 2026 m. balandžio 24 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2026 04 24, 15:59. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » matrix 8x8 ASM programa
PranešimasParašytas: 2011 01 08, 23:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
mindaugs
pasirasiau paprasta programa ASM kalba, su kurios pagalba tiesiog matrix led 8x8 diodai sviecia stulpeliais.
Pvz.:
Kodas:
LIST      P=16F876
#include <p16F876.inc>
__CONFIG   _CP_OFF &  _WDT_OFF & _PWRTE_ON & _XT_OSC
ORG   0x2100
DE   0x00
ORG    0
cblock 0x20
d1
d2
d3
endc
goto start
Delay
;999990 cycles
movlw 0x07
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;6 cycles
goto $+1
goto $+1
goto $+1
;4 cycles (including call)
return
loop:
movlw b'00000111'
movwf PORTA
movlw b'11110010'
movwf PORTB
movlw b'11111111'
movwf PORTC
call Delay
call Delay
call Delay
goto loop
start:
bsf STATUS,RP0 ; select register page 1
movlw 0 ; put 0 into W
movwf TRISC ; set portC all output
clrf  TRISA
clrf  TRISB
bsf STATUS,RP1 ; select Page 2,
bcf STATUS,RP0 ; by setting RP1 in Status register and clearing RP0
clrf PORTC ; select Digital I/O on port C
bcf STATUS,RP1 ; back to Register Page 0
goto loop
end
Bet noriu "sustresnes" programos su kuria galeciau atvaizduoti begancius zodzius per ekrana. Pradziai pameginau padaryti, kad uzsidegtu pora stulpeliu bet su skirtingose vietose deganciais diodais. Taciau gavosi kazkoks keistas blyksejimas, neiseina padaryti, kad ilgiau sviestu. Gal kas zinosit kas negerai...
Programos kodas:
Kodas:
LIST      P=16F876
ORG   0x2100
DE   0x00
ORG    0
cblock 0x20
   Delay1               ; delay loop 1
   Delay2               ; delay loop 2
   Delay3               ; delay loop 3
   TimeDelay            ; time delay x 0.001 s
   EndCount            ; used to tell PIC the end of the table is reached
   Counter               ; used as table counter
   Line1               ; Line 1
   Line2               ; Line 2
   Line3               ; Line 3
   Line4               ; Line 4
   Line5               ; Line 5
   sad
   Line6               ; Line 6
   Line7               ; Line 7
   Line8               ; Line 8
   Layer4               ;  brightness, and time
   Brightness            ; LED brightness
   Time               ; time for each pattern to stay
   Temp               ; temp register
d1
d2
d3
endc
goto start
Delay
;999990 cycles
movlw 0x17
movwf d1
movlw 0x2F
movwf d2
movlw 0x03
movwf d3
Delay_0
decfsz d1, f
goto $+2
decfsz d2, f
goto $+2
decfsz d3, f
goto Delay_0
;6 cycles
goto $+1
goto $+1
goto $+1
return
loop:
movlw b'00000001'
movwf Line1
movlw b'11110010'
movwf Line2
call   output
call Delay
movlw b'11100000'
movwf Line1
movlw b'10101010'
movwf Line2
call   output
call Delay
goto loop
start:
clrf  TRISA
clrf  TRISB
goto loop
output:
   movfw   Layer4
   andlw   b'00000001'
   movwf   Time
   incf   Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   clrf   PORTB         ; clear port B
   movfw   Line1         ; move layer1 to W
   movwf   PORTC         ; put W onto PortC
   bsf      PORTB,4         ; turn on layer 1 buy outputing bit 5 of PortB
   movfw   Brightness      ; put brightness into W
   call   Delayy         ; call the delay
   bcf      PORTB,4         ; turn off layer 1
   movfw   Brightness      ; put Brightness into W
   sublw   4            ; sub W from 4
   btfss   STATUS,Z      ; skip if the zero flag is set
decfsz   Time
   movfw   Line2         ; move Line2 to W
   bsf      PORTB,5         ; turn on layer 2 buy outputing bit 6 of PortB
   bcf      PORTB,5         ; turn off layer 2
decfsz   Time
decfsz   Time         ; decrement the Time regiester
return
Delayy:
   movwf   Delay3         ; put W into Delay 3
Loop1:
                     ; After Delay2 decreses to 0, it is reset to..
   movlw   0x1            ; put 1 into W
   movwf   Delay2         ; put W into Delay2
Loop2:
                     ; After Delay1 decreses to 0, it is reset to E9h
   movlw   0x1D         ; put 80 into W
   movwf   Delay1         ; put W into Delay1
Loop3:
   decfsz   Delay1         ; decrement Delay1
   goto   Loop3         ; jump back to Loop3
   decfsz   Delay2         ; decrement Delay2
   goto   Loop2         ; jump back to Loop2
   decfsz   Delay3         ; decrement Delay3
   goto   Loop1         ; jump back to Loop1
   return
end
PranešimasParašytas: 2011 01 10, 13:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
centronic
Kažkada dariau su pic16f84
Kodas:
;  *  PIC16F84 4MHz begantis tekstas *
LIST p=16F84
#include <p16f84a.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
;  *  kintamieji *
sk0    equ 20h
sk1    equ 21h
sk2    equ 22h
sk3    equ 23h
temp    equ 24h
count    equ 25h
speed   equ   26h
count2  equ 27h
speed2  equ 28h
disp   equ   30h
disp2   equ 38h
;  *  org 0x00 *
   org 0x00
   goto   pic_reset
;  * raides *
;  * visos raides aprasomos programos pradzioje
;  * maks. raidziu skaicius 20 (jei raide uzima 8x8
;  * kaip pvz.: raide_mm) nes naudojami tik 8
;  * bitai PC (PCL)
raide:
   movwf   PCL
raide_a:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'01111110'
   retlw    b'10010000'
   retlw    b'10010000'
   retlw    b'01111110'
raide_e:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'11111110'
   retlw    b'10010010'
   retlw    b'10010010'
   retlw    b'10000010'
raide_s:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'01100100'
   retlw    b'10010010'
   retlw    b'10010010'
   retlw    b'01001100'
raide_j:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'10000100'
   retlw    b'10000010'
   retlw    b'10000010'
   retlw    b'11111100'
raide_k:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'11111110'
   retlw    b'00010000'
   retlw    b'00101000'
   retlw    b'11000110'
raide_t:
   movlw   .4
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'10000000'
   retlw    b'11111110'
   retlw    b'10000000'
raide_u:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'11111100'
   retlw    b'00000010'
   retlw    b'00000010'
   retlw    b'11111100'
raide_n:
   movlw   .5
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'11111110'
   retlw    b'00100000'
   retlw    b'00010000'
   retlw    b'11111110'
raide_taskas:
   movlw   .3
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'00000110'
   retlw    b'00000110'
raide_clr:
   movlw   .8
   movwf   count2
   movf   PCL,W
   call   load_sym
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
   retlw    b'00000000'
;  *  begantis tekstas "KAJUS.NET " *
loop:
   call   raide_k
   call   perstumti
   call   raide_a
   call   perstumti
   call   raide_j
   call   perstumti
   call   raide_u
   call   perstumti
   call   raide_s
   call   perstumti
   call   raide_taskas
   call   perstumti
   call   raide_n
   call   perstumti
   call   raide_e
   call   perstumti
   call   raide_t
   call   perstumti
   call   raide_clr
   call   perstumti
   goto   loop
;  *  uzkrauti simboli i display ram - 0x30..0x37 *
load_sym:
   movwf   temp
   movlw   .1
   addwf   temp,F   ;PCL+1
   movlw   disp2
   movwf   FSR
   clrf   count
load_loop:
   movf   temp, W
   addwf   count, W
   call   raide
   movwf   INDF
   incf   count, F
   movf   count2,W
   subwf   count, W
   btfsc   STATUS,Z
   return
   incf   FSR, F
   goto   load_loop
;  *  atvaizduoti simboli *
display:
   movf   speed, W
   movwf   speed2
dispp:
   movlw   disp
   movwf   FSR
   clrf   count
disp_loop:
   movf   INDF, W
   movwf   PORTB
   call   pauze1ms
   clrf   PORTB
   incf   count
   movlw   .8
   subwf   count, W
   btfsc   STATUS,Z
   goto   _rs
_cl:
   call   _clock
   incf   FSR
   goto   disp_loop
_rs:
   call   _reset
   decfsz   speed2
   goto   dispp
   return
;  *  perstumti simboli *
perstumti:
;   movlw   .8
;   movwf   count2
p0_loop:
   call   display
   movlw   .15
   movwf   count
   movlw   disp+1
   movwf   FSR
p_loop:
   movf   INDF, W
   movwf   temp
   clrf   INDF
   decf   FSR
   movf   temp, W
   movwf   INDF
   incf   FSR
   incf   FSR
   decfsz   count
   goto   p_loop
   decfsz   count2
   goto   p0_loop
   return
;  *  cd4017 valdymas *
_reset:
   bsf      PORTA,1
   nop
   nop
   nop
   bcf      PORTA,1
   nop
   nop
   nop
   return
_clock:
   bsf      PORTA,0
   nop
   nop
   nop
   bcf      PORTA,0
   nop
   nop
   nop
   return
;  *  pauzes *
pauze1ms:
   movlw   .75
   movwf   sk0
   movlw   .2
   movwf   sk1
   decfsz   sk0
   goto   $-1
   decfsz   sk1
   goto   $-3
   return
pauze200ms:
   movlw   .0
   movwf   sk0
   movlw   .0
   movwf   sk1
   movlw   .6
   movwf   sk2
   decfsz   sk0
   goto   $-1
   decfsz   sk1
   goto   $-3
   decfsz   sk2
   goto   $-5
   return
;  *  programos pradzia *
pic_reset:
   clrf   PORTB
   clrf   PORTA
   bsf      STATUS,5
   clrf   TRISB
   movlw   b'01100'
   movwf   TRISA
   bcf      STATUS,5
   movlw   .15
   movwf   speed
   call   _reset
   goto   loop
end
schemą įdėsiu vėliau - jei dar rasiu.
PranešimasParašytas: 2011 01 10, 18:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
mindaugs
Dekui, ismeginsiu koda. Wink
PranešimasParašytas: 2011 01 10, 19:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
centronic
Turetu but taip, biski lieva kokybe http://www.youtube.com/watch?v=wT-pqtgDmjs&feature=mfu_in_order&list=UL
PranešimasParašytas: 2011 01 10, 20:16 Pranešti apie taisyklių pažeidimą Atsakyti su citata
mindaugs
Dekui uz nuoroda. Dar turiu klausima is sio kodo:
Kodas:
output:
   bcf      PORTB,4
   movfw   Line2
   movwf   PORTC
   bsf      PORTB,5
   movfw   Brightness
   call   Delay         ; call the delay
   bcf      PORTB,5         ; turn off layer 1
virsuje pateiktas kodas iskarto atvaizduoja Line2, praleisdamas Line1. kaip pakeisti koda, kad Line1 ir Line2 galetu atvaizduoti vienu metu?
PranešimasParašytas: 2011 01 11, 11:30 Pranešti apie taisyklių pažeidimą Atsakyti su citata
centronic
Kodas:
loop:
   call   output
   goto loop
output:
   clrf   PORTB
   movfw   Line1
   movwf   PORTC
   bsf   PORTB,4
   call   Delay
   movfw   Brightness ;nereikalingas niekur nenaudojamas
   bcf   PORTB,4
   movfw   Line2
   movwf   PORTC
   bsf   PORTB,5
   call   Delay
   movfw   Brightness
   bcf   PORTB,5
   return
PranešimasParašytas: 2011 01 11, 14:26 Pranešti apie taisyklių pažeidimą Atsakyti su citata
mindaugs
Pakoregavau internete rasta programa ir pritaikiau savo pic16f876 mokroprocesoriui. programa veikia gerai, tik toje programoje yra Brightness nustatymai, del kuriu speju mano matrix displejus silpnokai sviecia. Kuo viename stulpelyje uzsidega daugiau diodu, tuo jie silpniau sviecia. Kodas:
Kodas:
LIST      P=16F876
ORG   0x2100
DE   0x00
ORG    0
cblock 0x20
   Delay1
   Delay2
   Delay3
   TimeDelay
   EndCount
   Counter
   Line1
   Line2
   Line3
   Line4
   Line5
   sad
   Line6
   Line7
   Line8
   Layer4
   Brightness
   Time
   Temp
endc
   goto   Start
Start:
   bsf      STATUS,RP0
   movlw   0
   movwf   TRISC
   movwf   TRISA
   movlw   b'00000001'
   movwf   TRISB
   bsf      STATUS,RP1
   bcf      STATUS,RP0
    bcf      STATUS,RP1
   bcf      EndCount,0
   clrf   Counter
   clrf   PORTB
snaige:
   movlw   b'10000001'
   movwf   Line1
   movlw   b'01000010'
   movwf   Line2
   movlw   b'00100100'
   movwf   Line3
   movlw   b'00011000'
   movwf   Line4
   movwf   Line5
   movlw   b'00100100'
   movwf   Line6
   movlw   b'01000010'
   movwf   Line7
   movlw   b'10000001'
   movwf   Line8
   movlw   b'11100111'
   movwf   Layer4
   call   Output
;snaiges kodas ilgas, tai ikeliau tik pvz.
   goto   snaige
Output:
   movfw   Layer4
   movlw   b'00000101'
   movwf   Brightness
   bcf      STATUS,C
   rrf      Brightness,1
   incf   Brightness,1
   movfw   Layer4
   andlw   b'00000001'
   movwf   Time
   incf   Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
   bcf      STATUS,C
   rlf      Time,1
Output2:
   clrf   PORTA
   movfw   Line1
   movwf   PORTC
   bsf      PORTB,4
   movfw   Brightness
   call   Delay
   bcf      PORTB,4
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTB
   movfw   Line2
   movwf   PORTC
   bsf      PORTB,5
   movfw   Brightness
   call   Delay
   bcf      PORTB,5
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTB
   movfw   Line3
   movwf   PORTC
   bsf      PORTB,6
   movfw   Brightness
   call   Delay
   bcf      PORTB,6
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTB
   movfw   Line4
   movwf   PORTC
   bsf      PORTB,7
   movfw   Brightness
   call   Delay
   bcf      PORTB,7
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTB
   clrf   PORTA
   movfw   Line5
   movwf   PORTC
   bsf      PORTA,0
   movfw   Brightness
   call   Delay
   bcf      PORTA,0
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTA
   movfw   Line6
   movwf   PORTC
   bsf      PORTA,1
   movfw   Brightness
   call   Delay
   bcf      PORTA,1
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   decfsz   Time
   clrf   PORTA
   movfw   Line7
   movwf   PORTC
   bsf      PORTA,2
   movfw   Brightness
   call   Delay
   bcf      PORTA,2
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   clrf   PORTA
   movfw   Line8
   movwf   PORTC
   bsf      PORTB,1
   movfw   Brightness
   call   Delay
   bcf      PORTB,1
   movfw   Brightness
   sublw   4
   btfss   STATUS,Z
   call   Delay
   decfsz   Time
   goto   Output2
   return
Delay:
   movwf   Delay3
Loop1:
   movlw   0x1
   movwf   Delay2
Loop2:
   movlw   0x1D
   movwf   Delay1
Loop3:
   decfsz   Delay1
   goto   Loop3
   decfsz   Delay2
   goto   Loop2
   decfsz   Delay3
   goto   Loop1
   return
tikrina
   BTFSS   PORTB,0
   GOTO    LINK
   nop
   return
end
kaip suprantu sviesumui reguliuoti skirti parametrai:
movlw b'11100111'
movwf Layer4
ir
Output:
movfw Layer4
movlw b'00000101'
movwf Brightness
bcf STATUS,C
rrf Brightness,1
incf Brightness,1
Visaip bandziau keitalioti siuos parametrus (panaikinus Brightness visai nebesviecia), taciau gaunasi tamsiau ar sviesiau, taciau vistiek stulpeliuose kur sviecia daugiau diodu, jie sviecia zymiai blankiau...
Beje mano matrix 8x8 displejus katodinis. bet turbut tai reiksmes neturi..
negi ner kas suprastu? :/
