Dabar yra 2026 06 12, 05:40. Visos datos yra GMT + 2 valandos.
 Forumas » Mikrovaldikliai » del programos kodo
 del programos kodo
PranešimasParašytas: 2008 04 01, 20:39 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ramasp
sveiki, dariau robota pagal straipsni "99 botas" turejau namuose atmega16 tad ja naudoju, tap pat neturejau servo varikliu, tai panaudojau paprastu variklius su h-bridge'u. prie 19 ir 18 koju jungiau IR ledus o prie 16 ir 17 tsop1738, prie 22,23,24,25 koju jungiu h-bridge'a kuris valdo du variklius.
teko keist koda, pakeiciau taciau neveikia.. gal kas suprantat basic kalba ir galetu man paaiskinti?
programos kodas:
'Tell the compiler which AVR chip we use
$regfile = "m16def.dat"
'Tell the compiler which crystal frequency was used
$crystal = 10000000
Declare Sub Left_blink
Declare Sub Right_blink
Declare Sub Go_forward
Declare Sub Go_back
Declare Sub Go_left
Declare Sub Turn_left
Declare Sub Go_right
Declare Sub Turn_right
Declare Sub Stop_it
Declare Sub Back_left
Declare Sub Back_right
Dim Led_on As Byte , Led_off As Byte
Dim Object As Byte , I As Byte
Const No_object = 0
Const Right_object = 1
Const Left_object = 4
Const Center_object = 5
Compare1a = 131
Compare1b = 131
Config Pind.3 = Input 'LEFT RECEIVER OUTPUT
Config Pind.2 = Input 'RIGHT RECEIVER OUTPUT
Config Portc.0 = Output
Config Portc.1 = Output
Config Portc.2 = Output
Config Portc.3 = Output
Enable Interrupts
Do
Left_blink
Right_blink
If Object = No_object Then
Go_forward
Elseif Object = Right_object Then
Turn_left : Waitms 200
Elseif Object = Left_object Then
Turn_right : Waitms 300
Elseif Object = Center_object Then
Go_back : Waitms 200 : Turn_right : Waitms 200
End If
Object = 0
Loop
End
Sub Left_blink
Led_on = 0 : Led_off = 0
For I = 1 To 5
Config Timer1 = Timer , Prescale = 1 , Compare A = Toggle , Compare B = Clear , Clear Timer = 1
Waitus 600
Led_on = Led_on + Pind.3
Config Timer1 = Timer , Prescale = 1 , Compare A = Clear , Compare B = Clear , Clear Timer = 1
Waitus 600
Led_off = Led_off + Pind.3
Next I
If Led_on = 0 And Led_off = 5 Then
End If
Waitms 10 'THIS IS THE MINIMUM POSSIBLE VALUE
End Sub
Sub Right_blink
For I = 1 To 5
Config Timer1 = Timer , Prescale = 1 , Compare A = Clear , Compare B = Toggle , Clear Timer = 1
Waitus 600
Led_on = Led_on + Pind.2
Waitus 600
Led_off = Led_off + Pind.2
Next I
Object = Object + Right_object
End If
End Sub
Sub Go_forward
Portc.0 = 1
Portc.1 = 0
Portc.2 = 1
Portc.3 = 0
End Sub
Sub Go_back
Portc.0 = 0
Portc.1 = 1
Portc.2 = 0
Portc.3 = 1
End Sub
Sub Stop_it
Portc.0 = 0
Portc.1 = 0
Portc.2 = 0
Portc.3 = 0
End Sub
Sub Go_left
Portc.0 = 0
Portc.1 = 0
Portc.2 = 1
Portc.3 = 0
End Sub
Sub Turn_left
Portc.0 = 0
Portc.1 = 1
Portc.2 = 1
Portc.3 = 0
End Sub
Sub Go_right
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Portc.3 = 0
End Sub
Sub Turn_right
Portc.0 = 1
Portc.1 = 0
Portc.2 = 0
Portc.3 = 1
End Sub
Sub Back_left
Portc.0 = 0
Portc.1 = 1
Portc.2 = 0
Portc.3 = 0
End Sub
Sub Back_right
Portc.0 = 0
Portc.1 = 0
Portc.2 = 0
Portc.3 = 1
End Sub
 del programos kodo
PranešimasParašytas: 2008 04 01, 21:32 Pranešti apie taisyklių pažeidimą Atsakyti su citata
Elektronix
basik nesuprantu todel biski ne i tema ppaklausiu pagal koke schema darei h bridge ir kokie varikliai
 del programos kodo
PranešimasParašytas: 2008 04 01, 21:46 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ramasp
variklius islupau is masineles, h-bridge'as irgi prie ju buvo.. jis valdomas per keturis kontaktus. galeciau pabandyt nupaisyt schema, bet ten vistiek neaiskus tranzistoriai(NEC berods)
