Dabar yra 2026 06 24, 15:58. Visos datos yra GMT + 2 valandos.
 Forumas » Kompiuteriai, jų priedai, periferija » Lagina PC. Padekite :)
PranešimasParašytas: 2011 01 09, 22:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
Susiduriau su tokia beda. Kompas lagina Smile atrodo juokinga. Bet kompo parametrai tikrai ne tie, kad reiketu rupintis. Placiau:
Intel procas Pentium 4 HT 2,8ghz
Motina Asrock 775VM800
Operacine sistema Win 7 Ultimate 32bit
Proco temperatura ~50c
HDD temperatura ~40c
Kazkada seniai, kai gavau si kompa, jis turejo viena beda. Del ausinimo nestabilumo procas kaisdavo. Nekepdavo, nes atsijungdavo automatiskai prie kritines temperaturos. Buvo kalta ausintuvo kojale, del kurios ausintuvas neprisispausdavo prie proco. Sutvarkiau. Dabar darbine temp ~50c. Kol pc neapkrautas (neveikia jokios programos, tol viskas ok). Bet vos paleidziu kelias programas vienu metu, t.y. klausau muzikos ir narsau nete, narsykle pradeda laginti, muzika kartkartemis trukineja. Anksciau kaltinau sena HDD. Taciau, idetas kitas HDD, bet problema liko ta pati. Kaltint proca? Suprantu, kad cia kaip sakem per vandeni, bet gal kam panasi beda buvo.
Pratestinau naudodamas SiSandra programa.
Apie proca raso :
1.You are using a Hyper-Threaded system (HT/SMT) on an operating system (OS) that either does not support it or does not support the total number of logical processors of the system. Thus Hyper-Threading is not properly utilised. You may as well disable it.
2.SMBIOS/DMI information may be inaccurate. This information is reported verbatim and cannot be checked by Sandra. While brand-name companies set this information most generic manufacturers use generic data that is meaningless. This issue generates more technical support queries than all other issues combined.
Apie HDD raso:
1. Acoustic Management enabled. While this reduces the noise the drive generates, the performance is almost always impaired. Most of the time fans generate more noise than the drive itself. If the drive does generate a lot of noise, it may be faulty. You could also consider swapping the drive for another model that generates less noise.
Dekoju uz ats nepatingejusiems perskaityti Smile
PranešimasParašytas: 2011 01 09, 23:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
SrH
Kokie RAMai ir kiek? Ar nenoretum pakeisti procesoriaus ausintuvo - 50C idle yra labai didelis skaicius.
PranešimasParašytas: 2011 01 09, 23:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Arvydas300
Perinstaliuok WIN Wink
PranešimasParašytas: 2011 01 09, 23:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
SrH rašo:
2GB DDR. Del ramu, nemanau, kad turetu laginti.
Del ausintuvo - kur man dabar tokia reikala rasti su sveikais ausintuvo pritempejais prie proco?
PranešimasParašytas: 2011 01 09, 23:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
Arvydas300 rašo:
sviezia win kopija. Ir ne pirma karta Wink
 Re: Lagina PC. Padekite :)
PranešimasParašytas: 2011 01 09, 23:24 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123 rašo:
Pirmiausia toks kompas kiek per silpnas Win 7, bet tai matyt ne pagrindinė bėdos priežastis.
Motininė - ne iš geriausių švelniai pasakius. Tikrai neturinti geros reputacijos. Dažnos bėdos su kondikais, maitinimo tranzistoriais ir kitkuo (sudėta viskas kas pigiausia)
Procas kol nebuvo sutvarkytas aušinimas galėjo sugesti ir todėl dabar gliučina.
Maitinimo blokas irgi gali būti įtariamas.
Šiaip sunku ką nors per atstumą pasakyti, parsisiųsk HirensBoot CD, ten yra visokių geležies tikrinimo programų pratestuok viską ką įmanoma, gal paaiškės.
PranešimasParašytas: 2011 01 10, 10:29 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
dekoju uz komentara Smile
laukiu daugiau nuomoniu. Kolkas viskas krypsta i proca.
PranešimasParašytas: 2011 01 10, 10:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Gintaza
Koks vaizdo adapteris ?
Ar jo tvarkykles yra WIN 7 ?
PranešimasParašytas: 2011 01 10, 13:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
Gintaza rašo:
vaizdas geforce 7*** kazkuri plokste. nemanau, kad bent jau universaliu draiveriu neparase sitom plokstem.
Paskutinį kartą redagavo m123, 2011 01 10, 14:10. Redaguota 1 kartą
PranešimasParašytas: 2011 01 10, 14:09 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Gintaza
Tai koki adapteri dabar rodo kur yra "Display adapters" ?
Ir dar klausimas , ar "luzta" pati sistema ?
PranešimasParašytas: 2011 01 10, 14:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
Gintaza rašo:
paziuresiu, kai is darbo grisiu. bet man atrodo, kad sita rodo. o gal tokie bajeriukai buti del vaizdo plokstes??
PranešimasParašytas: 2011 01 10, 14:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Gintaza
Taip lagint gali , jei stovi "Standart VGA adapter " valdikliai .
PranešimasParašytas: 2011 01 10, 20:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
raso, kad nvidia draiveriai. manau, kad tik vaizdas lagintu tokiu atveju. o cia ir garsas trukcioja karts nuo karto
PranešimasParašytas: 2011 01 10, 21:42 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Gintaza
Na jei su softu tu isitikines , kad viskas tvarkoje , belieka gelezis .O gelezyje tai del labai ivairiu dalyku , pradedant procesorium , tiltais , tinklo adapterio ,garso ir kitais cipukais baigiant taimeriu , kas irgi neretai buna .Niekas cia su Desktopine plokste nezais , pamegink pakeist proca , jei sakai kad buvo perkaitintas , nepades - ieskok mamkes .
Sekmes .
PranešimasParašytas: 2011 01 11, 09:32 Pranešti apie taisyklių pažeidimą Atsakyti su citata
m123
pradejau nuo proco paiesku. vakar buvau isemes vaizdo plokste (paleidau vaizda per integruota motinineje). Niekas nepasikeite lago atzvilgiu. Kol viena programa, tol ok. Bet paleidus media plejari ir bandant narsyti nete jau sunkiau Very Happy
