Dabar yra 2026 05 11, 20:17. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » STM32 I2C
 STM32 I2C
PranešimasParašytas: 2011 10 17, 00:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Sloikas
Sveiki. Bandau paleist wii motion plus ir nuskaityt gyroskopu duomenis su stm32 mikrovaldikliu. Ant avr pasileido be problemų, tačiau ant šito niekaip neina. Gal kas esate įvaldęs stm32 i2c ir galėtumėt kodą pažėt?
Čia yra pseudo kodas:
Kodas:
//initialize the WM+
i2c_start
i2c_write(0xA6)
i2c_write(0xFE)
i2c_write(0x04)
i2c_stop
//read data
while(true)
    i2c_start
    i2c_write(0xA4)
    i2c_write(0x00)
    i2c_stop
    i2c_start
    i2c_write(0xA5)
    yaw_lo_byte = i2c_read(ack)
    roll_lo_byte = i2c_read(ack)
    pitch_lo_byte = i2c_read(ack)
    yaw_hi_byte = i2c_read(ack)
    roll_hi_byte = i2c_read(ack)
    pitch_hi_byte = i2c_read(nack)
    i2c_stop
    //this is necessary since the last two bits
    //in the high bytes are useless
    roll_hi_byte = roll_hi_byte >> 2
    pitch_hi_byte = pitch_hi_byte >> 2
    yaw_hi_byte = yaw_hi_byte >> 2
    //send to computer for displaying
    putc
    printf
Čia mano iš gabalų surinktas kodas:
Kodas:
#include <stddef.h>
#include "stm32f10x.h"
#include "funkcijos.h"
void I2C_Setup(void)
GPIO_InitTypeDef  GPIO_InitStructure;
    I2C_InitTypeDef  I2C_InitStructure;
    /*enable I2C*/
    I2C_Cmd(I2C1,ENABLE);
    /* I2C1 clock enable */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    /* I2C1 SDA and SCL configuration */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    //SCL is pin06 and SDA is pin 07 for I2C1
    /* I2C1 configuration */
    I2C_InitStructure.I2C_Mode = I2C_Mode_SMBusHost;
    I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStructure.I2C_OwnAddress1 = 0x00;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_ClockSpeed = 100000 ;
    I2C_Init(I2C1, &I2C_InitStructure);
    /*!< Enable SMBus Alert interrupt */
    I2C_ITConfig(I2C1, I2C_IT_ERR, ENABLE);    //dont think this is necessary
void init_wii(void)
I2C_GenerateSTART(I2C1, ENABLE);
    while(!I2C_GetFlagStatus(I2C1, I2C_FLAG_SB)); // start bit flag
    I2C_SendData(I2C1, 0xA6); //send write command to chip
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
    //while(!I2C_GetFlagStatus(I2C1, I2C_FLAG_TXE));
    I2C_SendData(I2C1, 0xFE); //mode register
    while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
    I2C_SendData(I2C1, 0x04); //continious conversion mode
    I2C_GenerateSTOP(I2C1, ENABLE);
    while(I2C_GetFlagStatus(I2C1, I2C_FLAG_STOPF)); // stop bit flag
void Recieve(void)
uint8_t X1,X2,Y1,Y2,Z1,Z2;
   /* Test on SB Flag */
   while (!I2C_GetFlagStatus(I2C1,I2C_FLAG_SB));
I2C_SendData(I2C1, 0xA4);
I2C_SendData(I2C1, 0x00);
/* Send STOP Condition */
/*re-enable ACK bit incase it was disabled last call*/
I2C_AcknowledgeConfig(I2C1, ENABLE);
/* Test on BUSY Flag */
while (I2C_GetFlagStatus(I2C1,I2C_FLAG_BUSY));
/* Enable the I2C peripheral */
/* Send device address for write */
I2C_Send7bitAddress(I2C1, 0xA5, I2C_Direction_Receiver);
/* Test on ADDR Flag */
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
/* Send START condition a second time (Re-Start) */
//I2C_GenerateSTART(I2C1, ENABLE);
//while (!I2C_GetFlagStatus(I2C1,I2C_FLAG_SB));
/* Send address for read */
//I2C_Send7bitAddress(I2C1, Address, I2C_Direction_Receiver);
//while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
/* load in 5 of 6 registers */
X1 = I2C_ReceiveData(I2C1);
while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED));
X2 = I2C_ReceiveData(I2C1);
Y1 = I2C_ReceiveData(I2C1);
Y2 = I2C_ReceiveData(I2C1);
Z1 = I2C_ReceiveData(I2C1);
/*enable NACK bit on next read and read final register*/
I2C_NACKPositionConfig(I2C1, I2C_NACKPosition_Current);
I2C_AcknowledgeConfig(I2C1, DISABLE);
Z2 = I2C_ReceiveData(I2C1);
USART_SiustiString("Siunciam");
USART_SendData(USART2, X1);
int main(void)
  USART2_Configuration();
  RCC_Configuration();
  USART_SiustiString("Siunciam1");
  I2C_Setup();
  init_wii();
  USART_SiustiString("Siunciam2");
  while (1)
     Recieve();
Bučiau dėkingas už bet kokią naudingą info Smile
 STM32 I2C
PranešimasParašytas: 2011 10 17, 15:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
R2D2
įkelk visur
USART_SiustiString("vis skirtingas tekstas");
ir atrasi kur sustoja ir bus aišku kas neįvyksta ar įvyksta ne taip.
 STM32 I2C
PranešimasParašytas: 2011 10 17, 18:28 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Sloikas
O, kad būtų viskas taip paprasta Smile Yra debugeris. Problema, kad kodas sukas, bet duomenų negauna Smile
 STM32 I2C
PranešimasParašytas: 2011 10 17, 19:45 Pranešti apie taisyklių pažeidimą Atsakyti su citata
R2D2
tai gal reikia pamėginti be debugerio, o tiesiai išvesti. nes jei niekur neužstringa reiškia duomenys yra gaunami.
čia akselerometrą spėju bandoma nuskaityti?
 STM32 I2C
PranešimasParašytas: 2011 10 17, 20:05 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sneikaz
STM32 i2c gaidiskiausias is visu bandytu... Pitriausiai uzduotis buvo padaryt visa harware kuo sustriau ir kuo pigiau... Gavos visiskas meslas, bet pigus...
Nori uzkurt skaityk datasheeta ir analizuok kiekviena eventa...
//Send START condition//
//I2C_EVENT_MASTER_MODE_SELECT //Wait while START generated
//Send slave address
//I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED//Wait for ACK
//Clear EV6 by setting again the PE bit??
//Send slave SubAddr;
//I2C_EVENT_MASTER_BYTE_TRANSMITTED//Wait for data sent
//Generate repeated start
//I2C_EVENT_MASTER_MODE_SELECT //Wait while repeated START generated/ /EV5//
//Send slave address+read
//I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED// Wait for ACK
// Disable Acknowledgement
//Send STOP condition
//I2C_EVENT_MASTER_BYTE_RECEIVED;Wait for
//Enable Acknowledgement
As naudoju tokia seka...
Siaip patarimas jei naudosi interuptus nenaudok polingo, nes kaskuris eventas trunka keliolika ar kelesdesimt ciklu, praleisi ir pakibs...
 STM32 I2C
PranešimasParašytas: 2011 10 18, 17:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Sloikas
Pagaliau pavyko paleist Smile Tik dabar problema kaip paverst int į stringą, kad būtų galima atvaizduot.... Atrodo paprasta problema, bet neina rast veikiančių funkcijų, reiks pačiam rašyt kažką.
 STM32 I2C
PranešimasParašytas: 2011 10 18, 17:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Socrates
Sloikas rašo:
itoa()
 STM32 I2C
PranešimasParašytas: 2011 10 18, 21:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Sloikas
Nu jei šitos funkcijos nežinočiau tai net ledų turbūt nemokėčiau pamirksyt su avr Smile Čia yra nestandartinė funkcija. Ant ARM'ų stdlibe ner šitos funkcijos. Reik persirašyt iš AVR Smile
 STM32 I2C
PranešimasParašytas: 2011 10 18, 21:26 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sneikaz
sprintf()
 STM32 I2C
PranešimasParašytas: 2011 10 18, 21:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Sloikas
sneikaz rašo:
sprintf()
Aha, jau pasinaudojau, bet čia sunki funkcija. Tinka kol kodas trumpas dar Smile
 STM32 I2C
PranešimasParašytas: 2011 10 18, 23:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
R2D2
jei savo, tai rekursiniu ištraukimu nuo galo imant po narį.
 STM32 I2C
PranešimasParašytas: 2011 10 21, 14:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
MarcaZ
snprintf(char *str, size_t size, const char *format, kintamasis1, kintamasis2);
Pvz
Kodas:
unsigned char stringas[10];
stringas = "lopeta";
snprintf(buferis,20,"Mano stringas: %s",stringas);
//cia sukelei viska i buferi
//o po to su kokia uart duomenu isvedimo funkcija isspausdini
print_to_uart(buferis);
