Dabar yra 2026 05 08, 17:08. Visos datos yra GMT + 2 valandos.
 Forumas » Autodiagnostika » del audi a6
 del audi a6
PranešimasParašytas: 2009 05 31, 15:36 Pranešti apie taisyklių pažeidimą Atsakyti su citata
neriuks007
sveiki kaip audi a6 2006 pakeisti gale kaladeles? ten rankinis elektrinis ir sako reikia su kompu ji atleisti kad suvaziuotu gilin?
 del audi a6
PranešimasParašytas: 2009 05 31, 18:33 Pranešti apie taisyklių pažeidimą Atsakyti su citata
deklafosas
be kompo nieko nepadarysi
 del audi a6
PranešimasParašytas: 2009 05 31, 19:52 Pranešti apie taisyklių pažeidimą Atsakyti su citata
neriuks007
tai as turiu,idomu kur ka suvesti?
 del audi a6
PranešimasParašytas: 2009 06 01, 00:07 Pranešti apie taisyklių pažeidimą Atsakyti su citata
keturi
Open Rear Parking Brake
Prerequisites:
Connect a battery charger.
Cycle the Parking Brake ON, then OFF first.
[Select]
[53 - Parking Brake]
[Basic Settings - 04]
Group 007
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The brake calipers will then open, allowing the pads to be changed.
[Done, Go Back]
[Close Controller, Go Back - 06]
It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
Close Rear Parking Brake
Prerequisites:
[Select]
Group 006
[Go!]
[ON/OFF/Next]
The brake calipers will then close.
[Done, Go Back]
The LED in the parking brake switch and the warning lamp in the instrument cluster will probably continue to blink rapidly. This should stop after cycling the Parking Brake ON, then OFF again.
Function Test
Prerequisites:
[Select]
Group 010
[Go!]
[ON/OFF/Next]
The brake pads are now opening and closing 3 times.
Wait 30 seconds after the the brakes stop making noise.
[Done, Go Back]
Longitudinal Acceleration Sensor (G251)
Prerequisites:
System voltage at least 12.0 V.
Car parked on a level surface.
Do NOT move/rock car while performing basic setting.
[Select]
Group 020
[Go!]
[ON/OFF/Next]
The status of the Longitudinal Acceleration Sensor (G251) is now beeing displayed.
[Done, Go Back]
CARCHIP Ltd
 del audi a6
PranešimasParašytas: 2009 06 01, 18:45 Pranešti apie taisyklių pažeidimą Atsakyti su citata
neriuks007
dekui-keturi,skolingas alaus.
