Dabar yra 2026 05 07, 16:02. Visos datos yra GMT + 2 valandos.
Forumas » Mikrovaldikliai » Houston we have a problem :(
Houston we have a problem :( |
Parašytas: 2008 09 22, 21:32 |
Sveiki tai va siandien pirma karta gyvenime sekmingai programatorius nuskaite procesoriu viskas buvo liux kol neisbandziau uzprogramuoti jo su arduino bootloaderiu
Viskas Prasidejo ant Labaratorines susirinkau sita:
be isvadu ir serialo tik visa kaire puse ir isp dalimi viskas liux ledai veikia kad programatoriu pajungiu.
Gerai isijungiam avrdude pagal aprsasyma pirma nustatom fuse's ir tuomet viskas prasidejo:
| Kodas: |
C:\arduino-0012-win\arduino-0012\hardware\bootloaders\atmega8>avrdude -v -c avri
spv2 -p ATmega8 -P com3 -U hfuse:w:0xCA:m -U lfuse:w:0xDF:m -U lock:w:0xFF:m
avrdude: Version 5.5, compiled on Jun 9 2008 at 14:32:04
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "C:\WinAVR-20080610\bin\avrdude.conf"
Using Port : com3
Using Programmer : avrispv2
AVR Part : ATMEGA8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max
W ReadBack
eeprom 4 20 128 0 no 512 0 0 9000 90
00 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 45
00 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 20
00 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0
0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0
0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP V2
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version: 2.10
Vtarget : 0.0 V
SCK period : 41.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9307
avrdude: safemode: lfuse reads as DF
avrdude: safemode: hfuse reads as CA
avrdude: reading input file "0xCA"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xCA:
avrdude: load data hfuse data from input file 0xCA:
avrdude: input file 0xCA contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xDF"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xDF:
avrdude: load data lfuse data from input file 0xDF:
avrdude: input file 0xDF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lock (1 bytes):
Writing | | 0% 0.00s ***faile
d;
Writing | ################################################## | 100% 0.14s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0xFF:
avrdude: load data lock data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x3f
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK
avrdude done. Thank you.
C:\arduino-0012-win\arduino-0012\hardware\bootloaders\atmega8> |
Bandem Daryti Flashinti flasha ir gavom vel klaida:
| Kodas: |
spv2 -p ATmega8 -P com3 -F -U flash:w:ATmegaBOOT.hex
Using Port : com3
AVR Part : ATMEGA8
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
W ReadBack
00 0xff 0xff
00 0xff 0x00
00 0x00 0x00
00 0x00 0x00
00 0x00 0x00
0 0x00 0x00
0 0x00 0x00
Vtarget : 0.0 V
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATMEGA8 is 1E 93 07
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: current erase-rewrite cycle count is -50462977 (if being tracked)
avrdude: erasing chip
avrdude: reading input file "ATmegaBOOT.hex"
avrdude: input file ATmegaBOOT.hex auto detected as Intel Hex
avrdude: writing flash (8170 bytes):
Writing | ############################################ | 87% 0.01savrdude:
stk500v2_command(): unknown status 0x80
avrdude: stk500v2_paged_write: write command failed
Writing | ################################################## | 100% 0.61s
avrdude: failed to write flash memory, rc=-1
Ir taip su visom naujom 3 atmegom speju as jas nuzudziau
Aprasimas Pagal kuri dariau http://tinkerlog.com/2008/01/07/arduino-on-a-prototype-board/
Prasau padekite nenoriu dar vienos zudyti  |
Parašytas: 2008 09 24, 09:13 |
| 90 % kad nieko nesugadinai tiesiog, neteisingai uzprograminai fuse bitu's isoriniam generatoriui. Dazna problema, apie sprendimus rasi sitam forume, ne viena karta diskutuota. |
_________________ -----
That's what she said. |
Parašytas: 2008 09 24, 17:03 |
viskas ten tvarkoj tik nemaciau kad isp resetas nedajungtas ant labaratorines pajungiau vieoj pusej ir masciau kad bus ok o tik kai perziurejau viska supratau kad nepersoko i kita puse ir dar sugebejau netaip buttona pajungti tai visalaika gaudavosi kad man jis reset sededavo todel avr studio tik viena veiksma beatlikdavo  |
