Dabar yra 2026 07 02, 17:20. Visos datos yra GMT + 2 valandos.
Forumas » Maitinimo šaltiniai » maiteko schemos perdirbimas
maiteko schemos perdirbimas |
Parašytas: 2006 10 07, 23:17 |
40v bus didelis skirtumas nuo 24v
pirma reikia surasti didesnes itampos mikroshemas, paskui reikia didesnio atitinkamos itampos transformatoriaus. ir galingesnio transzistorisu ir radiatoriaus |
Re: maiteko schemos perdirbimas |
Parašytas: 2006 10 08, 11:21 |
Ir dar nepamiršk įdėti stabilitronus su aukštesne įtampą, nes kitu atvėju tau vistiek reguliuosis 0-30V ir 0.002-3 A |
Parašytas: 2006 10 08, 14:58 |
stabilitronu keisti gal irnereikia, papratsai nuo stabilitrono itampa nepriklasuo
ten stabilitronai jug 5.6v |
Parašytas: 2006 10 08, 15:11 |
Reikia pakeisti D8 stabilitroną. nes nuo jo priklauso ir išėjimo įtampą ir apribojama srovė. Galima žinoma pasižaisti ir su rezistorių nominalais.
| Citata: |
| The reference voltage is generated at the output of U1. The circuit operates as follows: The diode D8 is a 5.6 V zener, which here operates at its zero temperature coefficient current. The voltage in the output of U1 gradually increases till the diode D8 is turned on. When this happens the circuit stabilises and the Zener reference voltage (5.6 V) appears across the resistor R5. The current which flows through the non inverting input of the op-amp is negligible, therefore the same current flows through R5 and R6, and as the two resistors have the same value the voltage across the two of them in series will be exactly twice the voltage across each one. Thus the voltage present at the output of the op-amp (pin 6 of U1) is 11.2 V, twice the zeners reference voltage. The integrated circuit U2 has a constant amplification factor of approximately 3 X, according to the formula A=(R11+R12)/R11, and raises the 11.2 V reference voltage to approximately 33 V |
GTA 6 Map,
GTA 6 Vehicles,
GTA 6 Character |
