Dabar yra 2026 06 02, 06:14. Visos datos yra GMT + 2 valandos.
 Forumas » Kompiuteriai, jų priedai, periferija » USB laido ilgis ?
 USB laido ilgis ?
PranešimasParašytas: 2004 10 24, 16:50 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ATMEGA
Dabar darau prailgintoja , tai norejau paklausti
kas isbande USB sujungimo maximuma be isrinio irenginio maitinimo ?
 USB laido ilgis ?
PranešimasParašytas: 2004 10 24, 19:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valdaz
kaip suprast be isorinio irenginio maitinimo, bent kokiu atveju bus maitinamas kontroleris,o maximalus ilgis suprantu esant max srovei 500ma as pvz jungiau webcam'a 9m ilgio utp5cat laidu ir veike lyg normaliai IMHO kaip suprantu kuo geresniu charakteristiku bus kabelis tuo ilgesni kabeli galesi naudot (isplaukiant is ilguju liniju teorijos)
Q1: How long of a cable can I use to connect my device?
A1: In practice, the USB specification limits the length of a cable between full speed devices to 5 meters (a little under 16 feet 5 inches). For a low speed device the limit is 3 meters (9 feet 10 inches).
Q2: Why can't I use a cable longer than 3 or 5m?
A2: USB's electrical design doesn't allow it. When USB was designed, a decision was made to handle the propagation of electromagnetic fields on USB data lines in a way that limited the maximum length of a USB cable to something in the range of 4m. This method has a number of advantages and, since USB is intended for a desktop environment, the range limitations were deemed acceptable. If you're familiar with transmission line theory and want more detail on this topic, take a look at the USB signals section of the developers FAQ.
Q3: How far away from a PC can I put a USB device?
A3: With the maximum of 5 hubs connected with 5m cables and a 5m cable going to your full speed device, this will give you 30m of cable (see section 7.1.19 for details). With a low speed device, you will be able to get a range up to 27m, depending on how long the device's cable is. With a straightforward cable route, you will probably be able to reach out 25m or so from the PC.
Q4: I need to put a USB device X distance from my PC. What do I do?
A4: If X is less than 25m or so (see previous question), buy a bunch of hubs and connect them serially with 5m cables. If you need to go farther than that, put another PC, or maybe a laptop, out where you need the device to be and network it with the first PC using something that's intended to be a long-range connection, such as Ethernet or RS-485. If you need to use nothing but USB, consider using USB based Ethernet adapters to hook the PCs together.
 USB laido ilgis ?
PranešimasParašytas: 2004 10 24, 21:52 Pranešti apie taisyklių pažeidimą Atsakyti su citata
ATMEGA
Isbandziau is to ka radau po ranka: China WEBcam,
paprastas ,neekranuotas 6 gyslu signalizacinis laidas.
Su 15 metru nesusitvarke. Toliau, P2 - 350, su 10 metru
dirba be problemu ,o va P4 ir su 6 metrais turi problemu...
Siaip reiketu 20 m.
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 00:37 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vytautas55
prateskim tema, gal kas daugiau bandet ilgi laido iki webcam'o ir koki?
Panevėžys
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 08:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sweg
5m+3m+1m+DWL-120 dirbo
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 08:43 Pranešti apie taisyklių pažeidimą Atsakyti su citata
burke
bandziau harda pajunk su 5m uzb prailgintoju, nedirbo
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 16:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
JAULER
viskas priklauso nuo laido, kaip jau sakė, kuo geresnį, kokybiškesnį (laidumo, indukcijos atžvilgiu) tuo ilgesnį galėsi naudot, bet kadangi laidai nėra tobuli, tai dar ir siuntimo greitis įtakoja.
teoriškai jei bus superlaidininkas ir neskleis/nepriims elektromagnetinių bangų, tai galės padaryt ir begalo ilgą. šiaip kuo kiekviena gysla bus toliau viena nuo kitos, ir kuo geriau ekranuota, tuo ilgesnį laidą bus galima naudot, čia jau geriau nesusukti laidų (jeigu tai įmanoma) o atskirai didesniais atstumais praskyrus kiekvieną laidą pratempti, bet čia tik taip.
arch linux Wink Smile
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 16:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vytautas55
5 metru prailgintojas jau neleido naudotis irenginiu, tai kokio jam laido reiktu? manau jis buvo gamyklinis. turiu ekranuota 6 gyslu naudojama signalizacijos darbams ,markes nezinau. reiketu pajungti webcam kokiu 10 metru, su trimis metrais prailgintoju dirbo, o su penkiametriu jau nebe, kaip manot tas ekranuotas geresnis nei tas penkiametris usb prailgintojas? o gal is kart ta ekranuota jungti prie webcam'o be esamo laido?
Panevėžys
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 19:54 Pranešti apie taisyklių pažeidimą Atsakyti su citata
USB kabelio max ilgis - 5m.Su salyga,kad tai kokybiskas kabelis.Ilgi riboja maksimaliai leistinas pagal USB standarto specifikacijas impulsu velavimas.Besidomintys galit paskaityt smulkiau cia:
http://www.usb.org/developers/usbfaq/#cab1
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 21:07 Pranešti apie taisyklių pažeidimą Atsakyti su citata
dzeris
Tai aktyvu prailgintoja dek, pvz HAMA
 USB laido ilgis ?
PranešimasParašytas: 2007 10 12, 22:11 Pranešti apie taisyklių pažeidimą Atsakyti su citata
sweg
sweg rašo:
cia buvo USB 1.1
USB 1.1 dar ant ilgesnio kabelio dirba, o USB 2 ant 3 m jau sunkiai arba isvis nenori dirbti.
 USB laido ilgis ?
PranešimasParašytas: 2007 10 17, 00:33 Pranešti apie taisyklių pažeidimą Atsakyti su citata
vytautas55
gal nusipaistysiu, bet vistiek, ar yra com keitiklis i usb? ir ar butu galima sukurt virtualu usb com'e? ar cia kazkaip kitaip turejo skambeti Confused
 USB laido ilgis ?
PranešimasParašytas: 2007 10 17, 22:00 Pranešti apie taisyklių pažeidimą Atsakyti su citata
p12
yra tokių keitiklių. galima ir pačiam pasidaryt
 USB laido ilgis ?
PranešimasParašytas: 2007 10 17, 22:14 Pranešti apie taisyklių pažeidimą Atsakyti su citata
LY1
eXec rašo:
o kaip tie keitikliai vadinasi nes pasigoogkinti noriu..
