Dabar yra 2026 06 12, 10:49. Visos datos yra GMT + 2 valandos.
 Forumas » Autodiagnostika » 2001 sharanas 1.9 tdi pakeistas kompas
PranešimasParašytas: 2010 11 26, 14:38 Pranešti apie taisyklių pažeidimą Atsakyti su citata
clasicc
zodziu pakeistas kompas,seno visai nebuvo visai,jei nesunku kaip ji priryst,kad su immo nesipyktu :D ,turim tik vag-com ir kts.
PranešimasParašytas: 2010 11 26, 14:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
lagas
bandyk su vag-com, eini i varikli, adaptation(10), test, save, isjungi degima, palauki vedi.
PranešimasParašytas: 2010 11 26, 18:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
brazauskas
Some 2001+ Volkswagen/Audi vehicles have Immobilizer III. This works similarly to Immobilizer II, except a secret key code (SKC) is required in order to perform the adaptation routine. The routine changes depending on whether you are using a BRAND NEW ECU that has never been in any other car, or if you are using a USED ECU that has been previously matched to another car.
Immo-3 knows your car's VIN. Access 17-Instruments (or separate 25-Immobilizer on vehicles that are set up that way) and look at the first "Extra" field.
If you see something like: "Immo-ID VWZ7Z0W0648696" You've got Immo-2 (or maybe even Immo-1 in earlier non-US models).
If you see something like "WVZKB58001H231169 VWZ7Z0W0648696" You've got
Immo-3. The first 17-digit string is the VIN. The second 14-digit string in the Immo-ID.
There are different procedures for installing a new ECU or a usedECU.
NEW:
Before Installing a BRAND NEW ECU in vehicle, get the ECM coding from the old ECU in the vehicle
[Select]
[01 - Engine]
Write down the 5-digit Soft. Coding
[Close Controller, Go Back - 06]
[17 - Instruments]
Write down the 14 digit Immobilizer ID number from the "Extra" field
Take that 14-digit Immobilizer ID number (along with your VIN number) to your dealer and request your seven-digit SKC, along with the workshop code and importer number (all this information can be found in the upper-right corner of the Administration screen of the dealer's VAS 5051).
Install new ECU in the vehicle.
Measure the car's battery voltage, it must be 12.5 V or higher.
[Select]
[01 - Engine]
[Adaptation - 10]
Enter "50" in Channel Number
[Read]
[Use 7-digit PIN/SKC]
Enter the 7-digit PIN, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
VCDS will validate the data you have entered and return you to the Adaptation screen, where the New Value will show as "XXXXX".
[Test]
[Save]
[Done, Go Back]
Verify that the VIN now displayed in the "Extra" field matches the VIN on the vehicle code from dealer
[Go Back]
[Exit]
Turn ignition OFF and then back on within one minute, but do not start vehicle for two minutes
After 2 minutes, start the vehicle
[Select]
[01 - Engine]
Verify that the 5-digit Soft. Coding matches the coding from the old ECU
[Fault Codes - 02]
Clear all DTC's.
gal tai pades kiek, galima naudot ir vag-com.jei ten immo2 tai kita tvarka.
PranešimasParašytas: 2010 11 26, 22:51 Pranešti apie taisyklių pažeidimą Atsakyti su citata
xyznia
vyrai nevarkit,pirma gaukit pin koda jei sharanas naujam kebule 2001m jau immo3!
PranešimasParašytas: 2010 11 27, 12:56 Pranešti apie taisyklių pažeidimą Atsakyti su citata
clasicc
xyznia rašo:
jei nesunku smukkiau paiskink,su kuom,ir kaip gauti ta pin koda,isanksto aciu
PranešimasParašytas: 2010 11 27, 13:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
brazauskas
tai pin kodo gavimas turbut butu pats paprasciausias dalykas varyt pas elektrikus, jei tokios galimybes nera pvz. esant ne lietuvoje, tada perki VAG LOGIN READERi (usb) is interneto tipo vag tacho , bet tas gali trukt apie 2-3 savaites kol atsius, ir istrauki pin koda pek diagnostine fiske.jei skydelis VDO tai nemanau kad bus problemu.
PranešimasParašytas: 2010 11 27, 23:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
clasicc
brazauskas rašo:
tai panasiai ir padarem,pirkom vag- tacho ir viskas jau padaryta.vag-tacho per viena diena lietuvoj nupurkt galima Very Happy
