Dabar yra 2026 05 06, 08:38. Visos datos yra GMT + 2 valandos.
Forumas » Autotiuningas » Cosworth 24V kompo apgavimas
Cosworth 24V kompo apgavimas |
Parašytas: 2013 04 25, 17:19 |
Sveiki gal galit padet su vertimu i lietuviu/rusu kalba nes anglu galima sakyt nelabai kertu. Tikslas apgauti kompa jog stovi automatine deze, nes reikia isideti mechanine. Verteja jau ne viena bandziau tai po ju isvis nieko nebesupratau.
Now for the hardest bit, the wiring, as I was doing a straight swap auto to manual I had the auto box to take apart and pinch some parts out of for measurement and in the case of the EPC solenoid wiring back into the system
On the auto box range selector switch you will have a row of 4 wires in a line and a row with 2 in the middle
The row with 4 wires, the outer 2 are the start inhibit, just chop and join these two together, the middle 2 wires are the reverse switch connection
The row with 2 wires is the engine control, my wire colours were Brown/yellow and white/black, this needs a resistance of 737R between it (simulating the neutral position in the range switch)
So
Start - 0
Rev - 0 - 0 - eng
Rev - 0 - 0 - eng --- range selector plug
Start - 0
Now you have to sort the solenoid plug which is the square shaped one
This one is a little tricky but if you hold the plug so that the catch part is on the right pin one is bottom right and pin 16 top left
Pin 16
V
0 0 0 0 pin 4
0 0 0 0
0 0 0 0 catch side
0 0 0 0 pin 1
pin 13
Right then
EPC (use the solenoid out the box or a power relay) uses pins 11 and 12
Temp pins 4 and 8 - use a resistor cant remember the value of hand but I think it was around 4 K ohms
Lock up pins 1 and 5 again use a resistor 8.7 Ohm
Then the shift sols
Pins 7 , 9 , 14, 16 are the one side of the relays (use the Yellow ones out the fuse box) and pin 10 is the common
That the main lot sorted
tekstas is http://www.fordscorpio.co.uk/cgi-bin/yabb/YaBB.pl?board=admin;action=display;num=1285441192
Visko verst neprasau tik pati procesa |
Parašytas: 2013 04 26, 22:15 |
| Duomenu to automobilio biski imesk, ir siaip parasyk ko is jo nori. Kiek suprantu cia apie TA kalbos nebus, starteri dasijungsi. Cia parasyta kokius laidus trumpint, kokias varzas det- starteris kad suktu, atbulinis kad veiktu...Siaip visa kita irgi gali but nelabai tau reikalinga- koks apsuku sukelimas, dar kazkas. |
Parašytas: 2013 04 27, 20:54 |
| tikslas isimest varikli i sierra, o kadangi automatas man nepatinka ir begalo dievinu saviskes sierros N9 mechanine deze noris ja ir isidet, variklis is scorpio v6 24v 152kw, starteris ir taip suks, tiesiog fordo EEC-V kompas neduos pajudet is vietos kol neatras is automatines dezes davikliu arba emuliatoriu |
Parašytas: 2013 04 28, 21:57 |
o ecu nuo mechano neturi?
nzn kaip kitu bet asmeniskai esu dares hondos ecu obd1 tai pora varzu ir peremiciuku idet isimt reikejo ir ciki
Parašytas: 2013 04 29, 08:33 |
| Cosworth su mechanika buvo tik keliatas egzemplioriu, aisku galima paimt ecu nuo senesnio BOA variklio bet ji rast sunku ir kainuoja kaip tas variklis |
