Dabar yra 2026 05 01, 20:26. Visos datos yra GMT + 2 valandos.
 Forumas » Autoelektronika » Sveiki reikia pagalbos del signalizacijos
PranešimasParašytas: 2011 07 19, 22:54 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vitaminaszzz
Yra toks dalykas pas mane yra toyota calica 1991 metu su centriniu ir pajungus laidus nesuveikia centrinis i ji iveina 5~7 laidai beto gal kas galit paaiskint kaip pajungt gerai sita signa signas yra pigiausias Car Alarm Manual 828Model kaip viska pajungiau rele veikia kaukia viskas ok tik su duru dacikais yra bedu pajunges uzrakini pastovi ir pradeda kaukti http://imageshack.us/photo/my-images/828/gedc0488.jpg http://imageshack.us/photo/my-images/217/gedc0490.jpg kas galit padet del pajungimo
PranešimasParašytas: 2011 07 20, 11:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vabalas
1991 Toyota Celica Car Alarm Installation Guide
Battery Constant 12v+ Positive Wire (+): White Or Black Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black/White
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Blue/Red
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Orange
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Gray
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Light Green
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Dark Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/Black
Power Door Lock Negative Wire Location: In Drivers Kick Panel
Power Door Unlock Negative Wire (-): Blue And Green (Use Both). When connecting for unlock, you must use both wires and diode isolate.
Power Door Unlock Negative Wire Location: In Drivers Kick Panel
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: At Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black Or White/Blue
Tachometer Wire Negative Wire Location: At Check Connector. The check connector is located behind the drivers strut tower.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
