 2026 m. gegužės 28 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2026 05 28, 00:32. Visos datos yra GMT + 2 valandos.
 Forumas » Programinė įranga » Reike pagalbos !
 Reike pagalbos !
PranešimasParašytas: 2008 07 20, 15:15 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Pario
Tai va persirasiau vindausus ir kai jungiu kompa visada ismeta sita:
A poblem has been detected and windows has been shut down to prevent damage
to your computer
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've this Stop error screen,
restart your commputer. If this screen appears again, follow
these atwps:
Check to make sure any new hardvare or softvare is proprly installed.
If this is a new installation, ask your hardvare or softvare manufacturer
for any windows update you might need.
If problems continue, disable or remove any newly installed hardvare
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe Mode to remove or disable components, restart
your compiuter, press F8 to select Advanced Startup options, and then
select Safe Mode.
Technical information:
*** STOP: 0x000000ED (0X82785AD0,0xC0000185,0x00000000,0x00000000)
Paskui jis greit pranyksta ir persikrauna kompas ir vel viskas is naujo vindausus jau 3 kartus persirasiau ir vis tiek tas pats ka daryt kad viskas butu gerai ? Beto situos vindausus bandziau isirasyt ir y kita pc kitame viskas veike puikei
