Dabar yra 2026 05 04, 05:01. Visos datos yra GMT + 2 valandos.
 Forumas » Autodiagnostika » klaida-1087 neatlikti baziniai nustatymai
PranešimasParašytas: 2008 08 29, 08:26 Pranešti apie taisyklių pažeidimą Atsakyti su citata
art64
Stai tokia klaida ismete VAG COM'as ant 1996m. benzininio 1,6l Golfuko ,variklio ECU lange,kurio variklio kodas AEE ir deze DGH.Buvo ir daugiau gedimu:temperaturinis dav.,droselio t.e. jungiklis,bet po daviklio pakeitimo ir atminties isvalymo, liko tik si klaida. VAG COM'o,variklio ECU lange ,kur yra eilute "kodavimas",ten tuscia,o as taip suprantu,ten turi buti kazkokie skaiciukai.Kokie ten jie turi buti tokiai masinytei ir kaip ECU galejo juos pamesti?Varikliu remontais neuzsiimu,si masina -atsitiktine,todel mazai ir zinau:)
PranešimasParašytas: 2008 08 29, 13:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
turgis
Jei angliskai supranti,tai viskas surasyta.Pries darant sita reikala sitokie reikalavimai turi but ispildyti:
No DTC's in the Engine Controller
Battery voltage at least 11.5 V
Throttle must be at idling position (keep your foot off the gas pedal)
Throttle body part must not be dirty (carbonized).
Coolant temperature must be between 5 and 95C
Cable-Throttle Engines
(These are engines with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.)
Darymas:
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Enter Group 001 (Note: Simos ir Marelli blokams naudojamas 001 kanalas,kitiem blokams 098 ar 060)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click the [Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Va taip sitam varijante ivykdomi baziniai nustatymai.O kad nematai coding,tai cia Marelli valdymo blokas.Apie jo coding nieko neparasyta.
PranešimasParašytas: 2008 08 29, 13:18 Pranešti apie taisyklių pažeidimą Atsakyti su citata
art64
aciu
PranešimasParašytas: 2008 09 11, 23:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
art64
turgis rašo:
Darymas:
[Select]
[01 - Engine]
[Go!]
Nepavyko man tokiu keliu atlikti bazinius nustatymus-klaida isliko ir mazos variklio apsukos isliko(apie 600aps/min).Ijungiant bazinius nustatymus apsukos sukyla iki baziniu(~850),bet perjungiant atgal ar uzdarant programa neissisaugo ir mineta klaida isiraso i atminti.Siaip,viska panasiai dariau ir pirma karta prisijunges, neskaites sito.Kazka kitaip reiktu daryti?
PranešimasParašytas: 2008 09 12, 10:13 Pranešti apie taisyklių pažeidimą Atsakyti su citata
turgis
Neatidziai skaitai.Kokios apsukos.Variklis ant degimo ir neuzvestas.
"Turn the key on but do not start the car"
PranešimasParašytas: 2008 09 13, 00:07 Pranešti apie taisyklių pažeidimą Atsakyti su citata
art64
Ne,skaiciau atidziai ir atrodo dariau atidziai-dariau neuzvesta ir nelieciant gazo pedalo,bet kai neisejo(pora kartu bandziau) ,tai emiau bandyti visaip.Pastebejau,kad esant uzvestam varikliui apsukos sukildavo iki normaliu, kai paspausdavau "bazinius nustatymus".
Dar apie si reiskini noriu pasakyti:
[Once you do this you will see the top right display say ADP RUN] ECU "apmokymo" metu jis irgi nevyko,jokio uzraso nemaciau-nezinau kodel.
Galima butu vazineti ir toliau taip,su sia klaida,bet uzvedus salta,ypac rytais ,reikia gazuoti kol isyla,nes gesta.Varikliui susilus, apsukos buna~600 aps/min
PranešimasParašytas: 2008 09 13, 00:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
GT
Ir as turejau beveik tokia pacia problema su 98 ibiza (polo) 1.4L (APQ) varikliu. Klaida 1087, pagal ELSA turi adaptuotis 098 kanale, tik parinkus ta kanala 0.5sek pasirodo reiksmes ir uzraso, kad sis kanalas "not available"... Ka daryti ?
PranešimasParašytas: 2008 09 15, 21:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
taurijus
Peržiūrėti vartotojo aprašymą Siųsti asmeninį pranešimą AIM adresas
GT rašo:
Aš irgi visai neseniai susidūriau su ta pačia problema.POLO 98m.1.4 variklis.pilnas ipurškimas.Negalėjau padaryt bazinio išstatymo.Trosas neįtemptas,potencai sklendės ir varikliuko padeties geri.Pabandėm kitą kompą- nepadėjo.pajungėm kitą tokią pat visą sklendę tada padarėm ir tai iš kokio trečio karto.Paskui pajungėm tą pačią orginalią (to automobilio)sklendę.Ir su ja pasidarė išstatymas.Taigis likau nesupratęs kame šaknys.Mašina neseniai pirkta,neaišku kaip viskas buvo anksčiau.Išleidom žmogų pavažinėt kokią savaitę,paskui reiks vėl pažiūrėt.
