Dabar yra 2026 05 01, 17:33. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » Help del UART
 Help del UART
PranešimasParašytas: 2006 03 07, 19:05 Pranešti apie taisyklių pažeidimą Atsakyti su citata
oxegen
Tai va kol buvau uzsiemes kitais reikalais pasibaige ir ta 30dienu IAR programaij.... Jei kas turit normaliai veikiancia, dar karta labai prasau atsiuskite man
oxegensytes@gmal.com
Instaliavausi ir "nusipirkau" licenzija CodeVisionAVR programaij... bet idejus koda pagal elektronikoj duota pvz.: http://elektronika.lt/schematic/theme/67/593/
taij neveikia meta klaidas. Jeigu nusciacius ir leidus minimaliai padaryti savo koda siai programaij toki :
#include <90s2313.h>
#define RXB8 1
#define TXB8 0
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// UART Receiver buffer
#define RX_BUFFER_SIZE 8
char rx_buffer[RX_BUFFER_SIZE];
#if RX_BUFFER_SIZE<256
unsigned char rx_wr_index,rx_rd_index,rx_counter;
#else
unsigned int rx_wr_index,rx_rd_index,rx_counter;
#endif
// This flag is set on UART Receiver buffer overflow
bit rx_buffer_overflow;
// UART Receiver interrupt service routine
interrupt [UART_RXC] void uart_rx_isr(void)
char status,data;
status=USR;
data=UDR;
if ((status & (FRAMING_ERROR | DATA_OVERRUN))==0)
rx_buffer[rx_wr_index]=data;
if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
if (++rx_counter == RX_BUFFER_SIZE)
rx_counter=0;
rx_buffer_overflow=1;
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the UART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index];
if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#asm("cli")
--rx_counter;
#asm("sei")
return data;
#pragma used-
#endif
// UART Transmitter buffer
#define TX_BUFFER_SIZE 8
char tx_buffer[TX_BUFFER_SIZE];
#if TX_BUFFER_SIZE<256
unsigned char tx_wr_index,tx_rd_index,tx_counter;
#else
unsigned int tx_wr_index,tx_rd_index,tx_counter;
#endif
// UART Transmitter interrupt service routine
interrupt [UART_TXC] void uart_tx_isr(void)
if (tx_counter)
--tx_counter;
UDR=tx_buffer[tx_rd_index];
if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
// Write a character to the UART Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter == TX_BUFFER_SIZE);
#asm("cli")
if (tx_counter || ((USR & DATA_REGISTER_EMPTY)==0))
tx_buffer[tx_wr_index]=c;
if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
++tx_counter;
else
UDR=c;
#asm("sei")
#pragma used-
#endif
// Standard Input/Output functions
#include <stdio.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port D initialization
// Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=In Func0=In
// State6=0 State5=0 State4=0 State3=0 State2=0 State1=T State0=T
PORTD=0x00;
DDRD=0x7C;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1 output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1H=0x00;
OCR1L=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
GIMSK=0x00;
MCUCR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// UART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// UART Receiver: On
// UART Transmitter: On
// UART Baud rate: 9600
UCR=0xD8;
UBRR=0x33;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
// Global enable interrupts
#asm("sei")
while (1)
// Place your code here
taij nelabai veikia padavus koda i " // Place your code here" vieta....
Tat kuris tas tikras kintamasis sioje programoje yra duomenu mainams per UART <<<putchar(c)>>
Jei imetu kazkoki taij duomenys i C man neismeta per terminala..... Kaip koda susitvarkyt kad bent pradziai pagal elektronikos puslapi atliktu tokius veiksmus su duomenu perdavimu per terminala.....
