Dabar yra 2026 05 11, 10:27. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » kas cia per daiktas? skubu
PranešimasParašytas: 2012 05 11, 10:40 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ssaudrius
turiu aprasyti si daikta. Klausiu specialistu kas tai yra?
http://www.ebay.com/itm/FIFE-CDP-01-M-CONTROLLER-VERY-NICE-/380083672940?pt=BI_Control_Systems_PLCs&hash=item587ec0976c
Fife CDP-01 Web Guide Controller
The CDP-01 Web Guide Controller delivers great flexibility in system and control functions. The advanced setup features of
this control automatically determine and set guide polarity, guide point, and system gain. Built for demanding web guiding
applications, this control also provides the flexibility to add features as needed.
Available for both electromechanical and electrohydraulic operations, the CDP-01 can be configured for line, edge, either
edge, or center guiding applications. All Fife standard sensors can be used, whether you need infrared, ultrasonic, visible light,
or feeler-palm.
Multidrive versions are available, allowing one web guide control for use with multiple actuators. Also available is the popular
dual-loop version for Moving-Sensor Center Guiding systems, featuring both guide and sensor postioner control loops in one
housing. The CDP-01 also offers many remote control options and alarm outputs.
Key Features
Advanced controller provides automatic setup features for fast, accurate operation
Switchable 115/220 VAC 50/60 Hz operation
1
Parallel interface for various functions: 6 inputs (remote controls), 2 outputs (alarms or indicators)
Automatically adjusts to connected Fife motor
Built-in amplifier for transparent web detection with infrared sensors
Automatic Sensor Control - a loss of a sensor signal (i.e. web break, end-of-roll) will automatically switch to manual mode
Electrostatic discharge protection
CE Compliant
Specifications
Metric English
Weight: 6.1 kg 13.5 lbs
Voltage Requirements:
90-122
VAC
50/60 Hz
180-244
VAC
50/60 Hz
Power: 210 VA
Fuse:
2.5 A slow blow (5 x 20
mm)
AC Current: 2 amp maximum
Maximum Motor Output:
80 watts (2.6 A at 30
V/3.5 A at 22 V)
Maximum Ambient Temperature (mounted on metal): 60º C 140º F
Maximum Ambient Temperature (mounted on non-metal surface): 50º C 122º F
Protection Class: IP 40
2
Dimensions shown in parenthesis are millimeters
CDP-01 System Diagram
3
CDP-01 Control Panel
4
CDP-01 mounts easily within an existing control panel
Source URL: http://fife.maxcessintl.com/guiding/fife-cdp-01-web-guide-controller
5
 Re: kas cia per daiktas? skubu
PranešimasParašytas: 2012 05 11, 12:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ssaudrius rašo:
or feeler-palm.
Key Features
1
CE Compliant
Specifications
Metric English
90-122
VAC
50/60 Hz
180-244
VAC
50/60 Hz
Power: 210 VA
Fuse:
mm)
V/3.5 A at 22 V)
2
3
4
5
Nu taigi viskas čia parašyta, ko dar reikia ?
PranešimasParašytas: 2012 10 05, 18:36 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lividas
Pramoninių robotų daviklių (sensorių) kontrolė,valdymas,informacijos surinkimas apie jų būseną.
