Dabar yra 2026 06 24, 14:41. Visos datos yra GMT + 2 valandos.
Forumas » Akustika » rocksford fostage p1 12"x2
rocksford fostage p1 12"x2 |
Parašytas: 2012 06 09, 03:22 |
Sweiki turiu pora subu Bet niekaip nesigauna sumoduliuot jiems dezes gal galetu kas man padeti ?
Description Value
CEA-2031 Compliant CEA-2031 Guidelines
Size 12"
Nominal Impedance 4-Ohm
Power Handling 150 Watts RMS
300 Watts Max
Voice Coil Diameter 1.5" 6-Layer
(3.81 cm)
Magnet Weight 40 oz.
Speaker Connector Dual 10 AWG compression
Fs (Hz) 25
Re (Ohms) 3.40
Le (mH) 3.9
Qms 7.30
Qes 0.58
Qts 0.54
Vas (Liters) 109.0
Sd (cm2) 540
SPL (dB @ 1w/1m) 86
Xmax (mm) 9.0
Woofer Displacement 0.048 cu. ft.
(1.36 Liters)
Cutout Diameter 11.125 in.
(28.26 cm)
Mounting Depth 5.875 in.
(14.92 cm) |
Parašytas: 2012 06 09, 21:25 |
| Dariau su re audio calculetur bet nzn ar gerai jai portas sone. o as noreciau daryt porta per viduri. beda tame kd nzn kokius portus daryt |
