Dabar yra 2026 04 25, 06:10. Visos datos yra GMT + 2 valandos.
Forumas » Kompiuteriai, jų priedai, periferija » Skaneris Mustek 1200 UB PLUS
Skaneris Mustek 1200 UB PLUS |
Parašytas: 2012 03 21, 12:48 |
Sveiki, niekur nerandu Mustek 1200 UB PLUS skaneriui win7 64bit draiveriu. Gal kas naudoja tokį skanerį ir turi draiverius?
Dėkui. |
Parašytas: 2012 03 21, 14:51 |
| Mustek 1200 cu plus turiu kazkur, atsimenu,kad uzsiknisau juodai - bet suradau ir veikia. Tik kitam kompe, kuris i namus sugryzta vakare, jei labai nori galesiu paieskoti. |
Parašytas: 2012 03 21, 15:06 |
Download the newest XP drivers from this site:
http://www.mustek.com/mustek/supportdrivers.php
Get the one file installation.
You will not be able to install the drivers but you can trick them to work.
The procedure is simple:
Do not plug in the scanner, start up the
Empty your systemroot\windows\temp folder
Srart the instalation and when it asks "Select Language" stop there. Then copy the all contents (files and folders) of Windows\Temp to another folder (e.g. systemroot\1)
Then plug in the scanner and windows should be able to find the drivers there if not guide it to that location and let it install Mustek Twain drivers.
Enjoy your scanner.  |
