Dabar yra 2026 05 15, 09:00. Visos datos yra GMT + 2 valandos.
 Forumas » Radioelektronika – imtuvai » DEGEN DE1103
 DEGEN DE1103
PranešimasParašytas: 2009 06 05, 20:22 Pranešti apie taisyklių pažeidimą Atsakyti su citata
LY1
Aprašymas: http://www.radioscanner.ru/receivers/review/degen1103_eng.html
Modifikavimai:
"A engineer who ever work in DEGEN show a secret of DEGEN DE1103 on a
shortwave forum in china. The engineer want every swl who ever use
DEGEN DE1103 remember him. He made a small program in DE1103║╞s
software and it can let DE1103 auto scan from 000KHZ~29999KHZ
continue and not only scan in a sw band.
First, input 21951KHZ on sw. (the engineer║╞s worker number is 21951)
Second, At the same time press both ║╟BAND+║╠ Button and ║╟BAND-║╠
Button for a second then the radio will auto scan down until 000KHZ
and memorize one of frequency. If you want scan continue, use the
memory and scan."
It is possible to tune the 1103 receivers below 100kHz, and to
disconnect the internal ferrite rod antenna on MW + LW, by using
this simple procedure with the SCAN function.
Normally, a 'scan' will remain within the selected band, with
the tuning scale showing progress through the band. If you start
a scan from outside a band, the scan will become 'trapped' within
the next band that is reached. However, starting between 1 & 9kHz
above any band upper edge and scanning down, will bypass the 'band'
system, and will not switch to the ferrite rod in the range 1710 -
100kHz. The tuning will also continue below 100kHz.
So, select 1711 by direct entry:
[1] [7] [1] [1] [band+/AM]
and scan down: hold [BAND-] for 2 seconds.
As soon as the frequency is below 1710kHz you can stop the scan and
use the rotary control, or you can let the scan continue below 100kHz.
The antenna is now switched for the telescopic or external antenna.
I suggest you tune it down to zero and store this in preset 0, or store
99kHz in preset 99. Also store any frequencies for which you wish to
use the external antenna input. You can store any frequency with the
[SSB] mode 'on' for CW reception.
Once you tune above 1710 again, the system will revert to the normal
tuning range with the ferrite rod for MW + LW.
There has been a suggestion that you must start the scan at 21951kHz
because that was the designer's employee number, but that story is
apocryphal!
http://www.radioscanner.ru/info/radio/degen2.php
http://mods.radioscanner.ru/degen/mod29/
Pagaliau gavau šį imtuvą ir labai juo džiaugiuosi Wink
p.s gal kas turit tokį patį?
