Dabar yra 2026 06 13, 08:43. Visos datos yra GMT + 2 valandos.
Forumas » Automobilinė garso aparatūra » su vibe space 12 gal kas pades?
su vibe space 12 gal kas pades? |
Parašytas: 2007 01 24, 17:16 |
taiva nusipirkau vibe 12space, bet ten prie jo nebuvo jokios brosiuros apie subo dezes turi ir pan. intike radau jog rekomenduoja 2,5 kubiniu pedu turio. kadangi noriu daryti deze su faziku tai nzn kokio skersmens ir ilgio jy parinkt. buciau labai dekingas jei kas paskaiciuotu turi ir t.t. ir prie to pacio butu ydomu jei ir uzdarai dezei turi kas isskaiciuotu...
Space 12
RMS power 1000
Peak power 300
Min, Input wattage 500
Diameter in inches 12""
Z- Nominal Impedance in Ohms Dual 4
Qts = Total Q factor of driver 0.501
Vas = Equivalent acoustic volume in cubic litres 37.630
Xmax = peak linear displacement of cone in mm 14
SPL = Speakers SPL 1 watt at 1metre in dB 86.352
Voice Coil Diameter in inches 3
Mounting Depth in mm 175
Mounting Diameter in mm 285
Sd = Piston area in square metres 0.053
Cms = Mechanical suspension compliance 94.339
Mms = Mechanical mass of cone and free air load in grams 200.505
Qms = Mechanical Q factor of driver 3.444
Qes = Electrical Q factor of driver 0.657
Revc = DC voice coil resistance in Ohms 7.2
Fo = Free air resonance frequency in Hz 36.594
No = The reference efficiency of the system in % 0.271
Mmd = Diaphram mass in grams 193.490
Magnet weight in oz 120
Speaker displacement in metres 0.0184
Xmax = Maximum peak linear excursion of driver, in metres 14mm
Vd = Maximum peak linear excursion of driver, in metres 38L
Re = DC resistance of the driver's voice coil. Re is less than the driver's rated impedance (normally 4 or 8 ohms) 2x3.6 Ohms
Le = This is the voice coil inductance measured in mH 2.78mH
BL = The magnetic strength of the motor structure 22.5TM
QTS = The driver's Q at resonance (Fs), due to all losses; dimensionless 0.49
NO = The reference efficiency of the system (eta sub 0) dimensionless, usually expressed as % 0.2%
SPL = Sound Pressure Level, usually measured at 1 watt,
at 1 metre in front of the loudspeaker 87.8dB
nu cia tai kazkokie parametriukai meginau pats pasiskaiciuot su bassbox6 bet kad nelabai ten ykirtau prasme |
