Dabar yra 2026 06 02, 22:51. Visos datos yra GMT + 2 valandos.
 Forumas » Garso aparatūra » kompas - mp3 grotuvas? :-)
PranešimasParašytas: 2004 03 11, 16:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Viniux
zodziu gulejo gulejo kompo deze po stalu ir galu gale prisiruosiau padaryt mp3 grotuva Smile
PC: P90 16 ram cd-rom 4x (heh) 130 mb hdd
viskas veikia labai graziai
ijungi idedi cd ir po poros min paleidzia Smile
viska daro mpxplayer'is
valdymas: mpxplayer'io confige yra nustatymai valdymui per rs-232 bet su rs-232 irgi mazai teko susidurt Sad
[serialport]
SerialEnable =0 ; - enable serial control with this
HandlerCFG =UIR,COM1,9600,6 ; - configure a handler
SerialFunc =45ba00ff0000,0b30 ; '0' - set functions (buttons) for this handler
SerialFunc =45ba807f0000,0231 ; '1'
SerialFunc =45ba40bf0000,0332 ; '2' These values are configured
SerialFunc =45bac03f0000,0433 ; '3' to my remote controller.
SerialFunc =45ba20df0000,0534 ; '4'
SerialFunc =45baa05f0000,0635 ; '5' You can declare max 99 SerialFunc lines (buttons)
SerialFunc =45ba609f0000,0736 ; '6' for one handler.
SerialFunc =45bae01f0000,0837 ; '7'
SerialFunc =45ba10ef0000,0938 ; '8'
SerialFunc =45ba906f0000,0a39 ; '9'
SerialFunc =45ba68970000,1f73 ; 's' stop
SerialFunc =45ba18e70000,1970 ; 'p' play/pause
SerialFunc =45bae8170000,1970 ; 'p' play/pause
SerialFunc =45ba52ad0000,316e ; 'n' random mode
SerialFunc =45ba88770000,4a2d ; '-' skip back
SerialFunc =45ba08f70000,4e2b ; '+' skip to next
SerialFunc =45ba7a850000,2064 ; 'd' hi-lite scan
SerialFunc =45baf00f0000,ff01 ; continuous rewind
SerialFunc =45ba708f0000,ff02 ; continuous forward
SerialFunc =45ba38c70000,4400 ; F10 exit
SerialFunc =45bad02f0000,332c ; , volume down
SerialFunc =45ba50af0000,342e ; . volume up
SerialFunc =45ba6a950000,372a ; gray-'*' next album
SerialFunc =45bab04f0000,246a ; 'J' programming (juke box mode)
gal kas daret kanors panasaus?
del lcd tai nzn ar isvis teks man ji jungt nes apie juos ziniu - 0 Confused
konfige lcd configinimas irgi yra
[LCDdisplay]
LCDport =none ;LPT1..LPT4 or COM1..COM4
LCDtype =1 ;1,2,3,4: LPT, 5,6,7,8:COM-port LCD
LCDrows =20 ;number of characters/line (usually 8-40)(max. 512)
LCDlines =2 ;number of LCD lines (1-16)
LCDportdelay =5 ;for LCDtype 1,2,4 (value should be between 1 and 500 (or maybe more))(increase it if the display doesn't work properly, reduce it to get a faster displaying)
LCDrefresh =0 ;refresh delay (lower value faster, higher value slower refresh (0=40fps,1=20fps,3=7fps,5=4fps))
LCDscrollspeed=4 ;(-"-)
LCDscrolldelay=30 ;pre-delay before scrolling (20 = 1 sec)
LCDpagereset =30 ;(re)set LCD to page 0. after n/20 sec (20 = 1 sec) if there's no desktop (keyboard) activity
;LPT to LCD controlbit configuration for LCDtype 1 and 3 (different wiring schemes, different bit configs)(0x01=LPT-pin 1, 0x02=LPT-pin 14, 0x04=LPT-pin 16, 0x08=LPT-pin 17)
;(note: old LCDtype3 cfg: RS=0x08,E1=0x01, old LCDtype4 cfg:RS=0x04,E1=0x08) (set the unused bits to 0x00)
LPT_cntrlbit_RW=0x02 ;read/write bit (used at type 3)
LPT_cntrlbit_RS=0x04 ;register select bit (command/data)
LPT_cntrlbit_E1=0x01 ;enable (data send) for controller 1.
LPT_cntrlbit_E2=0x08 ;enable for controller 2. (LCDtype 1 only: 4x40 displays)
;display-item config(s)
LCD_items =1,1,LINESCROLL,P_ARTIST," - ",P_TITLE," (",P_TIMEPOS,"/",P_SONGTIME,") " ;
LCD_items =2,1,LINESCROLL,"From the '",P_ALBUM,"' album in the year ",P_YEAR," [",P_GENRE,"] " ;
LCD_items1=1,1,LINESCROLL,EDITORHLINE," ";
LCD_items1=2,1,LINESCROLL,EDITORHLINEP1," ";
LCD_items2=1,1,volmeter ;
PranešimasParašytas: 2004 03 11, 16:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Dovydas
Parasyk plauciau, kaip tu visa tai zadi valdyti per RS232, koki softa naudoji. Gal koki linka mestelk... Idomus dalykas.
PranešimasParašytas: 2004 03 12, 01:27 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Viniux
mpxplayer home - http://mpxplay.cjb.net/
PranešimasParašytas: 2005 06 06, 23:38 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Dovydas
O tu su klaviaturą nebandei valdyt? Iš kur bandei užkraut tą mpxplay: iš DOSo ar Windows?
Aš bandžiau užkraut iš Windows per DOSą ir viskas veikia (su klaviatūrą), o kai kraunu vien per DOS'ą, tai neveikia garsas (nepaimima garso ploktės). Garso plokštė SoundBlaster 16. Lyg ir trūktų draiverių, bet kiek skaičiau aprašyme, tai turėtų veikti su SB1 ir be papildomų draiverių per DOSą. Nežinau ką daryt... Padėkit paleist per DOS'ą Rolling Eyes
PranešimasParašytas: 2005 06 07, 11:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
DainiusT
kraunant kompa is doso irgi reikia draiverius nurodyti ar tai config sys'e ar tai autoexec bat'e , nebeprisimenu. Paskaityk savo garso plokstes instrukcijoje, ten tikrai turi buti parasyta kaip uzkrauti is doso.
PranešimasParašytas: 2005 06 07, 15:38 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Marcius
as savo laiku norejau daryti is pc DVD grotuva;
valdymas buvo irda distanciniu;
labai viskas paprasta ir praktiska, nereikia nei klaviatorus, nieko. Uz keliolika LT irda daviklis ir betkoks distancinis. Veikia su betkokiom Windowsinem programom. Vaizdas per telika, naudojan video korta su tvout.
Aisku to taip ir nepadariau, nes nei garso kokybe nei vaizdo neaplenke pigaus dvd grotuvo.
Tau manau irgi yra neracionalu daryti mp3 grotuva is seno pc.
Elektros sanaudos, pasalinis garsas, nekokybiskas garsas, gabaritai, programiniai klausimai...
O dvd ijungei ir groja po 10sec.
PranešimasParašytas: 2005 06 07, 18:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
CodeC
gal tu geriau koki yammp daryk, bo tokia deze vien mp3 desifravimui tai kazinau... elektros negaila:)?
PranešimasParašytas: 2005 06 07, 21:53 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Dovydas
DainiusT rašo:
Na apie draiverių paleidimą iš DOSo nelabai ką išmanau Crying or Very sad
CodeC rašo:
Kas tas yammp? Jam tikriausiai reikės mp3 procesoriaus, kurio neimanoma gaut Surprised ? Elektros nelabai gaila...
PranešimasParašytas: 2005 06 08, 00:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Socrates
CodeC rašo:
Dovydas rašo:
www.yampp.com , bet kur gaut VS1001 (VS1011 or smth) dekoderi, tai nezinau Smile
PranešimasParašytas: 2005 06 08, 11:34 Pranešti apie taisyklių pažeidimą Atsakyti su citata
CodeC
www.atmel.com yra prociuku su hardwariniais mp3 dekoderiais. tik ne AVR o 8051 ar 8052 architekturos. gal juos lengviau butu gaut? tik idomu uz kiek.
PranešimasParašytas: 2005 06 09, 02:27 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Julius
o tu mp3 processoriu nebuna mp3 playeriukuose?Wink
PranešimasParašytas: 2005 06 09, 04:58 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Socrates
CodeC rašo:
AT89C51SND1C mp3 dekoderis su navarotais. Vienas kinietis man jo schema dawe Smile anyway kaina lemonoj shito stebuklo 84Lt. Tiesa kas zino, tai kaip matot atpigo jau Very Happy
PranešimasParašytas: 2005 06 09, 04:59 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Socrates
Julius rašo:
o tai kaip be tokiu jie veiks ? Laughing
PranešimasParašytas: 2005 06 09, 14:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Viniux
nu ir prikelet sena tema Smile
tas kompas toliau sekmingai guli kazkuriam kampe Laughing
PranešimasParašytas: 2005 06 09, 23:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Dovydas
Viniux rašo:
Tai ką, jau nuleidai rankas? Pabandyk dar panaudot Cool
