Dabar yra 2026 06 06, 19:05. Visos datos yra GMT + 2 valandos.
Forumas » Automobilinė garso aparatūra » Orginalus magas + lineikos
Orginalus magas + lineikos |
Parašytas: 2009 05 06, 16:48 |
seveiki turiu peugeot 406 2000m, ten stovi orginalus magas, noreciau isideti zemadazni i bagazine.
ar butu imanoma is orginalaus mago isvesti lineikas?
o gal tinka toks variantas:
http://www.nexxia.co.uk/car_stereo_fitting_kits/images/PC9-450.jpg
kaip suprantu is aprasymo vietoj galiniu koloneliu signalo gauname line-out
PC9-450
This adaptor can be used to provide a low level line output from a factory fitted head unit that doesn't have RCA outputs. It means you can run an amplifier from the existing original fitted radio. It will cut the rear speaker channels and convert these to RCA outputs. If you car hasn't got ISO connections for the head unit then you could use a SOT lead from the Telemute range to do this.
kur galima butu lietuvoj nusipirkti toki perejima? |
Parašytas: 2009 05 06, 16:54 |
| Butu neblogai mago galine dali pamatyti (kokios fiskes yra) ar bent jau modeli (Clarionas ar Blaupunktas ar dar kas nors) |
_________________ geriau pilvas nuo alaus,nei kupra nuo darbo.
PANEVEZYS |
Parašytas: 2009 05 07, 08:42 |
| bunbastik rašo: |
clarionas, o isemes dar nebuvau, kai islupsiu paziuresiu kokios ten jungtys... |
