Dabar yra 2026 05 11, 00:57. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » passat b5 skydelio pinoutai
passat b5 skydelio pinoutai |
Parašytas: 2011 01 28, 21:48 |
sveiki.bandau ant stalo pasijungti b5 passato skydeli(zaliu apsvietimu).zinau siuos pinoutus:
Pinuots:
GND - Dashboard Blue connector pin 24
W (Kline) - Dashboard Green connector pin 5
IGN +12V - Dashboard Blue connector pin 1
su maitinimais viskas tvarkoj,skydelis pasijungia ,taciau negaliu prisijungti vag tacho 2.5 prie pacio skydelio.raso,kad tipo skydelis nerastas. obd jungiu:
4 pin -gnd
16 pin- +
7 pin- k line sujungta su 5 pinu skydelio.
kur darau klaida?
dekui. |
Parašytas: 2011 01 28, 22:12 |
32-pin connector -T32a-, blue
1 - Terminal 15, positive
2 - Right turn signal warning lamp -K94-
3 - Output signal 1 from speedometer -G21-
4 - Warning lamp for trailer operation -K18- (vehicles 05.98 ►)
5 - Fuel gauge -G1-
6 - Warning lamp for airbag -K75-
7 - Terminal 31, sender earth
8 - Coolant temperature gauge -G3-
9 - Terminal 31, earth
10 - Oil pressure switch -F1- for warning buzzer for oil pressure check -H11-
11 - Rev counter -G5-
12 - Alternator warning lamp -K2-, charge warning lamp, terminal 61
13 - Glow period warning lamp -K29- (diesel engines only) or catalytic converter monitor warning lamp (only certain countries)
14 - Rear fog light warning lamp -K13-
15 - Not assigned
16 - Towing operation warning lamp -K18- or, on vehicles for USA only, rear lid open warning lamp -K116- (vehicles► 04.9
17 - Main beam warning lamp -K1-, terminal 56a
18 - Left turn signal warning lamp -K65-
19 - ABS warning lamp -K47-
20 - Digital display illumination -L75-, terminal 58d
21 - Signal for driver's door open
22 - Warning lamp for coolant temperature and coolant low display -K28-
23 - Terminal 30, positive
24 - Terminal 31, earth
25 - Self-diagnosis, K-wire
26 - Right parking light, signal for warning buzzer indicating light on -H16-
27 - Left parking light, signal for warning buzzer indicating light on -H16-
28 - Input signal to speedometer -G21-
29 - Warning contact for brake fluid level -F34-
30 - S-contact
31 - Seat belt warning system (for USA/Japan only)
32 - Warning lamp for side marker lights (certain countries only) or emissions warning lamp -K83- (USA only)
32-pin connector -T32b-, green
1 - Not assigned
2 - Immobilizer reader coil -D2-, connection 1
3 - Not assigned
4 - Not assigned
5 - W-wire
6 - Windscreen washer fluid level sensor -G33-
7 - Brake pad warning lamp -K32-
8 - Warning buzzer indicating light on -H16-
9 - External gong (e.g. for seat belt warning system)
10 - Fuel reserve warning (only certain countries)
11 - Signal for vehicle stationary
12 - Air conditioning system shut-off
13 - Dual circuit brake/handbrake warning lamp -K7-
14 - Traction control system warning lamp -K86-
15 - Not assigned
16 - Not assigned
17 - Immobilizer reader coil -D2-, connection 2
18 - Not assigned
19 - Not assigned
20 - Not assigned
21 - Not assigned
22 - Not assigned
23 - Multifunction display call-up button -E86- → top, (display switches down)
24 - Multifunction display call-up button -E86- → bottom, (display switches up)
25 - Multifunction display memory switch -E109- → Reset
26 - Ambient temperature sensor -G17-
27 - Not assigned
28 - Not assigned
29 - Not assigned
30 - Output signal 2 from speedometer -G21-
31 - Selected range display
32 - Fuel consumption signal
20-pin connector -T20-, red
1 - 11 - Not assigned
12 - Radio/navigation - clock
13 - Radio/navigation - data
14 - Not assigned
15 - Radio/navigation - enable
16 - 20 - Not assigned |
_________________ Kuo daugiau meistru, tuo daugiau darbo:)
CARCHIP Ltd |
Re: passat b5 skydelio pinoutai |
Parašytas: 2011 01 28, 22:15 |
| Egis_ rašo: |
Stai cia klaidos.W ir K line -skirtingi daiktai.W-skydukas jungiamas su varikliu |
Parašytas: 2011 01 28, 22:47 |
| art64 rašo: |
| Egis_ rašo: |
teisingai.bet sujungus 25 pina blue connector su 7 pin obd vis tiek neina prisijungt  |
Parašytas: 2011 01 28, 22:49 |
| gedas8899 rašo: |
| o tai su taxho usb nelengviau per diagnostika |
tai taip,bet turiu atliekanti skydeli,tai sumasciau pazaist truputi be to radau sena tema apie passato skydelio sukima,kuriame forumietis zemaitukas ivardino si kabeli,kaip ''viska daranti'' su vagais,tai uzvalde smalsumas zinau,kad sitas kabeliukas tik vdo skydeliam veikia gerai-isbandyta,o vat magneti marelli- kaip kad kazkas rase-zudo  |
Parašytas: 2011 01 28, 23:12 |
| art64 rašo: |
| Su Tacho ,kiek zinau,neis atsukti sito skydelio. |
na jei pavyks prisijungt,tai pasakysiu  |
Parašytas: 2011 01 29, 00:23 |
Pasijungiau,viskas veikia,su maitnimais buvau nugrybaves bet prie eepromo cia niekaip neina prilyst su situ kabeliuku  |
Parašytas: 2011 01 29, 02:11 |
| Egis_ rašo: |
Tai kaip galvoji, kam as ieskojau ir siunciau pinout? |
CARCHIP Ltd |
