Dabar yra 2026 05 09, 13:32. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » lcd asamblerio kode nesupratimas
PranešimasParašytas: 2009 02 06, 01:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
pcwortex
tokiame puslapyje http://www.8052.com/tutlcd radau kaip uzprogramuoti lcd 16x2 akraniuka. bet man tokia kodo vieta kelia nesupratimu
WAIT_LCD:
CLR EN ;Start LCD command
CLR RS ;It's a command
SETB RW ;It's a read command
MOV data,#0FFh ;Set all pins to FF initially
SETB EN ;Clock out command to LCD
MOV A,data ;Read the return value
JB ACC.7,WAIT_LCD ;If bit 7 high, LCD still busy
CLR EN ;Finish the command
CLR RW ;Turn off RW for future commands
RET
cia tokia eilute yra JB ACC.7,WAIT_LCD ; O pries ta eilute parasyta MOV DATA,#0FFh o pries ta eilute yra mov A,data, tai skaiciu ff ikelia A regstra. ir poto tikrina ar septintas A registro bitas yra vienetas ar ne. jeigu vienetas tai suolis vel i wait_lcd. tai cia gaunas kaip begalybes ciklas juk programiskai irasom A registro 7 bitus vienetus. niekaip tos vietos as nesuprantu Sad
 Re: lcd asamblerio kode nesupratimas
PranešimasParašytas: 2009 02 06, 10:12 Pranešti apie taisyklių pažeidimą Atsakyti su citata
R2D2
pcwortex rašo:
WAIT_LCD:
RET
po kodo prierašas:
Programming Tip: The above routine does the job of waiting for the LCD, but were it to be used in a real application a very definite improvement would need to be made: as written, if the LCD never becomes "not busy" the program will effectively "hang," waiting for DB7 to go low. If this never happens, the program will freeze. Of course, this should never happen and won't happen when the hardware is working properly. But in a real application it would be wise to put some kind of time limit on the delay--for example, a maximum of 256 attempts to wait for the busy signal to go low. This would guarantee that even if the LCD hardware fails, the program would not lock up.
kitaip sakant, reikia viską atidžiai perskaityti kai nesi tame dirbęs.
