Dabar yra 2026 05 04, 01:12. Visos datos yra GMT + 2 valandos.
Forumas » Automobilinės apsaugos sistemos » Apsaugos sistemos pajungimas i Mazda 6 2004 m.
Apsaugos sistemos pajungimas i Mazda 6 2004 m. |
Parašytas: 2010 07 07, 10:16 |
Gal kas galetu pasidalinti dejimo niuansais ir laidu spalvomis siam automobiliui? kokie pavojai.sunkumai laukia?
Dekoju. |
_________________ Neturi ka parasyti nerasyk! arba pasipasakok zmonai  |
Parašytas: 2010 07 08, 09:16 |
2004 Mazda 6 Car Alarm and Remote Car Starter Wiring Information
Constant 12V+ Wire: Black
Constant 12V+ Wire Location: Ignition Switch Large Harness
Starter Wire (+): Black/Blue
Starter Wire Location: Ignition Switch Harness
Second Starter Wire (+): N/A
Start Wire Location: N/A
Ignition Wire (+): Blue
Ignition Wire Location: Ignition Switch Harness
Second Ignition Wire: N/A
Second Ignition Wire Location: N/A
Accessory Wire: Black/Red
Accessory Wire Location: Ignition Switch Harness
Second Accessory Wire: Black/White
Key Sense Wire (+): White/Blue
Key Sense Location: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Tachometer Wire: On the 4 cylinder models use NOT Black/White. On the 6 cyl models use NOT Green with Stripe
Tachometer Wire Location: Any ignition coil or coil pack. the wire that is NOT black/white.
Door Lock Wire (-): Light Green
Door Lock Wire Location: Driver kick or door lock module. Lock is negative trigger through a 1000 ohm resistor. MUST use relays. The door lock control module is located above the passenger kick panel.
Door Unlock Wire (-): Same as power lock wire
Door Unlock Wire Location: Driver kick or door lock module. Unlock is a straight negative trigger. The door lock control module is located above the passenger kick panel.
Door Trigger Wire (-): Green/Orange
Door Trigger Wire Location: Driver kick panel or door lock module. The door lock control module is located above the passenger kick panel.
Dome Supervision Wire: Yellow/Black
Dome Supervision Wire Location: Driver kick panel or door lock module. The door lock control module is located above the passenger kick panel.
Headlights Wire (-): N/A
Headlights Wire Location: N/A
Parking Light Positive Wire (+): Light Green/Black
Parking Light Positive Wire Location: Driver kick panel, 14 pin plug.
Parking Light Negative Wire (-): Red/White
Parking Light Negative Wire Location: Headlight Switch
Trunk/Hatch Pin Wire (-): Brown
Trunk/Hatch Pin Wire Location: Driver kick panel or door lock module. The door lock control module is located above the passenger kick panel.
Hood Pin Wire (-): Gray/Red
Hood Pin Wire Location: At pin switch or anti-theft module. The theft-deterrent control module is located in the center console.
Trunk/Hatch Release Wire (-): Yellow
Trunk/Hatch Release Wire Location: Trunk release switch or door lock module. The door lock control module is located above the passenger kick panel.
Factory Alarm Arm Wire: Blue
Factory Alarm Arm Wire Location: Driver kick panel or door lock module. Meter this wire while turning the key in the driver door key cylinder. Arm is negative trigger through a 1000 ohm resistor. MUST use relays. The door lock control module is located above the passenger kick panel.
Factory Alarm Disarm Wire (-): Same as factory alarm arm wire.
Factory Alarm Disarm Wire Location: Disarm is a straight negative trigger. MUST use relays. The door lock control module is located above the passenger kick panel.
Factory Alarm Disarm but No Unlock Wire (-): Use key sense wire.
Factory Alarm Disarm Wire Location: N/A
Horn Trigger Wire (-): Purple/White
Horn Trigger Wire Location: Horn trigger switch or door lock module. The door lock control module is located above the passenger kick panel.
Brake Wire (+): Green/Yellow
Brake Wire Location: Brake Pedal Switch
Emergency Parking Brake Wire (+): Brown
Emergency Parking Brake Wire Location: Emergency Parking Brake Switch
Share or Bookmark |
