Dabar yra 2026 06 13, 08:26. Visos datos yra GMT + 2 valandos.
Forumas » Autoelektronika » Digital tacho
Digital tacho |
Parašytas: 2008 05 03, 16:25 |
Va radau gan nebloga schemute. Norintieji gali pasidaryt.
Linkai:
http://www.team-bhp.com/forum/modifications-accessories/25692-diy-microcontroller-based-digital-tachometer.html
Dar biski arabiškai
http://www.tuningtalk.com/forum/topic-t769-30.html
Parsidownoadinti schemute ie visa kita galit is cia:
Download
http://w11.easy-share.com/884197.html
or
http://rapidshare.com/files/16779081/Pic_16f84_Car_Tacometre.rar.html
Parts List
1 processor PC board, code 05104001, 78 x 50mm
1 display PC board, code 05104002, 78 x 50mm
1 front panel label, 80 x 52mm
1 plastic case utility case, 83 x 54 x 30mm
1 dark red transparent Perspex or Acrylic sheet, 59 x 20 x 2.5
1 4MHz parallel resonant crystal (X1)
1 LDR (Jaycar RD-3480 or equiv.)
5 PC stakes
3 7-way pin head launchers
2 DIP-14 low cost IC socket with wiper contacts (cut for 3 x
7-way single in line sockets)
3 tactile switches (S1-S3) (Jaycar SP-0730 or equiv.)
1 500kΩ horizontal trimpot (VR1)
1 6 x 20 x 0.5mm sheet copper for heatsink
1 400mm length of 0.8mm tinned copper wire
1 2m length of red automotive wire
1 2m length of black or green automotive wire (ground wire)
1 2m length of 250VAC wire for ignition coil connection
3 6mm tapped spacers
2 M3 nuts
2 M3 x 6mm countersunk screws or Nylon cheesehead cut to length
3 M3 plastic washers 1mm thick
1 M3 x 15mm Nylon screw
1 M3 x 15mm brass screw
Semiconductors
1 PIC16F84P microprocessor programmed with TACHO.HEX program (IC1)
1 LM358 dual op amp (IC2)
1 7805, LM340T5 5V 1A 3-terminal regulator (REG1)
3 BC328 PNP transistors (Q1-Q3)
1 BC338 NPN transistor (Q4)
4 HDSP5301, LTS542A common anode 7-segment LED displays (DISP1-DISP4)
1 10-LED bargraph (Jaycar ZD-1702 or equiv.) (LEDs 1-10)
1 16V 1W zener diode (ZD1)
1 20V 1W zener diode (ZD2)
Capacitors
2 47μF 25VW PC electrolytic
1 2.2μF 50VW bipolar electrolytic
2 0.1μF MKT polyester
1 .056μF MKT polyester
2 15pF ceramic
Resistors (0.25W, 1%)
1 47kΩ
2 1kΩ
1 22kΩ 1W
1 680Ω
1 22kΩ
3 470Ω
2 10kΩ
2 220Ω
1 4.7kΩ
13 150Ω
2 2.2kΩ
1 10Ω 1W
Miscellaneous
Automotive connectors, heatshrink tubing, cable ties, etc |
Digital tacho |
Parašytas: 2008 05 03, 20:55 |
Buvo shita autospeede.
Idejos labai patiko, bet mano versija (po daugelio shimtmechiu) bus ant atmegos. PIC'ai - elektroniku ishmislas, o ne prosas . Ant intelio uzhaugus, prie avr'u ipratus - pic'a programint uzhknisa.
Sau |
