Dabar yra 2024 03 28, 20:09. Visos datos yra GMT + 2 valandos.
Forumas » Programinė įranga » android OS instaliavimas
android OS instaliavimas |
Parašytas: 2016 01 06, 20:06 |
Seip man biciukai uzsienio forume va raso kad reik atsisiust kaskokia programele ir kaskaip nulauzinejant sistema pakeist touchscreen.idc faila ir tipo ekranas vel veiks, bet bijau kad vapse pzda bus, dar raso kad reik sistemai root daryt
For the colleagues that have problems with screen calibration, maybe you can try this tutorial: http://forum.xda-developers.com/show....php?t=2263582
I copied the usr* folder and took a look, there is no information in idc related to screen calibration. As I know there is not calibration method for the capacitive screens (because the way they work) so If you opened the unit maybe you can check again the connectivity between front panel and main board.
There is also an internal calibration mechanism (but again I think only for the resistive touch):
SSH into the box or use a terminal emulator. At the command line, enter the following commands:
su (this gives you permission to modify the system files)
getprop ro.calibration (this checks that the android calibration property is enabled, it should reply with a value of 1, if it does not STOP HERE!! )
cd /data/system (this is the location of the calibration file)
mv calibration calibration.backup (here you are saving your old calibration file, you can call it backup1, backup2, etc if you're doing this multiple times)
reboot (or turn off your device via the power button and restart it) |
Parašytas: 2016 01 06, 20:07 |
Regarding your Question @Edgaras7777
I Found The Links in The Russian Site Thanks TO @dragoescu
http://4pda.ru/forum/index.php?showt...#entry39825535
Just Google Translate it To English You Will Find your firmware 2.9.4 With Screen Resolution 1024 × 600 , You will Find Different Suppliers Find the firmware suits you among them Plus Many Other Firmware and MCU Firmware
For My Problem I Restored My Unit Back To 2.9.5 But Touch Still not Fixed , I've Configured a workaround thanks to @logicMASS Using his Method Settings->General ->Touch Area Key -> Position -> Top , it works but not perfect you can't touch your right Side Of the Screen ,
Also I've Formatted My Unit Several Times and Updated system with several 2.9.5 Suppliers and noticed that the Touch area key part Saves its data every time it doesn't clear data when system formatted So My First Thought is this a MCU Related Problem although i Never Updated MCU in My Unit and My Second Thought is a Config. File For Touchscreen Can Solve the Problem
If You Navigate By a Rooted File Explorer To Internal Memory -> System -> Usr -> idc -> U Will Find a File ( ur Model-touchscreen.idc ) , May Be IT Could be replaced I'm Not Sure |
Parašytas: 2016 01 06, 20:35 |
Siunciausi ivairias kalibravimo programeles, bet jos arba visai nepasileisdavo arba pasileisdavo, raso kad vyksta kalibravimas, kalibravimas baigtas sekmingai, bet ekranas kaip buvo toks ir lieka |
Parašytas: 2016 01 09, 14:11 |
Radau sistemoje faila touchscreen.idc
Ji galiu atidaryti kaip teksta ir redaguoti. Jame surasyti diametrai, kalibracijos ir pan. Bet kaip pabandau suredaguoti, tai neleidzia issaugoti.
Gal padetu toks dalykas kaip Root? |
Parašytas: 2016 01 09, 14:37 |
Edgarasxxl rašo: |
taip, turedamas root teises galesi faila issaugoti. |
_________________ Skype: dmb-220 |
Parašytas: 2016 01 09, 14:39 |
Dekui, atsisuusiu baidu root'a, ir bandysiu, ziuresiu kas nors ar geres ekrano tikslumui ar ne |
Parašytas: 2016 01 09, 14:40 |
Edgarasxxl rašo: |
Parašytas: 2016 01 10, 15:41 |
Deja, atsisiunciau baidu root 2001, nurootinau, bet keist failo neleidzia visvien |
Parašytas: 2016 01 10, 15:59 |
per sena programa kad pavyktu padaryt root, net su naujausiom priemonem kartais nepavyksta, nes kurejai uzdeje apsaugas buna kad negautum root teisiu. pradzioje su Root Checker programa pasiziurek ar tikrai turi root teises?
su kokia programa bandai redaguoti faila? reik programos kuri galetu dirbti su root. root explorer ar pan naudok. standartines programos nesugeba issaugoti failu kurie apsaugoti. |
Parašytas: 2016 01 10, 22:31 |
Edgarasxxl rašo: |
Root checker parodys ar galiu isvis aparata nurootinti? |
NE, parodys ar pavyko nurootint telefona, sita programa rodo yra ar ne telefone ROOt teises, nes tu sakei kad jau nurotinai ir nepavyksta issaugoti failo, tai is pradziu siulau pasitikrinti ar istikruju pavyko gauti ROOT teise |
Parašytas: 2016 01 11, 12:10 |
O kokia jus rootinimo prigrama patartumet atsisiusti? nes tikrinau, tai nenurootintas mano androidas |
Parašytas: 2016 01 11, 18:25 |
king root ant pc yra ir ant telefono, rekomenduoju pc versija naudoti, telefone reik nustatyti: nustatymai -> kureju parinktys -> android derinimas (per pc su adb sasaja)
tada is pc galesi rootinti, bet nevisiems tinka, viena telefona pavyko, kitam ne, ir jokia programa nenurootino jo.
siaip reik ieskoti instrukciju kaip nurootinti pagal telefono modeli. |
Parašytas: 2016 01 13, 22:04 |
Norejau pakl, programa superSU, cia kiek supratau irgi rootina, ar kaip? |
FS 22 Tractors
Farming Simulator 19 Mods,
FS 22 Maps,
FS22 Mods |
FS22 Trucks |
VAT number check,
What is VAT,
How much is VAT |
Paskola internetu
Vartojimo paskola,
paskola automobiliui,
paskola būsto remontui |
Thermal monocular
Thermal vision camera,
Night vision ar scope,
Night vision spotting scope |
FS22 Mods
FS22 Harvesters,
FS22 Tractors Mods,
FS22 Maps Mods |
FS22 Mods
FS22 Harvesters,
FS22 Tractors |
Sims 4 Mods
Sims 4 CC Clothes,
Sims 4 Hair CC,
Sims 4 Skill Cheat |
Optic sight
Binoculars for hunting elk,
Best compact binoculars,
Riflescope hunting |
