Dabar yra 2026 05 11, 20:53. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » VAG-COM vs VAG K+CAN commander
VAG-COM vs VAG K+CAN commander |
Parašytas: 2010 09 19, 16:01 |
| Gal kas galit apsviest kuom tas VAG K+CAN Commander 1.4 blogesnis/geresnis nei VAG-COM V805.1. Atrodo ir prie skydelio galima (su K+CAN) jungtis ir klaidas ziuret o kaina mazesne nei vag-com'o ? |
Parašytas: 2010 09 19, 19:46 |
paskirtis visai kita
vag-com,as dilerinio lygio diagnostime yranga
vag k-can programa "auksarankiams". tipo trina crashus, koreguoja rida.... aprasymas grazus. didesnio š... nesu mates (gal tik pas mane š... pasitaike. jei is zemieciu kas kitos nuomones butu ydomu isgirst) |
Parašytas: 2010 09 19, 21:35 |
K+can 1.4 nori veikia nori ne net ant tospacios auto perk line isvis nieko T4 spidometra atmete atgal per can lyg tai geriau.kaina nedidele atsipirko tai guli numestas
Vag-com jau 10.6.1 dilerinio lygio prietaisas |
Parašytas: 2010 09 21, 08:27 |
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter "channel number" 09 to select channel
Put in the number of km divided by 10. Example: If old cluster had 50,357 km, put in 5036.
Note: Some clusters may require a Login of 13861 before you can set the mileage.
[Test]
Observe the Instrument Cluster and make sure the mileage displayed is correct. Once you save this value, you will be unable to change the mileage EVER!
[Save]
Note: If you are installing an instrument cluster that has ever been installed in another car, you must insert the following step. Also, bear in mind that you will not be able to change the mileage of a cluster that has more than 100 km on the odometer): |
_________________ Kuo daugiau meistru, tuo daugiau darbo:)
CARCHIP Ltd |
