Dabar yra 2026 05 12, 02:36. Visos datos yra GMT + 2 valandos.
 Forumas » Garso stiprintuvai » pirmas tranzinis stiprius
PranešimasParašytas: 2009 04 21, 18:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
tranzistorius
tai wa sutweriau mini mosfetini stiprintuvuka ir kaip jy pajungiu tranzai kaista zaiurej ka daryt Embarassed Embarassed gali but del to kad potencai turi buti 2k o as dejau 2k2m rusiskus ??????
PranešimasParašytas: 2009 04 21, 18:43 Pranešti apie taisyklių pažeidimą Atsakyti su citata
tranzistorius
Connect the Power Supply Unit (previously tested separately) to the Power Amplifier but not the Preamp: the input of the Power Amplifier must be left open.
Rotate the cursor of R4 fully towards Q1 Collector.
Set the cursor of R3 to about the middle of its travel.
Connect a suitable loudspeaker or a 8 Ohm 20W resistor to the amplifier output.
Connect a Multimeter, set to measure about 50V fsd, across the positive end of C5 and the negative ground.
Switch on the supply and rotate R3 very slowly in order to read about 23V on the Multimeter display.
Switch off the supply, disconnect the Multimeter and reconnect it, set to measure at least 1Amp fsd, in series to the positive supply (the possible use of a second Multimeter in this place will be very welcomed).
Switch on the supply and rotate R4 very slowly until a reading of about 120mA is displayed.
Check again the voltage at the positive end of C5 and readjust R3 if necessary.
If R3 was readjusted, R4 will surely require some readjustment.
Wait about 15 minutes, watch if the current is varying and readjust if necessary.
Please note that R3 and R4 are very sensitive: very small movements will cause rather high voltage or current variations, so be careful.
Those lucky enough to reach an oscilloscope and a 1KHz sine wave generator, can drive the amplifier to the maximum output power and adjust R3 in order to obtain a symmetrical clipping of the sine wave displayed.
Ce yra intsrukcija
PranešimasParašytas: 2009 04 21, 18:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Mentality_Zero
tai ja ir naudokis Very Happy
PranešimasParašytas: 2009 04 21, 22:20 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Enshteinas
tranzistoriau, schema mestelk
PranešimasParašytas: 2009 04 22, 09:01 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vsa
Prieš pirma jungima atsuk potenca kuris reguliuoja Io taip ,kad butu min R,pamatuok kiek mv out-e /be apkrovos/.Jeigu 0-100mv-gerai;virš 100 mv-ieškok klaidu.Tik po to derink Io.Aišku, duok shema.Galiniai transai aišku pas tave ant radiko per zeruti su termopasta?Jeigu yra shema su termokompensacija - ne pamiršai transa prisukti prie radiko ?/aišku per zeruti su termopasta/.
PranešimasParašytas: 2009 04 22, 14:09 Pranešti apie taisyklių pažeidimą Atsakyti su citata
tranzistorius
jo izoliuota viskas bet man jie kaista ziaurej susvilinau vakar vienas tik nudege
http://www.redcircuits.com/Page123.htm
visas tinklapis jo
PranešimasParašytas: 2009 04 23, 11:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vsa
Man tokia shema ne patinka.Ko gero generacija.Nera termostabilizacijos.bus jautrus triuk6mam,gali fonuot,butinai reikalingas stabilizuotas maitinimas.Jeigu nori toliau testi-gal padidink R i gates nuo 330Om iki 470-560 Om,tarp bases 1 transo ir mases ijunk ceram C 200-330pF 63v.Dar patikrink ar gerai sujingei GDS laukiniu ir EKB paprasto transo. Potencas R4 sureguliok i 0 Om,R3-per viduri.Ant pluso isejimo C turi buti apie 1/2 tavo maitinimo.Maitinima pajung per A mpermetra - ziurek kiek rodo mA.LABAI letai pasuk R4 kad butu 50mA,po to patikrink kiek V ant + Cout. R4 ir R3 tarp saves suristos.Ir ijeima geriau sujunk su GND.Visa sita daryk be preampo.Taip po biski didink Io iki 100mA kontroliodamas V ant + C out ir galiniu transu temperatura.Bet geriau paimk kita shema - pvz 25W MOSFET- as is Elektronikos archivo-stabilesne,jautri-nereikia preampo,nereikia stabilizuoto maitinimo,difkaskadas pats kovoja su pulsacijom per maitinima.-tik galinius geriau imk ne IRF. o 1058/162-jie patys termokompensuojasi.
