Dabar yra 2026 06 16, 00:04. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » Passat komforto modulio klaidos
Passat komforto modulio klaidos |
Parašytas: 2009 03 06, 20:02 |
Sveiki, jau uzsiknisau kariauti su passatu, savaite laiko grybauja gamykline signalizacija, isijungia ir kaukia, kartais nes su rakteliu nereaguoja i atrakinima/isjungima. Pries savaite skanavau su vag-com:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 1J0 959 799 AH
Component and/or Version: 3R Zentral-SG Komf. 0001
Software Coding: 04096
Work Shop Code: WSC 05311
Additional Info: 1J2959802D 3R Tõrsteuerger. FS0001r
Additional Info: 1J2959801E 3R Tõrsteuerger. BF0001r
Additional Info: 1J4959811D 3R Tõrsteuerger. HL0001r
Additional Info: 1J4959812D 3R Tõrsteuerger. HR0001H
14 Faults Found:
01328 - Convenience System Data Bus
35-10 - - - Intermittent
01334 - Door Control Module: Rear Right (J398)
49-10 - No Communications - Intermittent
01333 - Door Control Module: Rear Left (J388)
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
01389 - Tailgate Open Switch (F124)
29-10 - Short to Ground - Intermittent
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
01134 - Alarm Horn (H12)
37-10 - Faulty - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
00930 - Locking Module for Central Locking: Rear Left (F222)
00931 - Locking Module for Central Locking: Rear Right (F223)
taigi sugalvojau kad cia to modulio grybavimas, islupau sedyne, isemiau ta moduli, jokios korozijos nesimato, laidu aplink irgi pazeistu neradau, tiek kad jie apsale buvo. Istrynys klaidas po savaites vel praskanuoju :
11 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
36-00 - Open Circuit
37-00 - Faulty
27-00 - Implausible Signal
00934 - Electric Window Motor: Rear Left (V26)
is karto istrynus ir vel skanuojant randa tik sia:
1 Fault Found:
gal kas padetumet surasti problema ? Kur tie interior Monitoring sensors randasi? dekui
vw Passat 1.9 tdi 81kw AFN, 99 metai |
Re: Passat komforto modulio klaidos |
Parašytas: 2009 03 12, 17:11 |
| vortex rašo: |
O tu laidais nubek tolyn. |
Parašytas: 2009 03 13, 10:53 |
Interior monitor deactivation switch, cia jis yra ant kaires puses galiniu dureliu? Kazkaip jis nereaguoja i nieka, bandziau su vag-com atjungti ta interior monitoring sensor, kad ir atsijungia vistiek rekia signalizacija. dainiusdxf patare ziureti jungiklius durelese ir bagazineje, supurskiau WD visus, lauksiu gal pades. Dar vienas dalykas, vidinio apsvietimo lemputes visos kaip ir mirksi, atrodo kad kazkas trumpintusi, tik niekaip neatkasu kas ten netaip, jau puse masinos isardytos, o rezultato nulis. Ir dar kazka pridariau visi keturi langai nebeveikia  |
Parašytas: 2009 03 13, 15:15 |
| Kur laidai eina i ta bloka po vairuotojo kojomis buna tokie sujungumai, kur keli laidai i viena vieta supresuoti ir izoliuoti. Gal ten oksidacija paveike? O del langu tai ziurek duryse valdymo bloka, ar maitinima gauna. Ir termo saugiklis yra ant stiklu jegos pliuso. Prie pedalu netoli panasus i saugikli, tik metaliniame korpuse. |
Parašytas: 2009 03 13, 18:43 |
| ramaskinas rašo: |
taip, tikrinau cia kai lupau moduli, ten fiskiu gal 10, tai jas visas atjunginejau ir perziurejau, viskas atrodo tvarkingai, saugiklius tikrinau visi sveiki, iki langu pliusas ateina, ir girdisi kad tas blokas ciksi (visu keturiu) bet langai nesidarineja. O gal yra kokia rele langams ar dar kazkas, vag-com apie langus nieko nekalba... |
Parašytas: 2009 03 13, 18:47 |
| dar vienas dalykas atsirado, uzvedus masina ir atidarant dureles (nesvarbu kurias), kazkur prie spidometro sucypsi 4 kartus pypsikas, pirmas ilgesnis, kiti 3 trumpesni, anksciau nieks nepypsedavo... Ar nereiks ta pasata nudazyti zaliai ir i ezera, kad zuvu nebaidytu... |
Parašytas: 2009 03 14, 21:23 |
| Dar termo saugikli surask ir patikrink. Po kojom kairiau vairolazdes ant tolimesnio karkaso jis stovi. Toks metaloniame korpuse. Paziurek, ar darinejasi langai su duru uzrakinimo spyna. Ilgiau palaikyk pasukes rakta atrakindamas - atsidaryti turi, o uzrakinant ilgiau palaikius uzsidaro. |
Parašytas: 2009 03 15, 12:40 |
| paziurek bloka tarp pedalu ir vairuotojo sedynes grindyse po kilimu ,ten jis juodoj dezej dvi fiskes,daznai buna nuskendes ,kartais uztenka tik isdziovinti |
Parašytas: 2009 04 20, 11:54 |
| taigi atsilus orams dar karta viska isardziau ir radau nupuvusius 4 laidus prie komforto modulio,, visi pliusai, juos sulitavus viskas veikia tvarkingai, dekui uz patarimus |
Parašytas: 2009 04 21, 18:09 |
| ramaskinas rašo: |
Ar tik ne sitoje vietoje?  |
Parašytas: 2009 05 07, 10:00 |
visiskai teisingai tam sujungime ir buvo nupuve visi tie pliusai
| ramaskinas rašo: |
| ramaskinas rašo: |
