Dabar yra 2026 05 08, 07:44. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » Audi A4 per dideles apsukos
Audi A4 per dideles apsukos |
Parašytas: 2009 02 07, 15:30 |
Sveiki,yra problema su A4 1998m. 1.8 variklis 20V.Laisvos apsukos buna 1500.Praskanavus su Vag'u meta klaida "Trottle Body (J338) 17967 Foult in basic seting".Kaip suprantu cia reiketu padaryti sklendes adaptacija.Dekoju uz betkoke informacija.  |
Parašytas: 2009 02 08, 18:38 |
Throttle Body Adaptation:
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 060 (Group 98 in non-DBW engines)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB
adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in basic mode for about 30 seconds, then switch back to normal settings and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this! |
