Dabar yra 2026 06 28, 06:46. Visos datos yra GMT + 2 valandos.
Forumas » Garso stiprintuvai » Audiophile kondensatoriai
Audiophile kondensatoriai |
Parašytas: 2023 07 16, 15:21 |
Prieš kokius 40 metų patefone Melodija-103 sudegė KT805. Juos pakeičiau į KT808 ir man buvo stebuklas kaip nuskaidrėjo garsas.
Kiek ir kaip pagerėtų garsas, jeigu pakeisti į WIMA kondensatorius? Ką labiausiai įtakotų? Žemus, vidurinius, aukštus dažnius? Efektyviau keisti tik įvade, nes gal per brangu visus? Sakykim ar WIMA kondensatoriai nuskaidrins lėkštės skambesį aukštuose dažniuose?
PS
Bendru atveju VAIVA.AI intelektas duoda tokį atsakymą:
- What sound improvement would we get if we changed the capacitors to WIMA? Would WIMA capacitors have different effects for different frequencies?
- Changing capacitors to WIMA or any high-quality brand can potentially bring about various sound improvements. While it is challenging to provide specific details without knowing the exact equipment and circuit design, generally, WIMA capacitors are known for their low distortion, high precision, and excellent performance in audio applications. Here are some potential sound improvements:
1. Clarity and Detail: WIMA capacitors are designed to minimize signal distortion, leading to improved clarity and enhanced detail in the audio reproduction.
2. Noise Reduction: High-quality capacitors like WIMA can help reduce electrical noise and interference, resulting in a cleaner and quieter audio signal.
3. Smoother Frequency Response: Capacitors play a role in shaping the frequency response of audio equipment. Upgrading to WIMA capacitors may provide a more precise and balanced frequency response, ensuring accurate reproduction across different frequencies.
4. Enhanced Dynamics: Capacitors affect the transient response and dynamics of audio signals. With improved capacitor performance, you may experience better dynamics and tighter control over the sound.
It is worth noting that the impact of capacitors on sound improvement can vary depending on factors such as the specific application, circuit design, and the overall quality of the audio system. Additionally, different types of capacitors (e.g., film, electrolytic) may have different characteristics and can affect specific frequencies or aspects of sound differently. It is always recommended to consult with an audio professional or technician for specific advice tailored to your setup.
Skelbiu.lt buvo skelbimas, kad parduoda Hi-End Vincent patobulintą stiprintuvą, kurio garso kokybė pagerinta 20 proc. Tikriausiai keitė lempas. O gal keitė kondensatorius.
Ar kas tobulinote savo stiprintuvą kondensatorių keitimais? Ar verta?
http://aeaaudio.com/audiophile-quality-capacitors-going-beyond-the-simple-re-cap/ |
Paskutinį kartą redagavo fiedzia, 2023 07 23, 14:31. Redaguota 3 kartus(ų) |
Re: WIMA kondensatoriai |
Parašytas: 2023 07 17, 09:58 |
| fiedzia rašo: |
PS
Keiciau savo 80s pioneeriui visus kondensatorius pries pora metu- visus elektrolitinius i panasonic ir nichicon, o tantalinius i wima plevelinius, taip pat keicius visus tranzus kurie anksciau ar veliau butu feiline i modernius analogus. Negrojo jis blogai, bet restauravau tik del idomumo. Garso pasikeitimai minimalus, sakyciau auksti skaidresni pasidare, bet tai galejo buti ir del elektrolitiniu kondensatoriu pakeitimo. |
Parašytas: 2023 07 17, 14:42 |
| Ibanez rašo: |
Jūs turite omenyje elektrolitinius kondensatorius maitinimo šaltinyje?
Čia WIMA kainoraštis. Sakyčiau papigiai:
https://lt.farnell.com/w/search/prl/rezultatai?brand=wima
Tik man abejones kelia "General Purpose Film Capacitor". Ankstesnėje nuorodoje rašoma: specifically designed for high quality audio use (the so called Audiophile caps) ... can easily take any vintage amp far beyond its original sound quality.
The best capacitor types for audio circuits are polystyrene and (second) polypropylene.
PS
Brangesni nebūtinai geriau ne/skamba
https://www.humblehomemadehifi.com/Cap.html
Ar turi įtaką skambesiui, jungiant nuosekliai arba lygiagrečiai? |
Parašytas: 2023 07 17, 15:23 |
| fiedzia rašo: |
| Ibanez rašo: |
PS
Elektrolitinius VISUS keiciau i panasonic ir nitchicon isskyrus tantalinius, juos i wima plevelinius apie butent kuriuos eina kalba. |
Muzika muzikinė klausa melodija |
Parašytas: 2023 09 27, 08:57 |
VAKARO SKAITINIAI
Vienas lochas pasikvietė du audiofilus guru ir mokinį ištestuoti jo įsigytą aukščiausios klasės muzikinę aparatūrą.
Audiofilai atėjo, atsisėdo. Lochas drebančiomis rankomis su baltomis medvilninėmis pirštinėmis sukinėja blokuose esančius reguliatorius, atlikdamas paskutines korekcijas. Įjungia testinę muziką. Sėdi, klausosi.
Guru klausia mokinį:
Difuzorius girdi?
Girdžiu, dar šalti, atsako mokinys.
Kabelius girdi?
Taip. Ploni ir varis blogos kokybės, atsako mokinys, - signalas stringa.
Maitinimo bloką girdi?
Girdžiu. Pigus ir fonuoja, atsako mokinys.
Locho kakta pasidengia prakaito lašeliais.
Kondensatorius girdi? tęsia guru.
Girdžiu. Blerbia.
Varžas girdi?
Girdžiu, skleidžia triukšmą.
Rozetes girdi?
Girdžiu. Niekam tikusios, prasti kontaktai.
Lochas ėmė neramiai sukinėtis ant sofos.
Elektronus girdi? vėl klausia guru.
Girdžiu, labai traška.
O protonus?
Taip, protonai švelniau girdisi.
Kolegos, neišlaiko lochas, ar jūs muziką bent girdite!?
Dėl muzikos tau reikia kreiptis į melomanus... |
Re: Muzika muzikinė klausa melodija |
Parašytas: 2023 09 27, 09:17 |
| satsek13 rašo: |
O protonus?
Bijau, kad melomanai čia nebepadės...
Per tą elektronų ir protonų triukšmą muzikos vis tiek nesigirdės...
Parašytas: 2023 09 30, 00:54 |
| lampavykas rašo: |
| satsek13 rašo: |
O protonus?
Vakaro skaitinys čia geras.
Tik vat protonų, kaip ir nereiktų minavoti ... |
Parašytas: 2023 10 03, 14:29 |
Audio-filai muzika naudoja stiprintuvams klausyti.
Viskas čia gerai  |
_________________ AC/DC (alternating current and direct current) |
Parašytas: 2023 10 14, 16:31 |
| satsek13 rašo: |
| VAKARO SKAITINIAI |
Aš nei filas, nei melas. Muziką pasileidžiu fonui. Kai dar nebuvo 60, tai galėjo kiaurą parą groti. Matyt iš paauglystės kai Liuksemburgą klausydavau.
Po 60 metų muzika staigiai prarado malonumą. O, jeigu tiksliau, tai klausiau anksčiau visokius Led Zeppelin, T.Rex, Suzi Quotro... su kinietišku namų kinu. Tuomet pasistačiau namą laukuose, nes norėjau klausyti dar ir labai garsiai. Žmona padovanojo Yamaha Rx 676 su Tannoy V4i. Kartu ir muzika pasunkėjo iki M.Mansono.
Netrukus Yamaha mane pradėjo erzinti (kinietiškas neerzino). Nuvažiavau keisti į geresnį. Paklausiau A1020. Truputį geresnis, bet tas pat šūdas. Pardavėjas pasiūlė paklausyti Vincent'ą hibridą. Na va, tokio man ir reikia.
Per metus atsiklausiau ir pradėjo trūkti skaidrumo aukštuose. Bandžiau ieškoti kolonėlių, bet aukštų atkūrimo priimtino neradau.
Tada perklausiau eilę stiprintuvų. Aukšti kai kurių skamba priimtinai, bet nei vienas neatkuria taip kokybiškai žemų kaip Vincent'as. Kiti ir vidurinių negeba atkurti.
Skelbiu.lt radau skelbimą, kad parduodamas pagerintas Vincent'as. Nėra ką ten gerinti, išskyrus aukštus. Tai ir buvo priežastis čia parašyti. Juk kažkas modernizavo. Ir lempų keitimas vakarietiškomis nieko nedavė, nors kai kurie sako, kad girdi.
Tai dabar, kai klausau labai garsiai, sujungiu Vicentą žemiems ir viduriniams su Tannoy kolonėlėmis ir 7 klasės Maratzu aukštiems. Bet dažniausiai negarsiai su 30 litrų atviromis dėžėmis, kuriose yra po 6gd-2 ir 4a-28 ir dar 6MAC dėžės su 3GD-2 nuo Melodija-106 patefono. Tik nebandžiau, kuris 6gd ar 4a gyvą galsą atkuria. Vis galvoju, kad gal reikėtų užkakalinę sienutę uždėti. Ir dar subas yra.
Kolonėlės pajungtos 4mm2 variniais laidais nors stalčiuje guli sidabriniai. Jų jungti net nebandžiau gaišti laiko.
Bet progos Vincentą pasigerinti neatsisakyčiau ir visais kitais atsikratyčiau. Ir dar skirčiau kažkiek tūkstančių kolonėlėms, jeigu jos ženkliai gerioau skambėtų už turimas.
PS
Dabar, kai jau virš 60, visa klausyta muzika malonumo nesuteikia. Labiausiai patinka Masvos grupė OMNIMAR. Ji garsiai jau man nesiklauso. Persikėliau iš 80 m2 svetainės į 15 m2 kambariuką ir dabar čia laiką leidžiu FB. Arba susenau, arba tokiame kambariuke jau garsiai muzika neskamba.
Tai toks būtų komentaras į girto ežiuko vakaro skaitinių kliedesius į netinkamai įdėtą temą. |
Paskutinį kartą redagavo fiedzia, 2023 10 18, 11:46. Redaguota 1 kartą |
Parašytas: 2023 10 16, 19:20 |
fiedzia raso:.....Bandziau ieskoti koloneliu, bet aukstu atkurimo priimtino neradau....
Kitaip ir buti negalejo. Kaip pasakytu vienas is mano draugeliu, kuris yra tos srities profas - jei savo name pakeisite vandentekio vamzdzius, kurie yra prijungti prie pagrindinio vandentekio i titano vamzdi, tai nuo to vanduo geresnis nepasidarys.
Todel ieskoti vadinamu geresniu koloneliu yra beprasmis reikalas |
Parašytas: 2023 11 21, 17:24 |
| fiedzia rašo: |
| satsek13 rašo: |
| VAKARO SKAITINIAI |
Ir dar skirčiau kažkiek tūkstančių kolonėlėms, jeigu jos ženkliai gerioau skambėtų už turimas. |
čia rimti ketinimai ar irgi 'vakaro mintys"? |
Parašytas: 2023 11 21, 19:51 |
| Egis64 rašo: |
šį šeštadienį su stiprintuvu ketinu jau su pinigais važiuoti už lygiai 2,000 ir su didele tikimybe parsivežti. |
Parašytas: 2023 11 22, 19:08 |
fiedzia raso:......buvo skelbiamas, kad parduoda HI-END Vincent patobulinta stiprintuva, kurio garso kokybe pagerinta 20%........
Kaip imanoma HI-END klases stiprintuva dar pagerinti 20% ?. Kas cia toks gamintojas, kuris taip lievai gamina HI-END audio stiprintuvus?
Nors logiskai pagalvojus, tai siandien gamina daugelis, kuris netingi. Ant priekines paneles parasoma, kad tai HI-END audio stiprintuvas - ir daugelis tuo patiki.
Siandieniniai muzikos klausytojai jau nelabai supranta kas tai yra tikras muzikos garsas. Tie laikai jau praejo. Su tuo teks susitaikyti ir toliau gyventi |
GTA 6 Map,
GTA 6 Vehicles,
GTA 6 Character |
