Dabar yra 2026 05 14, 23:47. Visos datos yra GMT + 2 valandos.
Forumas » Elektronika žaliems » Gal kas zino apie si daikta daugiau?
Gal kas zino apie si daikta daugiau? |
Parašytas: 2007 07 09, 23:56 |
o bent jau kas ten yra toks?
ir kiek suprantu kazkoks patramkos preidas ar panasiai. tai kam toki namuose panaodoso, gal kara su latvija zadi pradeti. |
Parašytas: 2007 07 10, 00:05 |
| Panasu i tolimati kuri matininkai naudoja... |
Parašytas: 2007 07 11, 11:57 |
| primena taikikli naudojama prie artilerijos pabuklu jai gerai atsimenu jie padeda nusitaikyt (atstumas, koordinates, tik del kmpo abejoju ar nurodo) |
Parašytas: 2007 07 11, 15:31 |
| lugeriukazz rašo: |
O kas yra kmpo?  |
Speju, kad praleista raide a . KAMPO. Nematydamas daikto foto, negaliu pasakyt. Zinau, kad gaubicoms yra naudojama busole. |
Parašytas: 2007 07 11, 16:46 |
radau intike tokia eilute:
TM 5-6675-304-12. Operator's and Organizational Maintenance Manual for Survey Electronic Distance Measuring Equipment, Infrared, Model DM-60(M-1) . . . . 31 July 1980.
ir dar toki teksta:
Infrared Distance-Measuring Equipment
One of the recent items of equipment issued to the field artillery surveyor is the survey electronic distance-measuring equipment, infrared, Model DM-60. This new distance-determining device operates by measuring the phase-delay of modulation signals on an infrared light beam traveling at a known velocity from the DM-60 to a prism type reflector and back to the instrument. An optical line-of-sight is required. With the DM-60 as a component of the fifth-order survey party TOE (all parties except div arty and the TAB), distances up to 2,000 meters can be measured in approximately five minutes. Experienced instrument operators can become proficient with the DM-60 in approximately one hour.
Hand-Held Calculator
Surveyors will soon be able to dispense with the log tables, TM 6-230 and TM 6-231 they are being replaced by the hand-held calculator. As a result of
DM-60, infrared electronic distance measuring equipment.
The DM-60 system contains a distance meter group, a reflector group, and accessory items. When set up for operation, the distance meter measures and displays distances and provides an automatic readout with a resolution of one millimeter. Atmospheric corrections are not required to achieve FA survey accuracies.
One word of caution: Do not throw away the 30-meter tape; it is still the fastest method of measuring very short distances or for use as a back-up means of distance measurement.
The DM-60 instruments are being issued on a unit priority basis at a rate of 20 per month. |
Parašytas: 2007 07 12, 11:08 |
Visai pamirsau prie to aparato buvo du stuveliai ant abieju yra po tris dezutes o jose kazkokie blizgus veidrodeliai Ten yra dar ir akumas bet itampa neparasyta Ir neradau kaip ji pajunkt  |
Parašytas: 2007 07 15, 17:36 |
| lugeriukazz rašo: |
gal parduosi?
12v,tik nesumaisik +/- |
Parašytas: 2007 07 15, 23:21 |
Ten jungtis su sregiu.. Ir trys kontaktai.... O parduot tai parduodu... 500Lt... Kaina nezmoniska tdl kad nepirktum  |
Parašytas: 2007 07 16, 23:15 |
Nu cia speju bus cilindrne jungtis... Joje trys kotaktai prie kiekvieno kontakto po raide... virsui kairei A virsui desnei C apacioj B... O virs kontaktu parasyta 12-3... Tai kaip cia suprast?  |
Parašytas: 2007 07 17, 21:21 |
| lugeriukazz rašo: |
12mm turbut skersmo,o3 kontaktai,senai tai buvo tiksliai nepasakisiu,A greiciausiai +,C - leka laisvas arba korpusas,su testeriu prie pliuso pridejus pliusa kita prie- rodis grandine(maza varza) o atvirksciei begalibe arba daug didesne
Palauksiu kol kaina sumazes. |
