Dabar yra 2026 04 26, 16:33. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » Opel Frontera 97m 2.5 TDS klaida (isspresta)
Opel Frontera 97m 2.5 TDS klaida (isspresta) |
Parašytas: 2010 03 03, 14:12 |
OP-COM 090820b - PC based diagnostic tool
OP-COM - KW2000 Communication Window> 1997|Frontera|Engine| 25 TDS
Keyword #1: 6B
Keyword #2: 8F
Normal timing parameter set.
VIN: Not programmed
vehicleManufacturerECUHardwareNumber 91154825 AN
systemSupplierECUHardwareNumber: 1001492
systemSupplierECUSoftwareNumber: P076V33
systemSupplierECUSoftwareVersionNumber: 02
exhaustRegulationOrTypeApprovalNumber: VM41B
systemNameOrEngineType: 25TDS
Identifier: 0503
Total number of fault codes: 2
P1725 - Injection Start Sensor Circuit Range/Performance
(0E) - Not present
P1572 - Immobiliser No Frequency Code Received
(0A) - Not present
GAL KAS ZINO KA REISKIA PIRMA KLAIDA, KUR PROBLEMOS IESKOTI? |
Paskutinį kartą redagavo xedos888, 2010 03 05, 11:45. Redaguota 1 kartą |
Parašytas: 2010 03 03, 21:57 |
Nu bet dar vaziavo su ta klaida ilgai, o siandien isvis cirkai su mano Frontera darosi, nulekiau iki parduotuves ryte, uzgesinau, uz desimt minuciu kuriu ir niekaip neuzkuriu, parsitempiau namo, pajungiau op com'a ir likau apakes:
Total number of fault codes: 8
(0E) - Not present
(0A) - Not present
P1225 - Fuel Injection Quantity Control Circuit Incorrect Signal
(0A) - Not present
P0100 - Mass Air Flow Sensor Circuit Low Input
(02) - Not present
P1220 - Fuel Injection Quantity Control Excessive Detected (Cold)
(0A) - Not present
P0400 - Exhaust Gas Recirculation Circuit Open
(04) - Present
P1630 - Injection Start Control Circuit Open
(04) - Present
P1635 - Glow Device Circuit Open
(04) - Present
Kaip ne is sio nei is to tiek klaidu atsirado, klaidos NEISSITRINA, AUTO NESIKURIA. |
Parašytas: 2010 03 03, 22:32 |
| gali buti, ilgokai bandziau uzkurti, uzdejau nakciai krautis. Bet tai kodel nesikuria, bandem ir ant buksyro kurt, niekaip. Kai dariau diagnostika, measure blokuose akumas rode 12.1V |
Parašytas: 2010 03 04, 02:15 |
(04) - Present
(04) - Present
(04) - Present
P0400, si klaida itakos uzvedimui neturi, P1630, ziurek, kazkur su jungtim ar laidais bus beda (jei teisingai suprantu gyveni UK, tai manu del vertimo bedu nebus), P1635 cia jau stebuklingos pakaitinimo zvakes, arba nuo kazkurios laidas nutrukes, arba nepavyko kokios nors atsukti ir ji nuluzo:-) |
