Dabar yra 2024 04 25, 09:06. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » Autocom'as
Autocom'as |
Parašytas: 2016 09 29, 19:03 |
mes už jus instrukcijos neperskaitysim |
Autocom'as |
Parašytas: 2016 09 29, 19:10 |
Autocom Delphi Software 2013.02 Activate Instruction
Step 1: Before install the new version 2013.R2 Autocom / Delphi software, you need uninstall previous versions
Delete the following folders:
WINDOWS XP:
C:ProgramsAutocom
C:ProgramsDelphi
C:Documents and SettingsAll UsersApplication DataAutocom
C:Documents and SettingsAll UsersApplication DataDelphi
C:Documents and Settings**USER**Application DataAutocom
C:Documents and Settings**USER**Application DataDelphi
C:Documents and Settings**USER**Application DataMicrosoftSystemCertificatesMy
C:Documents and SettingsDefault UserApplication DataMicrosoftSystemCertificatesMy
C:Documents and SettingsLocalServiceApplication DataMicrosoftSystemCertificatesMy
C:Documents and SettingsNetworkServiceApplication DataMicrosoftSystemCertificatesMy
WINDOWS 7 & 8:
C:Programsx86Autocom
C:Programsx86Delphi
C:users**USER**AppDataRoamingDelphi
C:users**USER**AppDataRoamingAutocom
C:users**USER**AppDataRoamingMicrosoftSystemCertificatesMy
OTHER OS:
Look similar folders.
Edit with Notepad:
C:WINDOWSsystem32driversetchosts
and delete:
127.0.0.1 activation.autocom.se
127.0.0.1 activation2.autocom.se
127.0.0.1 updates.autocom.se
Run CCleaner and clean the registry
Restart your computer
Step 2: Turn off all internet and wi-fi on your pc before installing 2013 Release 2 Autocom / Delphi software
Step 3: Install Autocom/Delphi 2013 R2 (2.13.2)
Step 4: Installing update1 programmer to install folder
Step 5: Install Patch to the Autocom folder(notice: need cover old file, pls consult "how to install release 3 autocom delphi software")
Step 6: Start Autocom/Delphi and fill in required ID, Hardware Code & serial (using Delphi Autocom keygen for 2013.2 )
Step 7: Click next and it will activate automatically success
Step 8: must to: Restart The Computer firstly
Step 9. Connect your Delphi DS150E VCI unit to computer then connect to CAR (OBD 2 plug)
Step 10: Start to test your VCI unit & UPDATE the firmware without INTERNET!
Step 11: Try directly to select your vehicle and make Diagnosis by autocom cdp plus or Bluetooth Delphi DS150E VCI |
Autocom'as |
Parašytas: 2016 11 02, 11:58 |
Kur autocom pirkai? Gal "modifikuota" Kai kurie auksarankiai megsta pakeisti serijinius numerius kad be ju niekas daugiau autocomo neinstaliuotų. O už intaliavimą papildomai ima. Šiaip kai jau viskas instaliuota ir reikia tik serijini kita . Tai eini help ir add new VCI ar kažkaip panašiai bus, tada galesi kita serijini suvesti aišku jei žinai koks jis. |
Autocom'as |
Parašytas: 2016 11 02, 13:30 |
Anthony rašo: |
aiik jau-gyveni vakarykste diena... |
Autocom'as |
Parašytas: 2016 11 12, 00:17 |
Anthony rašo: |
Buvo tik vienas toks auksarankis ALEKSANDRAS Pūdrindavo žmonėms smegenis, kad skrenda į KINIJĄ ir pats renkasi ten tuos atocomus ar panašiai Po to modifikuoja.. Tai tas modifikavimas ir buvo serjinio nr pakeitimas - darbas 2 minutes.. Nauda nulinė. Svarbiausia, jog daugelis juo tikėdavo, galvodavo kad perka tikrai rimtą daiktą. |
Autocom'as |
Parašytas: 2016 11 14, 19:49 |
Aš dar ir dabar gaunu bent vieną skambutį į savaitę ar turiu modifikuotą variantą.. ) Aleksandro palikimas šliaužia. |
Autocom'as |
Parašytas: 2016 11 21, 13:57 |
Sveiki, norejau pasidometi kuom skiriasi autocom nuo delphi? Kiek skaiciau tai jie vienodi tipo. Jusu nuomone, kuri geriau pasiimti? |
Autocom'as |
Parašytas: 2016 11 26, 10:47 |
Ar Delphi programa gali pati,neprasoma,updatintis? Kitaip tariant,ar naudojate interneta tame paciame kompiuteryje su sia programa? Dar kazkur skaiciau apie kitas programas siam adapteriui - Wurth (ar Wow) .Kuo jos skiriasi? Kuri geresne? Aciu is anksto |
Autocom'as |
Parašytas: 2016 11 29, 20:27 |
JustasKLP rašo: |
Vienodi, skiriasi tik case. Tad imk kurio išvaizda gražesnė |
Autocom'as |
Parašytas: 2016 11 29, 20:30 |
art64 rašo: |
Kiek žinau tai naujinasi - updaitinasi tik jei yra paleidžiama esant ijungtam internetui t.y. interneto prieigai. Galima pervadinti wyupdate is autocom ar delphi direktorijos, tada nesinaujina. |
autocom 2.14.2 aktyvavimas |
Parašytas: 2016 12 22, 16:40 |
sveiki nustojo veikti kiniskas autocom praso atnuajinimo visada naudojau be interneto. gal gali kaskuo patart ka daryt? |
Autocom'as |
Parašytas: 2016 12 22, 17:19 |
perinstaliuok is naujo softa.jeigu sviesos diodai sviecia raudonai(cdp+ versija) atnaujink firmware per settingus.
neparasei nei koks skaneris,nei kokia programa naudoji nei kokie pozymiai kad neveikia.gal laidas nutruko... |
_________________ +37068705542-Romas PRS... |
Autocom'as |
Parašytas: 2016 12 22, 17:35 |
Kybertarakonas rašo: |
nu supranti user'iui tiesiog neveikia, ir viskas, o kas kaip reikia burti iš krištolinio rutulio. |
Autocom'as |
Parašytas: 2016 12 22, 19:00 |
tomaxsas rašo: |
na tokiems atvejams yra manau tinkamesniu forumu kur renkasi raganos ekstrasensai ir tt.
arba teks keisti klausima i - gal kas suremontuotu... |
FS 22 Tractors
Farming Simulator 19 Mods,
FS 22 Maps,
FS22 Mods |
FS22 Trucks |
VAT number check,
What is VAT,
How much is VAT |
Paskola internetu
Vartojimo paskola,
paskola automobiliui,
paskola būsto remontui |
Thermal monocular
Thermal vision camera,
Night vision ar scope,
Night vision spotting scope |
FS22 Mods
FS22 Harvesters,
FS22 Tractors Mods,
FS22 Maps Mods |
FS22 Mods
FS22 Harvesters,
FS22 Tractors |
Sims 4 Mods
Sims 4 CC Clothes,
Sims 4 Hair CC,
Sims 4 Skill Cheat |
Optic sight
Binoculars for hunting elk,
Best compact binoculars,
Riflescope hunting |
