Dabar yra 2026 06 26, 17:23. Visos datos yra GMT + 2 valandos.
Forumas » Autoelektronika » Skoda Fabia 2001 srs error 65535 ir kt.
Skoda Fabia 2001 srs error 65535 ir kt. |
Parašytas: 2013 06 14, 13:40 |
Pastovejo ir sumirgejo. Atsirado pora klaideliu, kuriu vag-com su kitaisku sniuru neima.SRS itampa gauna tokia kokia ant AKB. Skaitinejau kad SRS galima isvalyt su tokia muterka:http://www.ebay.com/itm/Audi-VW-Airbag-Reseter-VAG-Airbag-Reset-Tool-Top-Quality-Free-Shipping-/270992788620?pt=Motors_Automotive_Tools&hash=item3f186dcc8c&vxp=mtr, bet nesinori jos tik del vieno karto pirkt, gal yra kitu budu kos softas ar gal paskolint kas galetu.
Del klaidos 01317 - Control Module in Instrument Cluster (J285) nelabai ikertu kas ir kaip gal bus kokiu komentaru.
VAG-COM Version: Release 311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,76
Address 01 -------------------------------------------------------
Controller: 038 906 019 AF
Component: 1,9l R4 EDC 0000SG 1110
Coding: 00002
Shop #: WSC 13765
TMBMS26YX??????????? SKZ7Z0A0803709
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 D
Component: ABS/ASR 5.7 FRONT V00
Coding: 00188
Shop #: WSC 13765
Address 08 -------------------------------------------------------
Controller: 6Y0 820 045
Component: Klimaanlage X0760
1 Fault Found:
79-00 - Please Check Fault Codes
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 09394
Shop #: WSC 13765
Address 15 -------------------------------------------------------
Controller: 6Q0 909 605 H
Component: 08 AIRBAG VW5 08 0006
Coding: 12344
Shop #: WSC 13765
3 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 17 -------------------------------------------------------
Controller: 6Y1 919 870 D
Component: KOMBIINSTRUMENT VDO V08
Coding: 22141
Shop #: WSC 20055
TMBMS26YX?????????????? SKZ7Z0A0803709
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S30
Coding: 00014
Shop #: WSC 13765
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 00110
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 C
Component: 07 Komfortgerát 0003
Coding: 00259
Shop #: WSC 13765
End ------------------------------------------------------- |
Parašytas: 2013 06 15, 22:22 |
| 65535 su sia klaida tai kaip dievulis duos, arba bus gerai, arba tuoj vel islys, arba is kart bus blogai, kartais ir bloka del jos keist tenka. |
Parašytas: 2013 06 15, 23:44 |
| Citata: |
| Del klaidos 01317 - Control Module in Instrument Cluster (J285) nelabai ikertu kas ir kaip gal bus kokiu komentaru. |
Galėtų būti: valdymo modulis prietaisų skydelyje (kas su juo nežinau, bet reikia tikrinti).
Visos kitos parodytos klaidos: tiesiog reikia bandyti paeiliui (ar pagal kitą tvarką) jas šalinti.
Taip pat manau, jog klaidų išvalymas saviapgaulė: jeigu gedimai nebus pašalinti, jos vėl atsiras. Ir tai yra visiškai normalu.
O šiaip, tai atsiverti to VAG'o pagalbą, ir randi visų klaidų kodų išaiškinimus. |
Parašytas: 2013 06 16, 00:16 |
tas sniurelis turi padaryt. kiek darau crash'u vagen'am-nei karto nepavede, tik ne viska per obd daro, kartais tenka bloka ant stalo pasijungt ir tiesiogiai sujungti ''sniurelio'' ir bloko k line'us ir isvalyti speju be jo neapsieisi, nebent turi ir moki naudotis programatorium, turerai rast motorola. |
Parašytas: 2013 06 17, 08:57 |
su sia klaida tik ant stalo su programatoriumi. Jai turi su kuo nuskaityti ir zinai kaip istrinti, tai imanoma padaryti. Ten stovi MC68HC908AZ32 arba MC68HC908AZ60A ir dar gali buti rakinta, priklausomai nuo maskes |
Parašytas: 2013 06 17, 17:19 |
SRS pinoutas jei kam prireiks:
Pinouts ECU:
K-line = pin 54 (connected with car OBDII connectorpin 7),
GND = pin 51,
+12V= pin 26,
Bandysiu ant stalo priskerst pradziai su kline, o po to ziuresim kas toliau... Su VAG'o pagalba susipazines, bet remiantis ja tikrini viska is eiles ir jei pasiseks rasti adata kupetoj tai beda dings... Mano kl. ar nebus susije 01317 su srs problemom nes pasak to vag helpo wikirosinio "Instrument Cluster (J285) stored a Code which influences other Control Modules Functionality". Palauksiu gal kas Skoda Fabia jau bus ciupinejes su panasiais simptomais. |
Parašytas: 2013 07 11, 12:24 |
| Po ilgų bandymų prikelti viskas baigsis kito SRS modulio dėjimu. Gal yra numanančių koks yra suderinamumas tarp modulių su skirtingais indexais ir paskutinės modulio numerio raidės (trumpiau tariant ka reiskia raide ir ka indexas)? Kiek suprantu indeksas nusako masinos komplektacija t.y. kiek pagalviu. Jei indeksas skiriasi ar imanoma naudota airbag perdumpint, kad butu panaudoti visi bagai? |
Parašytas: 2013 07 11, 23:15 |
| Hames rašo: |
siuliau "vienos knopkes" sprendima uz varganus 50lt, o tamsta norejo kaip geriau, bet gavosi kaip visada  |
Parašytas: 2013 07 11, 23:26 |
| solitaire rašo: |
| Hames rašo: |
va pasakyk kad 4B0959655G (a6/c5 vidui cr16) uztenka vieno knopkes paspaudimo |
Parašytas: 2013 07 11, 23:49 |
| cia ,mazai situ ubagisku cru 16tu ejo. kiek dariau su tuo knopkiniu eraseriu tai buvo keli kuriems keiciau srs bloka. o taip tai veju ;-0 beja turiu juos net 2 ;D gal kam reikia? |
Parašytas: 2013 07 12, 08:03 |
| vaidass rašo: |
| solitaire rašo: |
| Hames rašo: |
prie ko cia 4B0959655G? pas temos autoriu 6Q0909605H ant 68HC908AZ32. |
Parašytas: 2013 07 12, 14:11 |
| kad tas vienos knopkes paspaudimo variantas nepadejo, radau as ji VLN ir po jo uzgeso ir iskart vel oplia "as cia" ir vidus liko tas pats tie patys 65535 ir dar kokie ten buvo... pas kelis vln elektrikus buvau sak kad reik keist proca ir pan, tai daba radau kita su tuo paciu kodu moduli tik indexas kitas gal kas apsiimtu persiut vidurius? |
Parašytas: 2013 07 12, 20:48 |
| Hames rašo: |
tai tamsta gal per obd fyske jungei gal?ar ant stalo? man per obd irgi nesigavo,pagal aprasyma dar net skyda tipo rekomenduoja atjungti,bandziau bet nulis emociju pajungus viska ant stalo,k-line tiesiai is reseterio i bloka-crash'as issitryne.Kiek bandes problemu nebuvo.kazko nemokejot ar nedadare  |
Parašytas: 2013 07 15, 10:35 |
Dekui Solitaire ir kitiems, muterka visgi suveike ant stalo, kadangi kaip ir neturiu aš jos, o teko nulekt pas vieną diadia Vasia, kuris įgrudo į diagnostikos jungti paminkė, bet be rezultato...(error) Po pokalbio su solitaire pasiskolinau už užstatą dviejų knopkių technikos stebuklą, išsitraukiau ant stalo SRS ir ka.. po kokiu 15s mirksejimo busy ar kokia ten oranžinė lempute užsidegė žalia lempa. Ingrūdau atgal SRS į automobilį ir oplia kaip nauja Dar prieš tai bandžiau visaip skydeli prievartaut ir viena jungti atjungus ir abi niekaip nenorėjo bendraut su srs'u. Ant stalo be jokių spardymūsi atsidavė Case is closed. Solitaire, kai busi VLN pranešk, bonka jau paruošęs  |
GTA 6 Map,
GTA 6 Vehicles,
GTA 6 Character |
