Dabar yra 2026 06 17, 20:11. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » Arduino pagalba
 Arduino pagalba
PranešimasParašytas: 2013 03 22, 09:41 Pranešti apie taisyklių pažeidimą Atsakyti su citata
korne1
Sveiki forumiečiai,
Reikalinga pagalba arduino srityje. Niekaip negaliu padaryti, kad per menu galėčiau nustatyti katilo cirkuliacinio siurblio įsijungimą pagal nustatyta temperatūra.
Mano kodas:
#include <LiquidCrystal.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <EEPROM.h>
#define ONE_WIRE_BUS 2 // DS18B20 to D2 pin
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int Backlight =10; // lcd backlight to D10 pin
DeviceAddress Katilas = { 0x28, 0xBF, 0x84, 0x3E, 0x03, 0x00, 0x00, 0x50 };
DeviceAddress Boileris = { 0x28, 0xD0, 0x48, 0x3E, 0x03, 0x00, 0x00, 0xB4 };
// define some values used by the panel and buttons
#define btnRIGHT 4
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 5
#define btnNONE 0
float set=20.0;
int motor =12;
int keyPressed;
int adc_key_in = 0; //variable to store raw data from keypad
boolean menu_timer; //variable to test if menu timeout has completed
int read_Key_Pressed()
{ delay (200);
adc_key_in = analogRead(0);
//delay (200);
// read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 195) return btnUP;
if (adc_key_in < 380) return btnDOWN;
if (adc_key_in < 555) return btnLEFT;
if (adc_key_in < 790) return btnSELECT;
return btnNONE; // when all others fail, return this...
void setup()
pinMode(Backlight, OUTPUT); //lcd LED kaip isejimas
analogWrite(Backlight, 125);
pinMode(motor,OUTPUT);
lcd.begin(16, 2); // start the library
lcd.begin(16,2);
lcd.print("Termometras v1.0");
lcd.setCursor(4,1);
lcd.print("2013");
delay(2000);// print title msg and pause for 2secs
lcd.clear();
main_routine();
void main_routine()
{ keyPressed == 0; //reset key to none
dispDefaultScreen();
keyPressed = read_Key_Pressed(); //scan for key press
//delay(100);
if (keyPressed == 5) //if a key is pressed
lcd.clear();
lcd.setCursor(2,0);
lcd.print("Temperatura");
lcd.setCursor(6,1);
lcd.print(set);
if (keyPressed == 4)
set=set+1;
if(keyPressed == 3)
set=set-1;
else main_routine(); //else loop back to top function
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00)
lcd.print("klaida");
} else {
lcd.print(tempC);
void loop() //nothing in here
if(sensors.getTempC(Katilas)>set)
digitalWrite(motor,HIGH);
else if(sensors.getTempC(Katilas)<set)
digitalWrite(motor,LOW);
void dispDefaultScreen()
sensors.requestTemperatures();
lcd.setCursor(0,0);
lcd.print("Katilas ");
printTemperature(Katilas);
lcd.write(0b11011111); //laipsnio simbolis
lcd.print("C"); // celsijaus simbolis
lcd.setCursor(0,1);
lcd.print("Boileris ");
printTemperature(Boileris);
lcd.print("C");
 Arduino pagalba
PranešimasParašytas: 2013 03 22, 22:57 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vintikas
nu as nesu specas c# programavime,bet manau truksta sito
main_routine();
while (key!=5)
// darai ka nori kol nebus key==5
 Arduino pagalba
PranešimasParašytas: 2013 03 23, 10:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
korne1
Pagal tavo pasiūlyta varijanta nepadėjo.
 Arduino pagalba
PranešimasParašytas: 2013 03 23, 17:09 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vintikas
o tavo kodas isvis veikia? bentjau temperatura rodo.
Nu nesvarbu. neturiu po ranka ds1820.rytoj pabandysiu
 Arduino pagalba
PranešimasParašytas: 2013 03 24, 11:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
korne1
Termometras veikia puikiai tik su nustatymais niekaip nesusitvarkau.
 Arduino pagalba
PranešimasParašytas: 2013 06 20, 14:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Djsoldiers
Ar esat kasnors bvandes su arduino irasyti/nuskaityti duomenis is kasetes (senos muzikos kasetes).
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 10:03 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vintikas
Djsoldiers rašo:
O kam to reikia?. Arduino dirba su SD kortom.
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 10:24 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Valdulis
Vintikas rašo:
Djsoldiers rašo:
Ar esat kasnors bandes su arduino irasyti/nuskaityti duomenis is kasetes (senos muzikos kasetes).
Ne, nu, blyn... Klausia apie Joną, o atsako – apie sijoną... Very Happy
Gal Tau ir nežinoma, tačiau, be muzikos, tokiose kasetėse praeitame tūkstantmetyje buvo įrašinėjami ir duomenys... Nesakau, kad būtent to (Sinclair ZX Spectrum duomenų) klausėjui reikia, bet – ką gali žinoti?! Confused
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 12:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
I kasete irasyti kaip tris pirstus apmyzt, is kasetes nuskaityti irgi netrabliema, galima ir issifruoti, tik laiko reikia, jei formatas neaiskus.
Bet jei programos autorius nesupranta kam Arduino turi loop() ir kilpuoja rekursija, tai kada jis ismoks atlikti elementarius dalykus ?
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 17:29 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vintikas
Valdulis rašo:
Vintikas rašo:
Djsoldiers rašo:
Koks tu blin protingas. aciu kad apsvietei.
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 17:40 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Valdulis
Vintikas rašo:
aciu kad apsvietei.
Aš Tave nesvieteu, o apšviečiau.
Mokykis, ir Tu būsi protingas. Very Happy
 Arduino pagalba
PranešimasParašytas: 2013 06 23, 23:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Djsoldiers
AlgisL rašo:
O kaip siulitum jungti ?
 Arduino pagalba
PranešimasParašytas: 2013 06 24, 13:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
AlgisL
djsolder, ka jungti ?
jei mage prie arduino - tai per RCRC filtra/dalikli i mages IN bus isvedimas, o iejime vel RCRC filtras + operacinukas arba BC850C vietoje operacinuko.
OnChange pertrauktyje ivertini micros(), isvedant delayMicroseconds();
nepatikrintas pavyzdys, bet gal suveiks ir is 1 karto
Kodas:
enum {NO_OP = 1, GET_SYNC0, GET_SYNCA, GET_LEN, WAIT_BYTE, BYTE_IN};
unsigned char lineInStatus = NO_OP;
unsigned char lineInChCnt = 0;
unsigned char lineInData;
unsigned char lineInBits;
unsigned int lineInSyncs;
#define lineIn 3  // INT1
#define lineOut 4
void lineOutByte(char data){
    for(char b=0x80; b; b>>=1){
        digitalWrite(lineOut, !digitalRead(lineOut));
        delayMicroseconds(500);
        if(b & data) digitalWrite(lineOut, !digitalRead(lineOut));
void lineOutBlock(char *buffer, unsigned int count){
char checkSum=0;
    for(char t=1000/8; --t;) lineOutByte(0);
    for(char t=10; --t;) lineOutByte(0xAA);
    lineOutByte(count >> 8);
    lineOutByte(count & 0xFF);
    for(; count; buffer++, count--){
         lineOutByte(*buffer);
         checkSum ^= *buffer;
    lineOutByte(checkSum);
void lineInChange(){
static unsigned long time;
   if(lineInStatus == NO_OP) return;
unsigned long t = micros();
long changeDelay = t - time;
    time = t;
    if((changeDelay > 1500) || (changeDelay < 250)){
        if(lineInStatus != GET_SYNC0) lineInStatus = NO_OP;
        return;
    if(lineInChCnt == 0) lineInData <<= 1;
    if(changeDelay > 750){
        if(lineInChCnt == 1){
            return;
       if(lineInBits < 255) lineInBits++;
    }else
        if(++lineInChCnt > 1){
            lineInChCnt = 0;
            lineInData++;
    if(lineInBits >= 8){
        if(lineInStatus == GET_SYNC0){
            if(lineInData == 0xAA){
                lineInBits = 0;
                if(lineInSyncs >= 1000/8/2){
                    lineInStatus = GET_SYNCA;
                    lineInSyncs = 0;
                }else{
                    return;
            else{
               if(lineInData == 0) lineInSyncs++;
               else lineInSyncs = 0;
               return;
        if(lineInStatus == GET_SYNCA){
            if(lineInData != 0xAA){
                return;
            if(++lineInSyncs >= 10){
                lineInStatus = GET_LEN;
                lineInBits = 0;
                return;
        lineInStatus == BYTE_IN;
        lineInBits = 0;
int lineInBlock(char *buffer, unsigned int bufSize){
unsigned int count, bytesRead=0;
char checkSum=0;
    lineInChCnt = 0;
    lineInSyncs = 0;
    lineInStatus = GET_SYNC0;
    while(lineInStatus != GET_SYNCA)
        if(lineInStatus == NO_OP) return 0;
    while(lineInStatus == GET_SYNCA)
    count = lineInData << 8;
    while(lineInStatus == GET_LEN)
    count += lineInData;
    if(count > bufSize) return 0;
    while(bytesRead < count){
        lineInStatus = WAIT_BYTE;
        while(lineInStatus != WAIT_BYTE);
        checkSum ^= lineInData;
        buffer[bytesRead] = lineInData;
        bytesRead++;
    if(lineInStatus != BYTE_IN){
         return 0;
    if(checkSum != lineInData) return 0;
        else return bytesRead;
void setup(){
     pinMode(lineOut, OUTPUT);
     attachInterrupt(1, lineInChange, CHANGE);
void loop(){
char buffer[100];
   lineOutBlock(buffer, 100);
int bytesRead = lineInBlock(buffer, 100);
