Dabar yra 2026 06 04, 20:28. Visos datos yra GMT + 2 valandos.
 Forumas » Garso aparatūra » Stiprintuvas, kokių reta!
Puslapis 14
PranešimasParašytas: 2011 01 05, 16:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Contax
Na, ir ką gi galima pasakyt, paskaičius tokį aprašymą?
http://www.mutine.com/Fiches/Mutine_Fiche_CEC_AMP5300_En.pdf
Pažvelgus į radiatoriukus ir galios suvartojimą? Single Ended A class?
PranešimasParašytas: 2011 01 05, 17:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
Na ten ne tik tai "yra", pilna ir kitu panasiai abejotinu "stebuklu". Razz
The AMP-5300 features CEC’s exclusive load efect free (LEF) cir-
cuit to completely avoid all factors that result in deterioration
of sound quality ...
Every amplifer should be a perfect voltage
source. In theory, while the current into the speaker is likely out
of phase in relation to the voltage. The phase relation varies
with the frequency and is even dynamically moving. NFB am-
plifers are sensitive to this matter, specifcally to the dynamic
changes.
The LEF’s current control stage is not linked to the sig-
nal voltage, and just checks the current requirement that de-
pends on the speaker load without “knowing” about the phase
Tie potencialus audYofYlaY kuriems sis daiGtas yra siulomas reikia manyti nieko nezino apie bet kokios bendro naudojimo akustikos amplitudines-daznines charakteristikos netiesiskuma valdant ja sroviniu isejimo signalu be NGR.
The AMP-5300 also has an automatic bias adjust
function for stable signal processing.
The AMP-5300 is a Class A amp that features an extremely pure
single-ended circuit with each one single transistor for the
non-inverting and inverting lines, that handles all music sig-
nal processing. Earlier Class A amps were inefcient and had
extremely low output and generate considerable heat when
operating, but the AMP-5300 uses a load Efect free (LEF) circuit
to successfully combine high-efciency power with high-qual-
ity pure class A amplifcation. The primary technology of the
LEF is to avoid various sources of nonlinearities.
IGM volume control
The newly developed Intelligent Gain Management (IGM) sys-
tem is used to minimize signal loss during volume adjustment.
Sound volume is adjusted by controlling the gain itself with a
knob on the front panel.
The input signal is not degraded by
any mechanical volume resistor or CMOS device. As a result of
this, lowest noise, low distortion and highest dynamic perfor-
mance has been achieved.
Zodziu, eilinis "o mes i Saule skrisim!", o ypatingai durniems dar ir su paaiskinimais - "skrisim nakti!"
Ir eilini karta galima konstatuoti, kad durniai audYofYlaY perkantys tokius daiktus uz atitinkamai dideles kainas yra verti to, kad butu taip isdurinejami. Razz
"Aš čia, gyva!"
PranešimasParašytas: 2011 01 05, 17:42 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Ba1tuks
Jo, pritariu šitoje vietoje. Nieko nesakau, gražus, gražiai visus atrodo, bet... Pirma, negali čia būti arba A klasė arba 2x100W, nes radikas toks mažas... Mano 20W didesnį turėjo ir kaito kaip velnias...
Ten kažką suka labai gudriai apie pirštą, su kažkokiu A klasės signalo draiveriu, bet toliau visą tai vadina "Pure Class A Single-Ended Amp" Nu ir kurioje vietoje čia tas pure? Negrynas jis nifiga... Galas aiškiausiai AB... Čia atgauna tuos kurie nieko nenusimano šitame reikale... Toliau
Acoustone bottom plate
Newly developed “Acoustone”, that is a composite material
mainly including different kind of ceramics and binding resin,
is applied to the AMP-5300 bottom plate. Acoustone was
tuned for a maximum hardness ensuring low resonance and
high sonic speed, as well as a reasonable amount of elasticity
and damping. To make the best use of the Acoustone’s advantages,
metallic spike is applied to the AMP-5300 legs.
Už šitą nesamonę ir plešia bapkes...
Power supply 120 VAC - 60 Hz
Power consumption min. 60 W, max. 600 W
Nu ir kur tuos likusius 400W išsklaido? Laughing
Toliau pažiūrėkit kur eina signaliniai ir išėjimo laidai? Per kelis cm nuo trafo... Ir man patinka šitas:
THD 0.01 %/5O mW
Ant tiek net ir per ausines mažai ką girdėsi Laughing O kur THD(nėra dar ir THD+ N...) ant visos galios???
Verdiktas - Contax, aš ir dar daug kas gali pagaminti geresnį daug daug kartų Smile Tik gal ne tokį gražų Very Happy[/quote]
PranešimasParašytas: 2011 01 05, 18:54 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Babajuss
Na reikia juk ir teigiamų savybių rasti:
Gražus marketingas Wink
mane rasite: mano profilyje
PranešimasParašytas: 2011 01 05, 19:24 Pranešti apie taisyklių pažeidimą Atsakyti su citata
GSP
o gal bus kaip gramofone nagrinetame stipreke? Kad pirmi keli vatai A klasej dirba?
Anyway kad ir kiek jus cia blogo is technines puses prisaket, sitas stiprekas groja tikrai muzikaliai ir nesakau jog geriau ar blogiau uz kitus bet kad kitaip tai faktas. Seip esu dar kito CEC klauses nu matiko nors tu ka.
P.s. prieskonius maiste be galo megstu Very Happy
pp.s ir koks skirtumas kad susidaro netolygi daznumine be ngr, kambarys (o ypac "siuolaikinio remonto" ta daznumine +-15db patvarko, tai ar jau yra skirtumas? Galim taip pat ir ant lempos pradeti varyti kad sh ne stiprekai nes iskraipymai procentais skaiciuojami , tranzas cia jau atrodytu nenugalimas bet kazkodel yra kitaip Smile
Paskutinį kartą redagavo GSP, 2011 01 05, 19:26. Redaguota 1 kartą
PranešimasParašytas: 2011 01 05, 19:26 Pranešti apie taisyklių pažeidimą Atsakyti su citata
obalys
RVRSS rašo:
Viskas čia normaliai nereikia abejoti. Wink
Very Happy
PranešimasParašytas: 2011 01 05, 19:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
O taip, jei akys mato potenca, bet reklamoje parasyta, kad jo nera - reiskia, blin, JO NERA!
(kam nepatinka, uzsidekit tamsius nepermatomus akinius Razz )
"Aš čia, gyva!"
PranešimasParašytas: 2011 01 05, 20:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
GSP rašo:
o gal bus kaip gramofone nagrinetame stipreke? Kad pirmi keli vatai A klasej dirba? Tada cia yra tipiskas AB klases stiprekas Wink , galbut tik su didele rimties srove Rolling Eyes , bet visgi tai jis
Anyway kad ir kiek jus cia blogo is technines puses prisaket, sitas stiprekas groja tikrai muzikaliai ir nesakau jog geriau ar blogiau uz kitus bet kad kitaip tai faktas. Seip esu dar kito CEC klauses nu matiko nors tu ka. Muzikalumas deja yra subjektyvus, o konkreciu techniniu dalyku neadekvatumas - laimei objektyvus. Jei butu taip ir parasyta - "musu stipras labai muzikalus!", tai ir nesikabinetume
pp.s ir koks skirtumas kad susidaro netolygi daznumine be ngr, kambarys (o ypac "siuolaikinio remonto" ta daznumine +-15db patvarko, tai ar jau yra skirtumas? Skirtumas be jokios abejones yra (ir daznai manau artimas tiems 15db, paziurekime tipiskas garsiuku varzos priklausomybes nuo daznio kreives ir tada primeskime ka jie gros valdomi srove!), netgi jei ir butu klausoma tame siuolaikiniame kambaryje, kuris siuo atveju visiskai totaliai prasilenkia su tokio stipro keliamais uzmojais Galim taip pat ir ant lempos pradeti varyti kad sh ne stiprekai nes iskraipymai procentais skaiciuojami , tranzas cia jau atrodytu nenugalimas bet kazkodel yra kitaip Ar lempa ar tranzas - vis tiek meslas, tobulas antrinis irasyto garso atkurimas su siandieninemis technologijomis yra aplamai neimanomas, ir kas jo vaikosi vistiek tusciai svaisto jegas ir resursus, o ypac - pirkdamas tokius stiprus. Smile
Yra toks posakis - ieskoti juodos kates tamsiame kambaryje, ypac jei jos ten aplamai nera.
Protingas zmogus tai suprates pasistengtu kuo greiciau mesti toki tuscia uzsiemima, bet yra tokia issigimeliu kategorija - audYofYlaY, kurie vistiek uzsispyre iesko neziurint tos nykstamai mazos ir tik teorines galimybes ka nors kada nors visgi atrasti, ir baisiausia - jie vistiek ieskos net jei bus objektyviai irodyta, kad ten tikrai nieko nera! Razz
"Aš čia, gyva!"
PranešimasParašytas: 2011 01 05, 20:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
GSP
kur parasyta kad apskritai nera potenco? Parasyta kad ant iejimo signalo nera Exclamation jei jau taip kabinejates. Gal jis kur kitur ikistas ir istiesu iejimas yra kiaurai be jokio potenco
PranešimasParašytas: 2011 01 05, 20:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
GSP
o kadanors buvo imanomas? bus? ka tada rekomenduotum? Be stipreko sedeti? Pats sedi? Plec kartais kai paskaitai tokiu teiginiu tai atrodo tik imk ir pasikark
PranešimasParašytas: 2011 01 05, 20:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
Kur kitur jei stipras be "kenksmingo" NGR? Confused
Vel kazkas nesueina, kaip besuk. Laughing
Jei ir nepameluota, tai tendencingai nutyleta - as tai ir tokiu variantu nepasitikeciau Rolling Eyes , nors audYofYlams aisku geriau zinoti. Razz
"Aš čia, gyva!"
PranešimasParašytas: 2011 01 05, 20:33 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
GSP rašo:
Atsakysiu pavyzdziu is jau gana senos savo gyvenimo patirties.
Pries koki desimtmeti, kai jau beveik ziema ant nosies buvo, karta vakare netiketai uzvaziuoja pas mane grupe pazistamu vaikinu - automagnetola pajungti.
Na, kol as jungiu, masinos savininkas ir sako - klausyk, pas mane galinis stiklas kazko blogai syla, netolygiai.
Aha, sakau - tai pas tave ten matyt kai kurie sildytuvo siuleliai nutruke?
Sako, taip ir yra.
Gerai, sakau, yra trys galimi sprendimo variantai:
1. Keisti stikla i kita kuriame visi siulai veikia.
2. Bandyti atstatyti trukusius siulus nusipirkus specialiai tam skirtu laidziu kliju.
3. Susitaikyti su tuo, kad ne visi siulai veikia ir pasitenkinti tuo kas yra.
O, apsidziauge tas zmogus - labai saunu, trecias variantas pats geriausias! Cool
Net nustebau Surprised , kaip greitai buvo padaryta teisinga isvada. Very Happy
Deja, su audYofYlaYs yra kitaip - jie puse savo gyvenimo resursu pagatavi versdamiesi per galvas issvaistyti bandant pasiekti "tobula stiklo silima", nors aisku, kad tai neimanoma. Razz
(nes netgi ir su visais sveikais siulais stiklas vistiek kaista netolygiai Sad )
Tiems pamiseliams labai naudinga butu pasekti pavyzdziu to mano pazistamo ir dazniau gyvenime taikyti ta trecia varianta, o tada ziurek gal ir kokiai prasmingai veiklai daugiau laiko ir lesu atsiras. Wink
"Aš čia, gyva!"
PranešimasParašytas: 2011 01 05, 21:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
str
Neseniai daug muzikos klausiau su Vega312 Embarassed . Negirdėti kūriniai skamba labai blankiai. Bet tai, ką esu girdėjęs gyvai, skamba taip, kaip prieš 20 metų, nors dabar ir Vega aukštų neatkuria, o jei ir atkurtų, vistiek negirdėčiau.
Kaip čia vadinasi tas efektas, kai garsas iš kolonėlės tarsi tik sinchronizacija, iš atminties ištraukianti, o ausyse skamba taip, kaip kažkada girdėta?
PranešimasParašytas: 2011 01 05, 21:08 Pranešti apie taisyklių pažeidimą Atsakyti su citata
GSP
palauk nereikia taip kategoriskai apie audiofilus "neva iesko adatos sieno kupetos ar juodos kates tamsiame kambaryje kur jos net nera". Paimkim tarkim kad audiofilija yra hobis ir tas visas ieskojimas yra hobis. o kiekvienas hobis duoda savo kaifo. Pazvelkim i kitus hobius juk ten irgi entuziastai iesko tos pacios kates nors galetu susitaikyti Smile Paprasta kai tai nera hobis tuomet dziaugiesi tuo ka gauni ir tenkiniesi tuo kiek tai imanoma. Pvz tarkim automobiliu entuziastai, kiek pinigu yra kisama i automobili kad is jo gauti viena ar kita pagerejima, ar pagerinti esama savybe. Rezultatas niekad nebuna idealus tada jie vel iesko vel keicia, visa tai jiems teikia malonuma. Taip technokratiskiu poziuriu jie idijotai nes kiek sukisa seniai pasiimtu WRX ar STI ir dziaugtusi. Tai cia panasiai. Tai gal jie ne tokie ir kvaili kaip gali pasirodyti is pirmo zvilgsnio? As manau kad tai yra normalu. Kiti zinoma gali tureti ir kita nuomone tik nereik taip ziauriai Very Happy
PranešimasParašytas: 2011 01 05, 21:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
RVRSS
str rašo:
Gal tai "Deja vu"? Rolling Eyes
Pokstas Razz , manau, tai labiau panasu i Pavlovo tyrinetus gyvunu salyginius refleksus, na kai suniukai pripratinti valgyti pagal muzika pradedavo seiles varvinti net be jokio maisto dar tik jai suskambejus.
Deja, bet mus besivadinancius zmonemis tai irgi veikia - tik ne visi sugeba tai pripazinti, kai kurie vis issisukineja tame aukstu materiju ieskodami. Laughing
"Aš čia, gyva!"
