Dabar yra 2026 05 05, 14:58. Visos datos yra GMT + 2 valandos.
Forumas » Elektronika žaliems » noriu pasiteirauti apie B&W DM 602 S2 garsiakalbius...
noriu pasiteirauti apie B&W DM 602 S2 garsiakalbius... |
Parašytas: 2007 03 17, 20:23 |
neturiu ne zalio supratimo apie omus ir watus
turiu B&W DM 602 S2 garsiakalbius - kokio stiprintuvo jiems reikia, kad maximaliai butu isnaudotos technines galimybes?
buciau labai dekingas, jeigu kas ivardintumete konkrecius modelius...
is anxto dekoju
Specifications:
Description: 2-way, 4th-order vented-box system
Dimensions Height: 490mm (19.3in)
Width: 236mm (9.3in)
Depth: 306mm (12in)
Net Weight 9.8kg / 22lb
Frequency Response: 52Hz - 20kHz ± 3dB on reference axis
Frequency Range: -6dB at 43Hz and 30kHz
Sensitivity: 90dB spl (2.83V 1m)
Nominal Impedance: 8 ohms (minimum 4.3 ohms)
Power Handling: 25 - 120W into 8 ohms on unclipped program
Drive Units: 1x 26mm (1") metal dome high-frequency,
1x 180mm (7in) woven Kevlar® cone bass/midrange
Finish: Cherry or Black Ash vinyl
Grille: Black Cloth
Dispersion: Within 2dB of response on reference axis
Horizontal: over 40° arc
Vertical: over 10° arc
Harmonic Distortion: 2nd & 3rd harmonics
<1% 60Hz - 20kHz (90dB spl, 1m)
Max. recommended cable impedance: 0.1 ohms
Crossover frequency: 4kHz |
Parašytas: 2007 03 17, 20:59 |
| tomukas1990 rašo: |
| kiek kolonke W tokio ir stiprintuvo reik |
kokia tavo nuomone apie sita?
NAD C320BEE
Features
2 x 50W Minimum Continuous Power into 4 / 8 ohms
110W, 160W, 210W IHF Dynamic power into 8, 4 and 2 ohms
PowerDrive amplifier technology
Headphones socket
High Current Holmgren Toroidal Power Transformer
Relay Input Switching
7 Line inputs, including two tape in/outs
All discrete circuitry
Short signal path from input to output
All sockets Gold Plated
Bass and Treble controls with Tone Defeat switch
Main-amp Input & Pre-amp Output
NAD Soft Clipping
IR Input & Output
Full System Remote control including Stand-by/Off
12V Trigger Output |
Parašytas: 2007 03 17, 21:21 |
| eXec rašo: |
| ne tik galios, bet ir varžos turi būti tokios pačios pvz kolonkė 4 omu, tai ir stipras turi būt skirtas 4 omų kolonėlei. |
kiek suprantu sis stipriakas palaiko 4/8 omus pastovios sroves ir 8/4/2 omus kintamos - ar teisingai supratau?
o kaip del siu garsiakalbio parametru? ar jie turi sutapti su stiprintuvo - ar tiesiog stiprintuvas viska kontroliuoja automatiskai?
(nepykit, jeigu mano klausimai jums atrodo kvaili - tiesiog noriu zinoti, nenoriu aklai pirkti) |
