Dabar yra 2026 05 06, 02:51. Visos datos yra GMT + 2 valandos.
Forumas » Mikrovaldikliai » Padekit irasant hex
Padekit irasant hex |
Parašytas: 2011 06 04, 19:48 |
Sveiki, turiu atmega8 su usbasp softu ir atmega16 kaip ir tuscia. Atmega 16 nei su usbaspu neisiraso su avr burn o mat. o is usbaspo noriu pasidaryti kita programatoriu tai su tokiu http://www.embedds.com/wp-content/uploads/2010/10/RS232-AVR-ISP-SCHEMATIC.png programuoju. nei su pony progu nei atmegos 8 nei 16. gal kanors netaip darau?? Burnomat tuo COMiniu programinant nustacius ponyser (design ponyprog serial, reset=txd sck=rts mosi=dtr miso=cts raso: C:\Documents and Settings\Mosfet\Desktop\avrdude.exe -C C:\Documents and Settings\Mosfet\Desktop\avrdude.conf -p m8 -P com1 -c ponyser -F -u -U hfuse:w:0x4F:m -U lfuse:w:0xAF:m
avrdude.exe: AVR device not responding
avrdude.exe: initialization failed, rc=-1
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x000000
avrdude.exe: Yikes! Invalid device signature.
avrdude.exe: Expected signature for ATMEGA8 is 1E 93 07
avrdude.exe: reading input file "0x4F"
avrdude.exe: writing hfuse (1 bytes):
Writing | ***failed;
################################################## | 100% 0.09s
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 0x4F:
avrdude.exe: load data hfuse data from input file 0x4F:
avrdude.exe: input file 0x4F contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: verifying ...
avrdude.exe: verification error, first mismatch at byte 0x0000
0x4f != 0x00
avrdude.exe: verification error; content mismatch
avrdude.exe done. Thank you.
padekit  |
_________________ SPL in my blood... |
Parašytas: 2011 06 04, 20:22 |
| galimai pamirsai pajungt isorini kvarca ar bent XTAL koja kuom nors pamajacint, nes avr skirtingai nuo pic po fuse programinimo tolesnei modifikacijai pasiduoda tik per HVisp |
Parašytas: 2011 06 04, 20:23 |
Visų pirmą patikrink atmeg'os maitinimą gal būt nėra pastovi įtampa arba neužteka jos, panašią problemą turėjau, kai užmaitindavau tik su 3.8V vietoj [4;5] V |
Parašytas: 2011 06 04, 20:26 |
| na ji pas mane maitinasi per du diodus 3.6V kadangi programatorius tokiu principu veikia. Tai meginti jungti i +5? |
Parašytas: 2011 06 04, 20:33 |
pajungus +5 va taip gaunas
G:\WinAVR-20100110\bin\avrdude.exe -C G:\WinAVR-20100110\bin\avrdude.conf -p m8 -P com1 -c ponyser -D -F -u -U hfuse:w:0xCF:m -U lfuse:w:0xAF:m
Cia parasius -F ir -D |
Parašytas: 2011 06 04, 21:31 |
Aš tai siūlyčiau paieškoti kompo su lpt ir pasinaudoti bent jau penkių laidukų programatoriumi.
Ps. - visai neseniai buvau nemaloniai nustebintas, kai usbtiny pareiškė kad atmega16 juo nesiprogramuoja. Teko pasinaudoti seno pigaus nešiojamo kompo paslaugom su lpt jungtimi ir avrisp programatoriumi. |
Parašytas: 2011 06 04, 21:34 |
galite gal tikrai veikiancio lpt programatoriaus schema duoti?? Beja nebutinai kompas su lpt ir com turi buti senas. Gigabyte GA-p35-DS3l V2 turi viska ko reikia  |
Parašytas: 2011 06 04, 21:40 |
| Tikrai veikiantis lpt programatorius, taip pat gūgle "avrisp", arba jei reikia labai greitai, tai penki laidukai (aprašytas 99lt boto aprašyme). |
Parašytas: 2011 06 06, 16:48 |
Nebezinau ka daryti pasidariau toki:
http://www.scienceprog.com/avr-isp/ su 74hct244
ir gaunu toki rezultata.
C:\WinAVR-20090313\bin\avrdude.exe -C C:\WinAVR-20090313\bin\avrdude.conf -p m8 -P lpt2 -c blaster -F -u -U hfuse:w:0xD9:m -U lfuse:w:0xE1:m
Padekit patarkit prasau  |
Parašytas: 2011 06 06, 17:19 |
| Beja su pony prog tai nors lemputes sumirgsi, o su BURN o MAT niekas. Pony prog isnkarto ismeta Device missing or unknown device |
Parašytas: 2011 06 06, 18:11 |
| Jei lempute sumirksi, tai kaip suprantu maitinimą iš isp jungties programatorius gauna (tikiuosi maitinimą mikrei padavei? 10 koja minusas, 20 koja +5v iš antro isp kontakto). Tada bandyk pasižiūrėti per bios, kokį lpt režimą pasirinkęs. Jei neklystu, turėtų būti ecp+epp ar panašiai. |
Parašytas: 2011 06 06, 20:57 |
na maitinimas pajungtas gerai, Taip maitinima gauna is isp. Porto nustatymai yra tik auto bi directional, epp, ecp kad abu kartu nera. Kai paspaudziu read ar kanors panasaus. Tai kadangi atmega8 pajunga prie usb su visais kontaktais tai paraso usb device not recognized. Poto uzgesta lempute ir vel tiesiog unknown device. na o atmega16 taspat nesiprogramuoja nors tu ka  |
Parašytas: 2011 11 11, 13:43 |
| gal radai problemą ? nes pas mane ir prog su 74hct244 ir neveikia. pajungiu lpt ,įjungiu pony prog ,maitinima yra , probe paspaudžiu rašo ok . bet nei nuskaityt nei įrašyt nieko . |
