Dabar yra 2026 05 15, 15:58. Visos datos yra GMT + 2 valandos.
Forumas » Elektronika žaliems » Dar kart del vu meter
Dar kart del vu meter |
Parašytas: 2007 11 22, 15:17 |
Taigi darau vu meter http://www.modding.lt/site/index.php?module=reviews&id=36 viska sulitavau. Ir sulitavau gerai nes ijungiant windows LED'ai sumirksi. Bet yra problema su winampu jungiant plugina išmeta lentele :
Plug-in executed illegal operation.
Restart of Winamp is recommended
Nors winampa parsisiunciau 2.xx kaip ir reikia ... prašau profu patarimo |
Parašytas: 2007 11 22, 16:13 |
_________________ Pigiai gadinu elektros prietaisus, darau is ju dumu ir sviesos efektus,PM me. |
Parašytas: 2007 11 22, 16:19 |
Nu jej del userport tai nezinau ar gerai... dariau taip "If you run any OS based on the NT kernel (ie- Windows NT, 2000, or XP), you will need an additional program called Userport. UserPort allows you to control hardware resources (such as a parallel port), which is normally prevented in NT except by system functions. You will need to install then run UserPort and type "0x378-0x378" in the left hand box and then click "add". Then click "start" and "update". If you get a "Driver already started!" message, just click update. Now the plugin should work."
Bet jeigu gali pasakyk kaip... |
Parašytas: 2007 11 22, 17:14 |
| Nesuprantu kas yra userport susikonfiguravau viska padariau ir vistiek neveikia ;/// |
