Dabar yra 2026 05 02, 07:50. Visos datos yra GMT + 2 valandos.
Forumas » Mikrovaldikliai » atmega128 napasileidzia...
atmega128 napasileidzia... |
Parašytas: 2006 11 13, 21:30 |
yra problema kad parasius bet koki koda pvz kad ir sita kad PORTB.4 koja uzdegtu leda... bet nevykdo ka kalbant apie jau kitus kodus...
Kodas rasytas ant codevisionavr...
Nustatates esu securiti bits kad isorini kvarca 16mhz, bet jei ir atgal ijungus vidini niekas nesikeicia, parsisiusti ir nusiusti duomenys galiu be problemu...
#include <mega128.h>
// Declare your global variables here
void main(void)
DDRB.4=1;
// Port C initialization
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
// Compare C Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer 3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
// Timer 3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
ETIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
while (1)
PORTB.4=1;
Parašytas: 2006 11 14, 17:17 |
| Negi niekas negali pasakyt, kokia galetu but problema kad nevygdo programu atmega128...??????? HELP zmones... |
Parašytas: 2006 11 14, 18:50 |
Na man bent persasi mintis kaip tu pajunges dioda prie kojos? gal diodas pajungtas antraip arba nuo pliuso, tada ijungimas vyksta padavus 0 i porta.
Antras dalykas gal esi sumaises porto kojas nes kojos numeruojasi nuo 0;
Na del fuzu tai turetu buti kaip ir tvarkoj jeigu gali programa irasineti... |
Parašytas: 2006 11 14, 21:01 |
Paziurek ar:
- as yra normalus resetas;
- ar generuoja kvarcas;
- Pažiūrėk su simuliatoriumi ar tikrai programa sukompiliuota darbui nuo adreso 0x0000, ir ar neužsibūna kur nors startup'e. |
Parašytas: 2006 11 14, 22:09 |
dijoda esu pajunges geraij, del kvarco taij pasiaiskinsiu bet idomumo deliai jei vidini esu ijunges vistiek nieko nedaro tai gal su juom ir viskas ok, o del
"neužsibūna kur nors startup'e." ka turejai galvoje...? |
Parašytas: 2006 11 14, 22:31 |
| IAR'as (bei kiti kompiliatoriai) dadeda pradzioje savo initializacijos paprogrames. Ir tik veliau ishkviecia main(). Ir kai kuriais atvejais prie tam tikru konfiguraciju, tas main() taip ir lieka neishkviestas, pakimba kazkur pradzioje. |
Parašytas: 2006 11 14, 22:55 |
| Jei nesunku gal gali per savo kompiliatoriu parasyt kad ta koja uzdegtu tik.... kaip jau minejau as su codevisionavr programuojuos ant atmegos8 viskas ok buvo o ant jos kazko netaip.... pabandyciau tavo programa irasyti.... jei nesunku imesk man i oxegen@xxx.lt |
