Forumas » Autodiagnostika » req: ECU 038 906 018 GQ dump'as
req: ECU 038 906 018 GQ dump'as |
Parašytas: 2010 04 23, 11:02 |
sveiki, gal kas turite orginalu 038 906 018 GQ (0281010244) ecu dump'a?
1,9 TDI 99m
betkokia info welcome pm. |
Parašytas: 2010 04 24, 01:13 |
O kam tau jo reikia? Jei itari, kad kreivas, irasyk i nauja 24c02 pvz Atmel ir pabandyk buve tokiu atveju.
P.S. meila parasyk |
_________________ Kuo daugiau meistru, tuo daugiau darbo:)
CARCHIP Ltd |
Parašytas: 2010 04 24, 07:23 |
| keturi rašo: |
Kiek itariu cia ne epromo dampo iesko .. o flesho , ar kas ten 27c256 ar panasiai. |
Parašytas: 2010 04 25, 00:30 |
Visa esme, kad auto trukcioja riedant ~10km/h. Pakeiciau : siurbli(su valdimu), ecu, greicio davikli. Pakeles viena rata, ijunges 1 begi, su ranka suku greicio davikli ties 10km/h trukcioti pradeda ten ecu 038 906 018 BM
"Some TD 110s had a problem of stalling while coasting to a standstill from about 15 mph in neutral. The cure was to replace the ECU. This problem now seems to be coming back on high mileage TDI 110s. VAG acknowledges a fault with the ECU (038 906 018 BM) and specifies an upgraded unit (038 906 018 GQ) at £695.00 + VAT. According to VAG technical, this problem will eventually occur with all ECUs of this part number, so a second hand part may only be only a short term cure." |
Parašytas: 2010 04 25, 00:34 |
| liuxx rašo: |
| keturi rašo: |
viena aki uzmetes buvau tai atrodo kazkas panasaus, tik dvi plcc, pirmadieni reiks pratest  |
Parašytas: 2010 04 25, 00:37 |
| keturi rašo: |
noriu is (038 906 018 BM) padaryti (038 906 018 GQ) soft: (0281010244), bandyk admin@pramoga.com . |
Parašytas: 2010 04 25, 01:39 |
turiu ko tau reikia. kiek supratau kalba eina apie golf4. Tiesa tau geriau vienu failu, ar atskirus nes kiek zinia eepromkes dvi:) beje pasitikrink ar jos nebus vienkartines arba parasyk ju numerius |
GTA 6 Map,
GTA 6 Vehicles,
GTA 6 Character |
