusa rašo:
Vatai.
Class D ?
PranešimasParašytas: 2011 01 04, 18:25 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ba1tuks
O aš atvirkščiai už G klasę būčiau. Kokybė artima AB klasei, bet naudingumas yra didžiausias kai galia kiek galima didesnė. Kaip ir įdomu čia Smile O be to būtų kažkas naujom, o ne tie patys atsibodę stiprintuvas AB klasės. Beje, kai tokios galios, imamas ne trafas, o SMPS. Sutaupai daug vietos ir pinigų Wink
2KW SMPS gali suręsti už kokius tris šimtus. Tereikia didelio feritinio žiedo, geros saujos mosfetų ir kondikų...
