Dabar yra 2026 06 13, 07:08. Visos datos yra GMT + 2 valandos.
 Forumas » Autodiagnostika » Astra H 2006m. 1,7dyzelis
PranešimasParašytas: 2012 12 23, 15:46 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
Gal kas turejo reikalu- masina salta kuriasi, pravazinejus apie 2valandas-uzsidega krovimas check, ABS, uzgesinus nebesiveda, nebegali prisijungt kompo prie motoro, abs ir kur eina diagnostika per HS...Logiskai mastant beda kaip ir radau- keista vairo kolonke, laidai nebuvo gerai prisegti-nudribo ant duslintuvo-pradege laidai....BET!!! Uz kazkur uz 2valandu masina atvaziavo vel....Aisku prisijungt neina, bet kita diena viskas OK-vedasi, vaziuoja. Nuskaiciau klaidas-OP-COM 100219a - PC based diagnostic tool
hkj
OP-COM - CAN Communication Window> 2006 (6)|Astra-H|Body|CIM (Steering Column Module)
Read Info...
Identifier: 0x0109
VIN: W0L0AHL3552078983
Hardware number:13197719
System name: VALEO A3300 CIM
Part Number:13197719
Software version number: M:80.42 S:00.00
Programming Date: FFFFFFFF
Hardware key number: 54FKPG
System description: VALEO0400
Alpha code: ’’’
Manufacturing date: 20041129
Code Index and version: ’’’ ’’
Total number of fault codes: 4
U2100 - No Communication with CAN-Bus (High Speed)
(00) - Not present
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
(00) - Not present
U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
(00) - Not present
U2111 - CAN-Bus No Communication with EPS (Electrical Power Steering)
(00) - Not present
Identifier: 0x0109
Alpha code: ’’’
(00) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
hkj
OP-COM - CAN Communication Window> 2006 (6)|Astra-H|Body|IPC ECU (Instrument Control Unit)
Read Info...
Identifier: 0x1000
System name: BCM/KOMBI-A3300
Part Number:13172012
Software version number: 4.405 11/04
Programming Date: 00000000
Hardware key number: 0000000000
System description: SIEM 0400
Alpha code: RC
Software Freeze Date: 10.03.200
Code Index and version: 001 05
Total number of fault codes: 6
P0500 - Wheel Speed Sensor Circuit Range/Performance
(71) - Not present
P0654 - Engine Speed Signal Range/Performance
(71) - Not present
P0550 - Mileage Circuit Range/Performance
(71) - Not present
P0460 - Fuel Level Sensor Circuit Range/Performance
(71) - Not present
P0115 - Engine Coolant Temperature Signal Range/Performance
(71) - Not present
U2139 - Invalid Signal from CIM (Steering Column Module)
(71) - Not present
hkj
OP-COM - CAN Communication Window> 2006 (6)|Astra-H|Chassis|ABS/TC/ESP ECU (Electronic Control Unit)
Read Info...
Identifier: 0x0401
Hardware number:17003000
System name: ABS MK70
Part Number:13157575
Software version number: D2_REM00047
System description: TEVES0300
Alpha code:
Manufacturing date: 20041110
Software Freeze Date: 05.09.2003
ECU variant coding: 0x00006241
C0241 - Engine Torque Request Signal Range/Performance
(71) - Not present
(00) - Not present
(00) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
OP-COM - CAN Communication Window> 2006 (6)|Astra-H|Chassis|EHPS (Electrohydraulic Power Steering)
Read Info...
Identifier: 0x0203
System name: EHPS EP2 ZFLS
Part Number:13192897
Software version number: 7625379110 P526
Programming Date: 20202020
System description: ZFLS 0011
Alpha code: JV
Manufacturing date: 00000000
Code Index and version: 001 01
U2105 - CAN-Bus no Communication with ECM (Engine Control Module)
(00) - Not present
U2105 - CAN-Bus CIM Message Range/Performance
(70) - Not present
(00) - Not present
(00) - Not present
hkj
OP-COM - CAN Communication Window> 2006 (6)|Astra-H|Engine|Z 17 DTH
Read Info...
Identifier: 0x0705
Hardware number:81011943
Motor type: Z17DTH
Part Number:55556829
Software version number: P368_I63DT
Hardware manufacturer number: 0281011943
Software Number: 1037372298P368_I63
Hardware key number: ’’’’’’’’’’
System description: BOSCH0100
Type approval number: B04015
Variant programming: 0x00000002
Alpha code: ZH
Hardware manufacturer system name: EDC16
ECU variant coding: 0x000010E5
Total number of fault codes: 10
P0070 - Ambient Air Temperature Sensor Error
(71) - Not present
U2108 - CAN-Bus no Communication with ABS/TC
(70) - Not present
P0500 - Vehicle Speed Signal Range/Performance
(7E) - Not present
(7F) - Not present
U2103 - CAN-Bus Circuit Malfunction
(04) - Not present
(06) - Not present
(7F) - Not present
(70) - Not present
P0650 - CAN-Bus No Communication with CIM (Steering Column Module)
(74) - Not present
(5B) - Not present
PranešimasParašytas: 2012 12 23, 16:30 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Raimundas213
tikriausiai teks tuo metu kai nesikuria jungt osila ant can ir atjunginet viska is eiles kad rast kas trumpina linija.
PranešimasParašytas: 2012 12 23, 17:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
beaviz
Nebus CIM modulis grybaujantis?
PranešimasParašytas: 2012 12 23, 18:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
Mielai duociau kam nors kitam, nes- ryte gerai, po kokiu 2 valandu luzta, kazkiek pastovi- vel gerai...jei jau butu blogai visalaik- tada daug paprasciau.
PranešimasParašytas: 2012 12 23, 19:40 Pranešti apie taisyklių pažeidimą Atsakyti su citata
HooDoo
Turejau astra pries pora metu 1.7cdti nesikure kai karstas motoras tai du purkstukai buvo supuleve tik nepamenu del klaidu man atrodo ju nebuvo;)
Neteiskite tu kurie nesupranta,bet nori ismokti.
PranešimasParašytas: 2012 12 27, 20:25 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
Nesiveda-turejau omeny net starteriu nesuka-tipo kaip rakto nepazintu....Motoras dirba-uzgesinus ba ba...Siandien pamastes ant durniaus atjungiau ABS bloka- pravazinejo gal nuo 10 iki 16 val-jokiu bedu, paskui paskambyjo sako pajung, kol kas irgi jokiu ziniu. Tiesiog bendradarbis dar viena dalyka pamate- mokomosios plafonas stopus paspaudus ryskiau uzsidega, kadangi kazkas neeme i galva kad gabaritu ir stopu ta pati lempute, siaip galo valdymo kompas mete 2 klaidas susijusias su stopais, sakau gal dar tas itakojo, bet cia plafonas senai pajungtas....
PranešimasParašytas: 2012 12 29, 21:35 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ComAuto
Esminis klausymas, ne karta atvaziuoja tokie opeliai astra ar vectra 2dti ir pan... zodziu uzgesini, nesvarbu salta silta, kuo ilgiau palieki uzgesines varikli, tuo poto ilgiau reikia sukti starteriu kad uzvesti, ir kaip starteriu suki tai ne tai kad pagriebia ir uzsiveda o griebia griebia ir uzsiveda, klaidu jokiu, gaunasi taip kad kaskaip ar tai salerka is siurblio i baka atgal varo ar kaip... zodziu uzknisa, gal kas esat susidures ir numanot kaip si problema sprendziama? P.S. vienkrypciai voztuvai nepadeda
PranešimasParašytas: 2012 12 29, 22:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
HooDoo
ComAuto rašo:
Idek pompa prie kuro filtro ir pries vezdamas uzpumpuok ir suzinosi ar sesta kuras ar kazkas kitas yra.
Paskutinį kartą redagavo HooDoo, 2012 12 30, 05:31. Redaguota 1 kartą
PranešimasParašytas: 2012 12 29, 22:18 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
Manau ci koki tai eilini karta papjovei pievu. Del savo atvejo ziurek kuro slegius,patrauk ant slipso galu gale.... mano atveju- kompas nesijungia prie motorinio, vairo stiprintuvo, ABS....Uzgesinus net starteriu nesuka, bet kol negesini ir dirba ir krauna....
PranešimasParašytas: 2012 12 29, 22:22 Pranešti apie taisyklių pažeidimą Atsakyti su citata
dusiata
nu kazkur suntuojamas HS CAN. rasti lengviausia atjunginejant iranga. siaip buna kad vairo stiprintuvo siurblio elektronika paskesta ATF'u ar vandeniu, tai manau ji meginciau atjungt pirmiausiai.
PranešimasParašytas: 2012 12 30, 05:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vaidisvaidis
CANAS trumpina ir nieko daugiau ,tis 2000 ir toliau kaip pacio galimybes su ziniom,patyrimu ir iranga leidzia ,tokiu problemu dar niekas per atstuma nesprende,sekmes
PranešimasParašytas: 2012 12 30, 13:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
Nieks ir nepraso per atstuma sprest, pats puikiai suprantu kad HS canas trumpija....Tiesiog turi ribota laiko tarpa ta pasiziuret, nes paskui susitvarko, tiesiog dabar nuo penktadienio dar tebevaziuoja, be to pabandykit Mokomaja paleist vazinetis be vairo stiprintuvo!!! Jau su atjungtu ABS iskilo klausimu-kodel nerodo greicio, nerodo kuro sanaudu.....nors sakiau kad taip bus.
PranešimasParašytas: 2012 12 30, 13:54 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ComAuto
Jai kaskas su kuro slegiais butu tai ir uzgesinus ilgai suktu ar pan, uzgesini tai jai vedi uzsiveda iskart, bet jai kuo ilgiau palieki neuzvesta tai tuo ilgiau sukti reikia, is po nakties tai isvis suki suki, vien suki suki, ir po ilgo kankinimo seip ne taip uzvedi, dar aisku buvau susidures su tokiais dalykais kad buna purkstuku abratkiu slangutes kiauros, arba prie siurblio slangeles kiaurios biski leisdavo, bet ir buna kad visiskai niekur niekas neleidzia ir taip darosi
PranešimasParašytas: 2012 12 30, 14:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
pilypas
ComAuto rašo:
Cominis rasyk i kita tema, nes greit jau nebeaisku bus kokio motoro remontui duodami patarimai, taviskes visai kitoks gedimas, siurbele mirsta, arba kuras gizta, kiti variantai mazai tiketini.
To abalys, as patarciau ziureti nuo ABS bloko. Sekmes knisantis.
Nebijok dideliu islaidu - bijok mazu pajamu
PranešimasParašytas: 2012 12 30, 16:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
abalys
ComAuto rašo:
Matau kai kas jau Naujus svencia Laughing Laughing Laughing Bent pasiskaityk apie ka rasoma, pradedu manyt kad nuo kuro slegio uzsispaudzia CAN, bet ant tiek smarkiai-kad net starteris nebesuka.
