Dabar yra 2026 06 12, 15:17. Visos datos yra GMT + 2 valandos.
 Forumas » Elektronika žaliems » OneWire protokolas
 OneWire protokolas
PranešimasParašytas: 2013 05 28, 20:45 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ToTa
Sveiki, gal galit kas nors padet issiaiskint viena kodo vieta? bandau issiaiskint bet niekaip nesigauna. kodas standartinis DS18B20 jutikliui pajunkti is mikroC.
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
// Set TEMP_RESOLUTION to the corresponding resolution of used DS18x20 sensor:
// 18S20: 9 (default setting; can be 9,10,11,or 12)
// 18B20: 12
const unsigned short TEMP_RESOLUTION = 9;
char *text = "000.0000";
unsigned temp;
void Display_Temperature(unsigned int temp2write) {
const unsigned short RES_SHIFT = TEMP_RESOLUTION - 8;
char temp_whole;
unsigned int temp_fraction;
// Check if temperature is negative
if (temp2write & 0x8000) {
text[0] = '-';
temp2write = ~temp2write + 1;
// Extract temp_whole
temp_whole = temp2write >> RES_SHIFT ;
// Convert temp_whole to characters
if (temp_whole/100)
text[0] = temp_whole/100 + 48;
else
text[0] = '0';
text[1] = (temp_whole/10)%10 + 48; // Extract tens digit
text[2] = temp_whole%10 + 48; // Extract ones digit
// Extract temp_fraction and convert it to unsigned int
temp_fraction = temp2write << (4-RES_SHIFT);
temp_fraction &= 0x000F;
temp_fraction *= 625;
// Convert temp_fraction to characters
text[4] = temp_fraction/1000 + 48; // Extract thousands digit
text[5] = (temp_fraction/100)%10 + 48; // Extract hundreds digit
text[6] = (temp_fraction/10)%10 + 48; // Extract tens digit
text[7] = temp_fraction%10 + 48; // Extract ones digit
// Print temperature on LCD
Lcd_Out(2, 5, text);
void main() {
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
C1ON_bit = 0; // Disable comparators
C2ON_bit = 0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Lcd_Out(1, 1, " Temperature: ");
// Print degree character, 'C' for Centigrades
Lcd_Chr(2,13,223); // Different LCD displays have different char code for degree
// If you see greek alpha letter try typing 178 instead of 223
Lcd_Chr(2,14,'C');
//--- Main loop
do {
//--- Perform temperature reading
Ow_Reset(&PORTE, 2); // Onewire reset signal
Ow_Write(&PORTE, 2, 0xCC); // Issue command SKIP_ROM
Ow_Write(&PORTE, 2, 0x44); // Issue command CONVERT_T
Delay_us(120);
Ow_Write(&PORTE, 2, 0xBE); // Issue command READ_SCRATCHPAD
temp = Ow_Read(&PORTE, 2);
temp = (Ow_Read(&PORTE, 2) << Cool + temp;
//--- Format and display result on Lcd
Display_Temperature(temp);
Delay_ms(500);
} while (1);
O neaiski vieta yra kodel kai extraktina skaitmenis isvedimui prideda 48?
pvz cia :
tarkim temperatura 23C
text1 bus lygus 23/10=2; 2%10=2; 2+48=50; nors realiai pirmas skaicius turi buti 2;
text2 lygus 23%10=3; 3+48=51, nors realiai turi buti 3;
Tai kaip cia su tuo 48, ar as gal ne taip skaiciuoju?
 OneWire protokolas
PranešimasParašytas: 2013 05 28, 22:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Katushke
Pasidomėk ASCII lentele. 48 atitinka '0' simbolį. Taigi jei prie 48 pridėsim tarkim 2, tai gausim '2' char tipo kintamąjį.
 OneWire protokolas
PranešimasParašytas: 2013 05 28, 23:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ToTa
Aciu!
