Dabar yra 2026 06 06, 10:52. Visos datos yra GMT + 2 valandos.
 Forumas » Automobilinė garso aparatūra » Subo deze Alpine'ui
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 20, 21:43 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
Sveiki, tai va esu papirkes Alpine SWE-1243e, jis atitinkantis mano reikalavimus, nereikia man labai galingo ir nereikia jau visiskai silpno cia man per viduriuka Smile gal kas galit padeti pasidaryt dezute. "Vented Box"? O duomenys mano bumsiuko yra tokie:
Subwoofer Features and Specifications
Power Handling (RMS/peak): 250W/800W
Power Range (RMS): 50W-250W
Frequency Response: 28Hz-1kHz
Enclosure Information:
Mounting Depth: 169 mm (6.7")
Mounting Diameter - Front Mount: 282 mm (11.1")
Added Volume - Reverse Mount**: 1.6 L (0.056 ft³)
Displacement - Front Mounted**: 2.8 L (0.099 ft³)
Displacement - Rear Mounted**: 3.5 L (0.124 ft³)
Recommended Box Types (S)Sealed/(V)Vented/(BP)Bandpass: S/V/BP
Sealed Box Volume Range: 28 - 40 L (0.99 - 1.41 ft³)
Optimum Sealed Box Volume: 35 L (1.24 ft³)
Vented Box Volume Range: 32 - 58 L (1.13 - 2.05 ft³)
Optimum Vented Box Volume: 39 L (1.38 ft³)
Vent Diameter/Length: 7 / 23 cm (2.8 / 9.1")
Electro-Mechanical Parameters
Nominal Impedance: 4 omai
Frequency Response: 28 - 1 KHz
Sensitivity (SPL@1W/1m)*: 89.8 dB
D.C Coil Resistance (Re): 3.6 omai
Inductance (Le) 1kHz/20kHz: 1.02 mH / 0.24 mH
Free Air Resonance (Fs): 28 Hz
Equivalent Stiffness (Vas): 75 L (2.65 ft³)
Mechanical Q (Qms): 3.27
Electrical Q (Qes): 0.43
Total Q (Qts): 0.38
Linear Excursion [(Hvc-Hag)/2)], One-Way (Xmax): 10 mm
Magnetic Linear Excursion, One-Way (Xmag): 23 mm
Mechanical Excursion, Peak-to-Peak: 50 mm
Gap Height (Hag): 10 mm
Coil Height (Hvc): 30 mm
Cone Area (Sd): 502 cm²
Voice Coil Diameter: 50 mm (2")
Magnet Weight: 104 oz (2.95 Kg)
Tai vat. dabar bandau viska vest i programa, kuria katik parsisiunciau dar nelabai suprantu.. tai pakol aiskinsiuos gal kas gali kokiu patarimu duot, daryt su skyle ar be. Kiek skaiciau rekomenduojama 32L su port diameter x length [cm]: 7 x 21.
Cia raso paciam manuale. http://www.restricted.alpine-electronics.co.uk/support/ownersdatabase/SWE-1243E/OM_SWE-1243E_EN.pdf
nenoriu pasidaryti is lempos. suba esu dares bet jau turejau pries tai brezinius tai.. nebuvo ka veikt Smile tai va dabar noriu pasiklaust zmoniu kurie tuom uzsiima Smile tai gal kas pagelbesite?
[/img]
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 20, 21:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
t.y. jai svarbu automobilis audi a4 sedanas.
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 06:47 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Mentality_Zero
ka gi tu cia skaiciuoji..kai suskaiciuosi gausi ta paty ka gamintojas rekomenduoja.. daryk 55L ir nesuk galvos
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 07:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
o man 55L su faziku rekomenduoja ?
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 07:48 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
man 55L rekomenduoja: low / definition
Normal: 32L + 2,8L subas uzima vietos.
Tai gal man daryt 34,8L deze? su faziku. alpine taip rekomenduoja butu normal Smile ka manot?
Cia supratau faziko diametra ir ilgy cm.
O sita formule man kas galetu paaiskinti ?
**): calculate and add volume displacement of port(s)
formula: outer diameter [dm] square times 3,14 devided by 4, times length [dm]
Buciau dekingas, jei nebutumet tokie pikti ir padetumet Smile
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 07:57 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
ai tiekto Smile niekas nepadeda einu darytis deze 35L
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 09:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
taskas
Na ir daryk, zmones tau pasake, 55l. Jei porta per slidziu anga isvesi, o jei nenori taip daryti, daryk band-pass 4th order
Boo!
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 10:33 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
o ta 55L nebus perdidele ?
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 11:52 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Profix
aurimielis rašo:
Su didesne dėže gausi platesnę atkuriamų dažnių juostą, gilesnį bosą, bet šiek tiek didesnį vėlavimą. Su mažesne dėže gausi kietoką bosą, bet jis bus tikslesnis. Plius vietos bagažinėj sutaupysi.
Spręsk ko tau reikia.
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 12:42 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
Profix rašo:
aurimielis rašo:
tai darysiu tada 55L dekui uz pagalba o tai frezika irgi pagal litraza det?
Alpine manuale raso kad 55L dezei frezikas: 10 x 34
o gal kas turit 55L dezes kokius ismeras? pavizdy?
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 13:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
57,8 L dezei. ta prasme 55L dezes reikia o praso manuale dar prideti 2.8L tai gaunasi 57,8 L paskaiciavau siuos matmenis 40x38x38
Kiek pamenu tikriausiai yra skaiciuojama 40*38*38=57760/1000=57,76L
Ar neklystu?
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 16:55 Pranešti apie taisyklių pažeidimą Atsakyti su citata
perihellis
nepamirsk ivertint faziko ir subo dydzio ( nezinau kas ten i tuos 2,8l iskaiciuota, tyngiu skaiciuot kiek fazikas uzimtu toks), dar kad tokie matmenys butu dezes vidui o ne isoriniai, je deze bus trapecijos formos taip pat nepamirsk matematikos
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 21, 19:17 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
perihellis rašo:
manuale raso kad i dezei padaryti 2.8L na tipo cia subas is sios puses uzima, ta manau teisingasi supratau. taip supratau kad matmenys vidui tai cia priklauso nuo storio plokstes, reikia pridet 4cm jai 2cm storio imsiu. o forma bus keturkampa. kitaip tingiu skaiciuoti, dekui uz info. Beje apie fazika tai nezinau zinau jo skersmeny ir ilgy koki gamintojas rekomenduoja tai panasiai ka gamintojas rekomenduoja ta ir bandysim padaryti Smile o seip viska teisingai darau? niekas nieko nesako Smile
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 22, 23:19 Pranešti apie taisyklių pažeidimą Atsakyti su citata
aurimielis
Ei, katik uzgimo naujas klausimas. vis droviuosi pjaut. taigi dar karta pasitiklinu Mounting Depth - Tai Montavimo gylis. ta prasme koks turi buti atstumas nuo subo iki sieneles. ne nuo magneto iki sieneles o nuo plokstes iki plokstes taip supratau? Raso 169 mm (6.7") tai 16,9 cm? buciau dekingas jai pagelbetumet..
 Subo deze Alpine'ui
PranešimasParašytas: 2008 05 23, 11:03 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Black Scorpio
montavimo gylis yra garsiakalbio austis, t.y. atstumas nuo dufuzopriaus virsaus iki magneto apacios. skirtas tam, kad zinotai kiek garsiakalbis lenda gilyn i vidu
