 2026 m. gegužės 21 d. Projektas | Reklama | Žinokite | Klausimai | Prisidėkite | Atsiliepimai | Kontaktai
Dabar yra 2026 05 21, 20:35. Visos datos yra GMT + 2 valandos.
 Forumas » Automatika, robotai, RC modeliai » PLC O/I bit resolution
PranešimasParašytas: 2007 06 10, 16:31 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
Ką reiškia analoginio įėjimo/išėjimo bitai? Kokia tai turi įtaką? privalumai/trūkumai?
PranešimasParašytas: 2007 06 11, 21:06 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
sužinojau iš kito forumo Very Happy
valentinas - For example i have PLC with outputs with AO 8bit resolution.
What does it meen, and what influence it gives?
Yesterday, 09:21 AM #2
Tharon
Member
Local Time is: 02:04 PM
Posts: 148 I believe it means you have an Analog Output with 8 bits of resolution.
8 bits means that your full scale of output is either -128 to 127 (Or is it -127 to 128?) or 0 to 255. The more resolution it has, the finer tuned the analog signal can be. 10V/256 (8 bits) is less resolution than 10V/65536 (16 bits).
Edit:
Just to explain where those numbers came from. The bits are how many bits of binary are used for the output.
8 bits of binary is 2^8 = 256.
16 bits of binary is 2^16 = 65536
Yesterday, 01:16 PM #3
valentinas
Member
Posts: 2 Quote:Originally Posted by Tharon
Edit:
so more bits meens biger precision of measurement and controling?
Yesterday, 02:46 PM #4
Tharon
Member
Posts: 148 Yes.
But it also depends on the accuracy of the devices you are using for your input and output. A system is only as accurate as your least accurate device.
Today, 08:45 AM #5
Tom Jenkins
Member
Local Time is: 01:04 PM
Posts: 3,900 Quote:Originally Posted by nightex
Don't confuse resolution with accuracy.
Accuracy is the difference between the "right" value and the actual value. A lot of things influence this, and I've seen 12 bit and 16 bit I/O that had a lot of drift and error.
Resolution is the number of decimal places or digits in the display. It isn't the same as accuracy. You can display a wrong answer to 20 decimal places.
And look at the resolution required. 1/256 = 0.4% If you have a 1% accurate sensor or a valve positioner that is ±2% (which some are) then additional resolution probably won't give more accurate results."
Jei kas galvojate kitaip, ar ka nors pridurtumete, ar galbut cia pasakyta neteisingai... Rolling Eyes bet esme manau pasakyta
PranešimasParašytas: 2007 06 11, 21:07 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
Paskutinį kartą redagavo valentinas, 2007 06 11, 21:10. Redaguota 1 kartą
valentinas
Confused error posting. Du postai ish vieno gavosi
PranešimasParašytas: 2007 06 12, 21:23 Pranešti apie taisyklių pažeidimą Atsakyti su citata
JAULER
tai kad čia nieko nepasakė, tieisog pasakė, kad 8 bit`ai eina nuo -127 iki 127 arba 0 - 255, arba kad prietaisų tikslumą kartais apibūdina, o kas yra analoginis bit`as tai vistiek lieka klausimas. Realiai jau bitas yra kilęs nuo žodžio binary digit, kas reiškia, kad negali būt analoginis, kažko aš čia nesuprantu...
arch linux Wink Smile
PranešimasParašytas: 2007 06 13, 13:10 Pranešti apie taisyklių pažeidimą Atsakyti su citata
krienas
Šiaip tai, atraminis signalas dalinamas iš max skaičiaus ir turi 1 bitinio žingsnelio analoginio signalo reikšmę....
PranešimasParašytas: 2007 06 13, 18:21 Pranešti apie taisyklių pažeidimą Atsakyti su citata
JAULER
hmm, analoginiu bit`u gal galima pavadinti kažką tokio, kai yra ADC tai tam tikra įtampa atitinka bit`ą, kaip krienas sakė, (aš tiap supratau)
PranešimasParašytas: 2007 06 17, 12:02 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
JAULER rašo:
ash tai taip supratau: bitu skaicius parodo kokia bus signalo rezoliucija, tai reishkia pvz 8bit bus 2^8=256. Skaičius 256 reiškia kad signalas bus ivertintas skalėje nuo 0 iki 256. Ty jei maksimalus tavo signalo reikshme 10V tai 256 skaleje tai atititks 256, jeigu tavo signalas bus 5V iš dešimt tai atitiks 128 (gavau taip 256/2), o pvz jei bus 4V tai 256*4/10=102,4, čia PLC jau nebeatpažins dalies 0,4 iš 102,4, nes rezoliucija permaza, jis matys 102, tai reiškia kad jis 4V nemato jis mato tik 3,98V (10*102/256). An kiek PLC gali skirti signalo lygį priklauso nuo įjėjimų ir išėjimų bitų
PranešimasParašytas: 2007 06 18, 00:09 Pranešti apie taisyklių pažeidimą Atsakyti su citata
JAULER
tai jo, aš tiesiog paėmiau pavyzdį su ADC.
PranešimasParašytas: 2007 06 18, 10:29 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
krienas rašo:
ka reishia atraminis signalas?
JAULER rašo:
ka reishkia ADC?
PranešimasParašytas: 2007 06 21, 00:44 Pranešti apie taisyklių pažeidimą Atsakyti su citata
JAULER
ADC - analog to digital converter
t.y. prietaisas, kuris iš analoginio signalo paverčia jį skaitmeniniu.
PranešimasParašytas: 2007 06 21, 09:03 Pranešti apie taisyklių pažeidimą Atsakyti su citata
valentinas
JAULER rašo:
ne apie skaitmenini signala kalbame gi Smile
