Dabar yra 2026 06 12, 03:43. Visos datos yra GMT + 2 valandos.
Forumas » Automobilinės apsaugos sistemos » Signalizacija i Peugeot 407
Signalizacija i Peugeot 407 |
Parašytas: 2008 08 28, 09:01 |
Gal teko susidurti ,kokios spalvos ,kur rasti laidus? Desiu ne CAN'ine i Peugeot 407 2005m. 2.0HDI.
Isanksto dekoju. |
Parašytas: 2008 08 28, 11:25 |
TURN SIGNALS:
a. Front and side L/H:
YELLOW
b. Rear L/H: GREEN
c. Front and side R/H: GRAY
d. Rear R/H: WHITE
All sized 0,75 mm2.
a. c. Connector: BLACK 28-way marked
with PP2, attached to the fuse box of the
engine compartment.
Position: NR 17 and NR 18.
b. d. Connector: GRAY 16-way marked with
EC1, attached to the control unit fitted
behind the moquette, in the luggage
compartment, from driver“s side.
Position: NR 5 and NR 4.
POSITIVE UNDER KEY:
GRAY 4 mm2.
Connector: BLACK 2-way marked with AA,
attached to the BSI control unit front.
Position: NR 2.
1ST ENGINE IMMOBILISER: (Starter motor).
LIGHT BLUE 2,5 mm2.
Connector: GRAY 5-way marked with PB,
attached to the fuse box of the engine
compartment.
Position: NR 2.
CENTRAL LOCKING: Diagram NR 32.
UNLOCK:
WHITE Ref. 8207
0,75 mm2.
LOCK:
0,75 mm2.
WHITE Ref. 6285
Connector: WHITE 22-way marked with
EH1, attached to the BSI control unit front.
Position: NR 27 and NR 4.
DOOR SWITCHES:
Front L/H: WHITE Ref. 82
Front R/H: WHITE Ref. 82
Rear L/H: GRAY Ref. 8288
Rear R/H: WHITE Ref. 828
All sized 0,75 mm2.
BONNET SWITCH:
YELLOW 0,75 mm2.
Attached to the original bonnet switch, fitted
is taves butelis |
Parašytas: 2008 09 03, 21:05 |
| Ar uzrakinant-atrakinant vairuotojo duru mikriko laide nesikeicia minusas i pliusa?kiek pamenu tai ten kazkas yra.As dejau pulteline sign.ir lygtai staciau papildoma galinuka. |
Parašytas: 2008 09 09, 00:50 |
| stasiss rašo: |
O nuo salono lemputes nepaprasciau butu paimti ? |
Parašytas: 2008 09 09, 13:35 |
| Salono apsvietimas valdosi+.Reikia statyti relike.Relike nuo mazejancios sroves birbia ir gali sukibti kontaktai.Man atrodo geriau nuo duru galinuku.Tada ir signalkes funkcijas visas gali pajungti. |
Parašytas: 2008 09 09, 20:15 |
| tai kad nebirbtu rele kondika pakabini ir gerai.nors nuo duru trigeriuku geriau aisku. |
Parašytas: 2008 09 13, 00:54 |
| stasiss rašo: |
Sakai nuo galinuku ? Teko paciam daryti P307, P407, P607 arba C4, C5 masinas ? |
Parašytas: 2008 09 13, 19:00 |
GT atsakau kad taip .O kame čia problema?Nesigailėk diodu,atskirk laidus,pastatyk 1 galinuką ir pajunk signalke su visom galimom funkcijom.
Šitie modeliai jau nebe egzotika o kasdienybė.Ypač P307. |
Parašytas: 2008 09 13, 21:06 |
| stasiss rašo: |
C5 problema tik su priekinėm durim ,reikia laidai atsivesti į duris, bet galinukų nereikėjo dėti nei į C5 senesnį, nei į naujesnį. |
Parašytas: 2008 09 13, 21:29 |
Tai kad man galinukas greičiau, ir garantuotai ,negu ardyt duris.Mano kaime
su pipsikais problema. |
Parašytas: 2008 09 16, 00:38 |
| stasiss rašo: |
Pabandytum pastatyti tu kokiam rimtesniam zmogui i 2007m masina galinuka... Galva sveika liktu ?
Beje, teko man paciam matyti P307 su istatytu i sonine paneles plastmase KAPOTINIU galinuku... Ne kur nors i stojke, o tiesiog matomiausioj vietoj ! |
Parašytas: 2008 09 16, 11:47 |
GT rašo;Beje, teko man paciam matyti P307 su istatytu i sonine paneles plastmase KAPOTINIU galinuku... Ne kur nors i stojke, o tiesiog matomiausioj vietoj !
Nu čia tikrai geras.Gali likti be pinigu ir su mėlyna akim.As statau suderinęs su klijentu i stoikę karpoma galinuka su gumele.Nežinodamas nelabai ir suprasi.Šiandien turiu FIAT ULYSSE ir dėsiu 2galinukus.Kitaip pati nepersirakina ir perspėja apie neuždarytas duris po 40sek.Diodas,relė ir kondikas nuo lemputės jungiant aš žinau .Bet tai panaikina šias funkcijas. |
