Dabar yra 2026 05 09, 05:35. Visos datos yra GMT + 2 valandos.
Forumas » Įvairūs » internetine radijo stotis
internetine radijo stotis |
Parašytas: 2006 12 16, 23:40 |
Sveiki!
Gal kas zinot kaip pasidaryti internetija radijo stotike? Kiek intike ieskojau, tai visur tik mokamos paslaugos... sakau gal kas nemokamai kur mate...? |
Parašytas: 2006 12 16, 23:42 |
| labai paprasta. ant winamp`o atsisiųskshoutcast plug-in`ą, ir viskas. |
_________________ nepamirškit, klysti žmogiška
arch linux  |
Parašytas: 2006 12 17, 00:22 |
Ir tureti gera interneta, koki optini , kad galetu prisijungti ne 3 klausytojai o bent 50  |
Parašytas: 2006 12 17, 01:49 |
Prasau, viska atsisiusk, paleisk ir grok.
Shoutcast Installation and Setup:
1. Go to the http://www.shoutcast.com/download/serve.phtml and download the SHOUTcast WIN32 Console/GUI server v1.9.42.
2. Open the installation file and install it.
3. Next, download the Shoutcast DJ DSP tool http://www.shoutcast.com/downloads/shoutcast-dsp-1-8-2b-windows.exe and install it.
4. Next, we need to edit the shoutcast server configuration.
Go to your Start Menu > Programs > Shoutcast DNAS > Edit Shoutcast DNAS Settings
A text file will open, this the config file for the server.
Main things to worry about:
MaxUsers=XX - Maximum number of users
Password=XX -MUST BE SET! we will need this for the Winamp Shoutcast Console
PortBase=8080 (port that shoutcast stream will use, default is 8080, i leave it at that)
The other options are optional.
Once you set your options, save the file.
5. Now open winamp.
Go to Preferences
Then go to the Plugins : DSP/Effect
Click the Nullsoft SHOUTcast Source DSP plugin.
Once you do, you'll get a new SHOUTcast Source box.
Go to the Output Tab.
Make sure the Password is the same as the one we set in the server configuration in step 4. Also the port is the same too!.
If you have more than one pc running a server, put in the local IP address of the computer in Address, otherwise leave it as is.
Next, go to the Encoder Tab, choose the type you want, (MP3 Encoder), and the settings. I recommend 128kbps, 44,100kHz, Stereo (i have 1.5mbs DSL)
Running your SHOUTcast station
1. Start the SHOUTcast server
Start Menu > Programs > ShoutCase DNAS > Shoutcast DNAS (GUI)
A command box with status and info will show up now.
2, Open up winamp, and if the Shoutcast Source box does not open with winamp, go into winamps Preferences > Plugins : DSP/Effects and make sure the SHoutcast DSP plugin is highlighted.
3. Load up some songs and play them. To listen to your station from a different location, just open up a web browser and put in your ip address and :8080
(ie. www.mywebserver:8080 or 102.332.4.2:8080 )
once you do, you'll be brought to the your shoutcast page and can listen to your station or see what is playing and so on.
P.S mano radijo stotele:
http://shoutcast.com/sbin/shoutcast-playlist.pls?rn=26517&file=filename.pls |
Parašytas: 2006 12 17, 01:57 |
ech spitfire kartu mes raseme ir nemaciau kai pradejau rasyti bet tu viska nukopijavai :/ |
Parašytas: 2006 12 17, 13:08 |
| Pazystamo rašo: |
ir koks tas geras internetas? kokie 2Mb jau gerai? Ar 24Mb reikia? |
Parašytas: 2006 12 17, 14:07 |
kaip ten ta plugina ikelt y winampa? va to nesuprantu
5. Now open winamp.
Go to Preferences
Click the Nullsoft SHOUTcast Source DSP plugin. |
Parašytas: 2006 12 17, 16:46 |
| leopard rašo: |
Ziurint koks tavo interneto upload greitis (ne download). Pvz telekome su 1024 download yra apie 768kbit upload teoriskai. Tarkim groji 128kbit daina,tai jos klausytis gali 768/128=6 klausytojai. Jei groji prasta kokybe pvz 64kbit tai bus 12 klausytoju... Beje telekome net su 4096 downloadu duoda tik 768 upload'o. Tad geriau apsimoka nuomotis serveri tokiam reikalui, jei nori kad klausytojai be trukciojimu galetu klausytis ir ju butu virs 10  |
Parašytas: 2006 12 17, 21:13 |
| Nu man irgi nepavyksta tos stoties paleisti... o ten tam plagine Winampo reikia spausti Connect? Nes kai paspaudziu tai neprisijungia vistiek... |
