Dabar yra 2026 05 03, 05:48. Visos datos yra GMT + 2 valandos.
 Forumas » Įvairūs » mikroschema!!!
 mikroschema!!!
PranešimasParašytas: 2005 02 08, 02:30 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vladas
sveiki! turiu mikroschema am27c512-175dc/t
pasiziurejau jos kaina lemonoi tai ji kainuoja virs 100LT kam ji skirta bandziau surasti apie ja informacijos bet lietuvisko nieko neradau ! gal kas zino kam ji reikalinga?
dekingas!!!
Lytuoji ir galvoji
 mikroschema!!!
PranešimasParašytas: 2005 02 08, 03:09 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ACC
The Am27C512 is a 512-Kbit, ultraviolet erasable programmable
read-only memory. It is organized as 64K
words by 8 bits per word, operates from a single +5 V
supply, has a static standby mode, and features fast
single address location programming. Products are
available in windowed ceramic DIP packages, as well
as plastic one time programmable (OTP) PDIP and
PLCC packages.
Data can be typically accessed in less than 55 ns, allowing
high-performance microprocessors to operate
without any WAIT states. The device offers separate
Output Enable (OE#) and Chip Enable (CE#) controls,
thus eliminating bus contention in a multiple bus microprocessor
system.
AMD’s CMOS process technology provides high
speed, low power, and high noise immunity. Typical
power consumption is only 80 mW in active mode, and
100 μW in standby mode.
All signals are TTL levels, including programming signals.
Bit locations may be programmed singly, in
blocks, or at random. The device supports AMD’s
Flashrite programming algorithm (100 μs pulses), resulting
in a typical programming time of 8 seconds.
http://www.datasheetarchive.com/datasheet/pdf/77/770310.html
 mikroschema!!!
PranešimasParašytas: 2005 02 08, 11:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
circuit
Lietuviškai ir nerasi. Nieko nerasi. Niekada...
 mikroschema!!!
PranešimasParašytas: 2005 02 08, 22:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Vladas
su ja ka nors galima padaryti iskytus pc ?
beje jeigu parduociau kur galima parduoti???
Lytuoji ir galvoji
